My Dell Inspiron 1525 Laptop is turning on by itself. I have run virus checks and nothing comes up (used latest Norton as well as the virus scan provided by my internet provider - Bell). I checked my bios and I don't see any setting for an auto turn on. Also checked 'Wake on LAN' and it is disabled (also unplugged my wireless modem one day and it still turned on by itself). Not turning on at the same time either, very random (sometimes will be on when I return home from work, other times it will turn on during the night). Any help would be appreciated!!
Dell inspiron 1525 with vista freezes constantly
Delete all unsed data, erase cookies and browser history, disk defrag, virus scan. It might help if you boot in safe mode to do this.
Oct 23, 2012 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
When I watch CNN I cant get the videos to play on my Dell inspiron 1525 laptop?
Update your Adobe flash player software to the latest version:
http://get.adobe.com/flashplayer/
If that doesn't fix it you might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs..
Jun 27, 2012 | Dell Inspiron 1525 Laptop
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
I have a del 1525 inspiron that displays the windows error recovery. it gives me two options to repair the computer or to start windows normally. it doesn't matter which one i click on it doesn't work. i...
this is a virus and you need to remove the hard drive and have it scenned for spyware and virus. the computer or laptop that you use for the scanning must be clean. try this and see how you get on. If it doesn't i have another fix
Mar 07, 2010 | Dell Inspiron 1525 Notebook
Re: dell inspiron 1525 laptop shutdown.
There is a good possibility that you have some nasty malware or viruses. I will give you links below to programs that will clear out the problems....
At the end of this are three links to programs that you should load up and run. The first is MalwareBytes Ant-Malware Tool, another is Avast Anti-Virus 4.8, the third is Threatfire.
Run MalwareBytes first and perform a quick scan, when it finishes, it will ask you to show the results, click on “Show results, all infections will appear in red. Delete everything it finds.
Run Avast and install it, when it asks, go ahead and schedule a pre-boot scan of your entire system. This should get rid of most problems….Now, if you have Norton Anti-Virus, internet security or any of the others, they also be causing some of your problems. They will have to be removed and the only way to properly do that is go to the Norton site and download their Norton removal tool. Run this before installing any other kind of ant-virus. The Avast 4.8 is free to use, just register it once a year, that is all…it will update itself 2-4 times a day to keep its virus definitions constantly updated, you do not have to do anything, it is completely automated and has 7 real time scanners that run all the time.
When your boot time scan is over and you have either deleted or moved the infection to the chest as Avast recommends, now run Threatfire…it will ask you to let it update as will Malwarebytes, do so. Threatfire monitors every web page on the world wide web and lets you know if your tap dancing where you shouldn’t, it will throw a flag up and say abort connection…do so to save yourself from a bad situation. The links are below.
http://www.filehippo.com/download_malwarebytes_anti_malware/
http://www.filehippo.com/download_avast_antivirus/
http://download.cnet.com/ThreatFire-AntiVirus-Free-Edition/3000-2239_4-10726873.html
http://www.filehippo.com/download_ccleaner/
Jan 18, 2010 | Dell Inspiron 1525 Notebook
Computer shuts off when writing emails from windows live. help.
check for virus/spyware with online antivirus like: norton antivirus, .....
Dec 23, 2009 | Dell Inspiron 1525 Laptop
MY DELL INSPIRON 1525 HAVE PROBLEM
1)check whether the issue exists in safe mode
2)Perform system restore if this is a recent issue
3)Run spyware removal scan from safe mode
Dec 06, 2009 | Dell Inspiron B130 Notebook
Freeze up
If it turns on... Run - "msconfig" - click Startup, and Disable All - then click Services, check "Hide Windows Services", and Disable All
Mar 31, 2009 | Dell Inspiron 1525 Notebook
Computers & Internet Logo
284 people viewed this question
David Payne
David Payne
