Question about The Computers & Internet
How do I do C4B?
The pattern says. "P3,C4B,C4F
How do I decrease a rib pattern
If you are working on the right side of the work, it looks better to purl the two together.
Conversely, if you are working on the wrong side of the work, it looks better to knit the two together.
Aug 29, 2014 | Lion Brand Wool-Ease Thick & Quick Yarn...
Forgot password pattern for tecno p3
Reboot the phone into recovery by first switching it off, then on by pressing power on and volume down button simultaneously, all data and phone related information will be lost, but not SD card data
Aug 09, 2013 | Cell Phones
GEW9250pl0 says to check rotary cycle selector by measuring ohms from pins P1-14 to P1-XX but gives no clue where to test this. I can find no connector labeled P1.
This is tested on the matching connector to P3 that leads into the control board/user interface. P3 is on the console. P1 is the connector that plugs into P3.
P1-14 matches to P3-14 etc. There are exposed connectors on one side of the connector.
Jan 10, 2013 | Dryers
Can I use Nikon Coolpix P3 as WebCam?
No. The P3 is designed to store images and videos to memory, not to stream live video to another device.
Sep 13, 2010 | Nikon COOLPIX P3 Digital Camera
no p3 is never support windows 7 what a silly question!!!!
May 24, 2010 | Primavera Project Planner P3 (PRIMAVERAP3)...
Workloc directory is invalid or cannot be created (server 2003 install of p3.1)
I have 2 suggestions based on my assumptions since you did not elaborate on what environment you are having your P3, network or single user.
1. If you are logging on a network before you open your P3, it is most likely that you don’t have a read and write access to the P3WIN directory or any of its subfolders. So, first you have to log into your computer as an administrator, we call it local administration, and go to windows explorer, right click the P3 directory and choose sharing and security on the pop-up. Add your Network ID or make sure your network ID has all the access enabled for these directories. Then you can go back to the network and restart P3.
2. If it is single user, check your P3.ini located on Windows directory and see if the WORKLOC directory is beyond 54 characters from the root directory. P3 was created in the 90’s when DOS was still one of the reigning OS. So it means it follows the 8+3 rule of filenaming and other limitations. Make sure that the directory listed is as near as possible to the root directory, that is from C:\ Many errors in P3 are caused by these limitations since we’re already used with the new Windows OS’s wherein you can almost create a folder with endless description. My suggestion is, in using P3, try to minimize your folder names to 8 characters, same goes with filenaming.
Jul 22, 2009 | Primavera Computers & Internet
Need instruction for mamas and papas p3 pramette
hi keelyharwood..pls visit this link. they have available instruction manual for download for pliko p3. hope it helps. good luck!!
May 22, 2009 | Peg Perego Pliko p3 Standard Stroller
How to collapse my pilko p3 storller
Contact Peg Perego. They will email you a copy of the maiual for free.
Phone 800-671-1701
Jan 11, 2009 | Peg Perego Pliko P3 Stroller Umbrella
Intel p3 audio driver
hi kumar i need a sound driver for my p3
Feb 05, 2008 | Intel Steinberg Nuendo AudioLink PCI 96...
Computers & Internet Logo
24 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
