Question about Sewing Machines
How do i remove the embroidery unit from the topaz 40
  • Sewing Machines Master
  • 5,301 Answers
Do you mean the Husqvarna Designer Topaz 40? If so, first make sure that the unit is in Park. You need the sewing machine on to do this. Select the Park Position on the Embroidery Stitch-Out menu. This screen is accessed after you choose a design and press Go (at the bottom of the touch screen on the left). Then press the release button on the bottom of the left hand side of the embroidery unit.
The directions to remove the embroidery unit are in the manual on page 6:3 (page 69 of the PDF). The manual is available from the product page: . Scroll down and look on the left side of the page. The direct link to the manual is .
I hope this helps.
Posted on Dec 31, 2016
My Bernini 830 would not recognize the embroidery attachment. I re-attached many times, but it doesn't work.
I assume you mean a Bernina 830. If you have removed the slide-on table, I have two possible solutions. I've seen this with a couple of Viking embroidery attachment units. (I am also assuming it's not a hoop issue.)
You could have corrosion on the pins that send the signals between the embroidery attachment and the sewing machine. Remove the embroidery attachment and turn off the sewing machine. Unplug the sewing machine. Spray the pins with an electronic contact cleaner; one example is here: . Push the embroidery attachment into the sewing machine by lifting up the far side and then sliding it into the port. Remove the embroidery attachment. Repeat this a few times. (The friction of the insertion and removal will remove any dirt or corrosion.) Plug in the sewing machine and turn it on. Try connecting the embroidery attachment. If it works, remember to clean the contacts the next time the embroidery attachment isn't recognized.
Once I helped someone with two sewing/embroidery machines with an unrecognized embroidery attachment. In that case, the person swapped which embroidery unit went with which machine. The contacts were not the same and didn't mate. Once the correct machine and embroidery unit were paired, the embroidery unit was recognized instantly.
I hope this helps. If it doesn't, you may need to talk to your Bernina repair technician at your local shop.
Aug 19, 2017 | Sewing Machines
What system is on my viking topaz 40 the husqvarna system 5 or system VIP?
The Husqvarna Topaz 40 can use many embroidery file formats as being shown in this Husqvarna YouTube video:
Also refer to your manual page 9:2 which can be downloaded for free at:
Happy Stitching
Mar 14, 2017 | Husqvarna Sewing Machines
My machine does not recognize that the embroidery unit is attached. It keeps saying attach embroidery unit. Has anyone had this problem
What make and model of sewing machine do you have? I have seen this problem with a Husqvarna Viking Designer I (or similar older Viking machine). In that case, the problem was corrosion on the contacts between the embroidery unit and the sewing machine. The solution was to use an electronic contact cleaner to clean the contacts; this is one product: . Make sure that the machine is unplugged. Spray the contact cleaner on the contacts. (In some cases, you should then connect the embroidery unit to the machine and remove it a few times.) Allow the product to dry before you plug in the sewing machine again.
In another case, the solution was actually easier. The owner had two similar embroidery machines. She managed to mix up which embroidery unit went with which sewing machine. Neither embroidery unit could be properly seated on the machine that she attempting to use it with. Once the embroidery unit was paired with the correct machine, both pairs worked.
I hope this helps.
Aug 03, 2015 | Sewing Machines
I have a topaz 25 viking embroidery machine my screen keeps telling me to attach the correct hoop and I already have and he keeps telling me the same thing and won't embroider
Try removing the hoop, then replace it. When you replace it be sure to push hard so it snaps into place. If you don't hear or feel the snap, it is not in all the way.
Feb 24, 2015 | Sewing Machines
Poor tension on a Viking Topaz 20
Is the thread coming off the Thread Take Up? That will cause issues. Another thing would be to take apart the bobbin area and clean it thoroughly. If you have one of the sewing machine vacuum attachments that would be the best way to clean it. Good luck.
Apr 16, 2014 | Sewing Machines
Husqvarna Diamond Embroidery unit problems
Make sure that the red disk (smaller than a floppy) on the underside of your embroidery unit has been removed. Remove and discard the red disk. It is used for shipping purposes only. Joyce
Jan 10, 2009 | Husqvarna Viking 1
The carriage of the embroidery unit is not move automatically to the embroidering standby position.
Is the need in upright position ?
or have you fitted the embroidery hoop correctly.
If all else fails switch off and start up again - should then automatically go to correct position.
May 16, 2008 | Singer CE-200 Quantum Futura Computerized...
Pfaffa 7570 Creative Fantasy Embroidery Unit does not move
Try turning the machine off, removing the unit and then placing it back before turning the power on again.
Apr 08, 2008 | PfaFF Creative 7570
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
