Question about Saws
I need the peice where the blade of a table saw comes up
    Top Expert:
  • 46,460 Answers
Try the manufacturer or make your own
Posted on Jan 01, 2017
How do you attach the kerf and saw blade guard
Don't your safer with out it unless you paid big money for a top of the line saw .
I see these things all the time they don't work correctly peices that you are trying to cut hang up in the kick back device.
Just have the respect for the tool it desurves and use the correct blade for what you are cutting .Keep the blade as low as possible less restiance and less blade use your pusher keep hands away from blade .
And if you want it to cut true you need a stand or base The new ones are all made out of plastic /the motor mounts to the plastic the plastic flexs the blade mounts to the motor so it wanders .
You can take a peice of 5/8 plywood cut a square hole in it and bolt it to the plywood and you will find it works much better stright percise cuts .
May 07, 2015 | Saws
2 questions re Craftsman Tablesaw 137.218072 since the young men in that dept at our Sears did not know what a table saw was!
You can find a nice quality feather board that will fit your table saw from www.leevalley.com. They have one that comes with both 5/8" and 3/4" table bars and sells for about $15. I have one and it works great, Look under the Woodworking tab and type in feather boards. Look at the brand Versatile Featherboards. http://www.leevalley.com/US/wood/page.aspx?p=60022&cat=1,240,45884,60022 You may want to call Lee Valley to see if they have a zero clearance insert that will fit your saw. Otherwise, order a new insert from Sears Parts Direct. From the picture on their website I believe it comes as a blank and you will need to cut the new opening in the insert. To do that lower the saw blade all the way below the table top, install the new insert, move the rip fence over top of the insert but not over where the saw blade would penetrate, turn on the saw, and slowly raise the blade up through the insert.
e1e75b0f-dc3b-4bbe-bf84-360a611e8e41.jpg b3efb051-1d00-43f6-bc27-d2f9d84da710.jpg
Oct 02, 2014 | Craftsman 10" Table Saw
I have to push blade to start and after a little while breaker trips
The Start capacitor is bad. (CD60A) Made in China the min. order is 1000 peices, replace motor cost more than the saw, or get a 200 uf 250vac capacitor (Grainger) to replace the CD60A. It is larger so you have to mount it on top of the external cap on the motor. I think the CD60A is going to be a major problem on all these saws.
Feb 18, 2013 | Craftsman 10" Table Saw
I just bought this table saw and when i tilt the blade to 45 deg. the blade rubs on the blade insert. also when i put it together it didnt come with a riving knife and hardware.
I ran into that kind of problem with my Craftsman 10 table saw. I (an usual) over analyzed the problem and looked at moving the entire motor assembly from left to right slightly. In the end, I found that that the blade stablizer plates I used on the left and right of the blade, moved the blade that little bit needed to make the blade tips make contact. I removed the two stablizer plates, reinstalled the blade with the normal to flat washers and gave it a try. The blade now cleared the insert when pushed all the way to 45 degrees.
You might want to look to make sure there are no extra washers/spacers on the arbor that might move the blade slightly left or right from its normal position.
Dec 08, 2010 | Craftsman 10" Table Saw
MAKITA #2703 table saw 10'' to rise and lower blade it
i would say the table is twisted then, strip it down first and if you need to "bend!" it back so it works
Mar 27, 2010 | Makita 2703 10" Table Saw, Electric Brake
How do i change the blade on my delta 10" mitre saw
Exploded diagram for your SM100M miter saw is here.
User manual is here.
Page 20 covers blade change operation.
Make sure you unplug your saw! You need to remove a screw from the cover and rotate the cover to the rear. Use a hex wrench in the motor shaft to keep the saw blade from turning, and loosen the arbor nut with a 1/2" wrench. The arbor is reverse threaded, so you'll turn it clockwise to loosen, then counterclockwise to tighten it up after you have swapped the blade.
Rotate the cover back after that's done, and replace the screw.
If this was useful, please vote. Thanks.
Nov 23, 2009 | Delta SM100M 13 Amp 10" Compound Miter Saw
I have an old Makita table saw and need to change the blade. It is a circular saw mounted under a table. I can't find the stop that allows me to unscrew the fixing nut on the blade. It is Makita Model...
This link will take you to Makita and display an owners manual where you will see that the saw should have came with the necessary wrenches to change the blade. If they are not available I have used two different methods. Take care with either, that blade is just waiting to getcha. 1. I have clamped a pair of vice grips directly on the blade and let them stop against the saw top to keep the blade from turning or 2. I have levered a peice of soft wood against the blade to keep it from turning. According to Makita the thread is righthand, so you can apply the righty tighty lefty loosey rule to determine which way to loosen the nut. Good luck I hope this helps.
Nov 22, 2009 | Dishwashers
Crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Jan 04, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Table Saw blade
Did you remove the center plate? It has to come out before you can remove the blade. Also make sure that the saw is unplugged before you go any further. If you still have questions contact me and I will do what I can. Also if you would like you can download a schematic of this tool at Makitatools.com just type in your model and look at the schematic. Good luck
Jan 03, 2009 | Makita Saws
Blade size
There are two common blades: Eight-Inch Table Saws are a good choice for crafts and other applications associated with thinner stock.Ten-Inch Table Saws provide the extra cutting depth needed for angled cuts in thicker stock.
Aug 27, 2008 | Jet 708315BTC Jbts 10BT 3 15 Amp Benchtop...
Saws Logo
42 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
