Sx580 galler till machine when i take z reading its saying key op error
Geller sx580 how can i do half reset
Turn key to P. Power off then on again.
If anyone needs a Geller SX-580 manual, one of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Towa_SX-580_operating_programming_manual.html
Aug 14, 2014 | Casio Parts Cash Register PC Desktop
System error E000
  • Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer"
  • Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
  • Then press "Set" again, and the display will ask you "Yes" or "No"
  • Press the "Left" arrow for "Yes", then press "Set".
  • Now, unplug the power cord and wait 5 seconds and plug back in
That should clear the error. If it doesn't, get a new fuser.
Feb 29, 2008 | Canon imageCLASS D860 All-In-One Laser...
Geller sx580 cash register till keep beep sound showing kew op error
Make sure you have signed on with your secret log on code. If you have forgotten your code, you'll need to set new codes. There's a programming manual here:
What does the error code "OP" mean?
OP - Open Thermistor - Replace thermistor.
Aug 27, 2013 | Washing Machines
OP display light comes on when hitting start. Then hit off & in a minute it comes on?
Most times this issue is caused by loss of signaling thru the Left Hand Lid Lock.
1st check for a Lid Magnet out of position. This is an easy check if you have a couple key holder magnets or a similar magnet that you can place over the Left side grey lid bumper. Let's see if you can close the Magnetic Reed Relay switch with an external magnet and send +12VDC up to the Control Board and clear the "OP" error code.
If that doesn't clear the "OP" error code we will need to remove the Left Hand Lid Lock and check to see if corrosion is part of the issue. Because of its proximity to that nasty bleach dispenser it will cause issues. Here is the lid lock to order.
Here is a picture of a bad lid lock.
Nov 22, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Geller sx-580 key op error
WHEN Z READING KEY OP EROR COME UP
Aug 06, 2012 | Computers & Internet
I have maytag neptune tl,i moving3 week ago i do a coneccion and a have a cod en tha machine OP,and dont do nothing.
Sorry should read ""Confirm the model number and the 1st two digits if the serial number and I will see if I can help. Is the machine a FAV6800A or FAV9800A? Any error unbalance codes during the spin cycle like dc or UC? ""
You have lost signaling thru the left hand lid lock or have a lid magnet out of posistion.
With the lid open try placing a magnet over the left hand grey lid bumper with the lid open.
If the OP error code clears then it's a Lid Magnet issue. If the OP error code dosen't clear we need to troubleshoot the Left Hand lid lock or replace. I prefer to troubleshoot further before buying a part. Let me know what you want to do. If you want to troubleshoot/DIY the repair we need to move your issue to a better DIY appliance repair forum. Try the external magnet first and rule out a Lid Magnet out of position issue.
See pics;
See if an external magnet over the left grey lid bumper will clear the OP error code.
Nov 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I cannot send or receive faxes. The Transmission Error report says phone line error. I don't know how to set up the fax software; cannot find my Lexmark x8350 manual. Thank you.
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
Jun 20, 2010 | Lexmark X8350 InkJet Printer
Why does it say "op" when i press the start button?
The Service Manual for reference. Sears Parts Direct for reference.
I feel you have lost signaling from the Left Hand Lid Lock for Lid is Open/ Lid is Closed.
First check is to place a magnet over the Left Hand grey bumper and while watching the LED display see if the OP error code clears. If it does you have a lid magnet out of position. See the Service Manual for access to the Lid Magnet.
See Pic;
If an external magnet over the Left Hand grey bumper doesn’t clear the OP error code with the lid open then See this Link for troubleshooting Left Hand Lid Lock Troubleshooting. I discuss the OD error code but the OP error code troubleshooting is very similar. If the lid Magnet is not out of position then I feel you have a broken lead at the Magnetic Reed relay or severe corrosion issues with the Left Hand Lid Lock preventing Lid Open/Lid Closed status signaling to the Control Board in the Console.
FAV6800A/FAV9800A replacement Left Hand Washing Machine Lid Lock - 25001048
Let me know if you have any questions or concerns…….Rich
May 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
