Question about RCA Class 1080p 120Hz Smart Back Lit LED HDTV - SLD55A55RQ 55 in. Black 50 to 59 in
My RCA flat screen model SLD55A55RQ flipps colors when you turn it on the sound works just see the colors. What do i do to get picture to come back in need help bad. Please help me
SOURCE: goodmans flat screen TV.Blank screen
If it is a LCD TV, and there is a faint picture, it is probably the backlight or inverter board (probably the latter). This is a common problem (especially with PC monitors).
Do an internet search for your model and inverter, you may be able to replace it.
Make SURE you REMOVE the power lead before opening the set !!!!
Posted on Mar 03, 2008
  • 19 Answers
SOURCE: LG LCD flat screen TV - 42LG50-remote control is unresponsive
Sounds like a probable main board issue
Posted on Feb 21, 2009
  • 13 Answers
SOURCE: sound no picture
http://www.avsforum.com/avs-vb/showthread.php?p=18039617#post18039617
This about a different issue, but has good pics. See my posts at the end. The LVDS ribbon cable is even easier to get to then the LCD controller ribbons. Take off the stand, and back cover. Take off metal 'cage' on back, the ribbon underneath can become dirty or loose. Untape the cable, unclip and remove it. Rub it clean with an eraser. Replace and re-affix with some metal foil tape or other heat resistant tape from the hardware store.
Drop me a line if ya want.
alchemancer@yahoo.com
Posted on Jan 31, 2010
yammy_alf
  • 666 Answers
SOURCE: RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Posted on Mar 26, 2010
  • 246 Answers
SOURCE: No picture on coby tv
I'm not certain but it sounds like there is a loose video cable in there...if you are able to, take the tv apart, and literally push on all of the connectors and cables to make sure they are not loose. The main video cable may not seem to be loose, but once it is making contact again, it should clear that mess up. Just look for cables running to the main screen and pull them off and put them back. Then put the tv back together again and see if it worked...it usually does. why does this happen? Some blame it on dust, others blame it on quick manufacturing processes...whatever the case, the cables become slightly seperated from the controller board and that happens...it also happens to computer monitors too...Good luck and take your time. If there are a lot of screws and things either take pictures of where they all went or write it down. I like to make a diagram on a piece of paper and tape the screws on the diagram to show where they went.
Posted on Sep 01, 2012
My RCA flat screen model SLD55A55RQ flipps colors when you turn it on the sound works just see the colors. None of the answers are for a Rca model flat screen
T'Con board fault. Check and replace it. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jan 24, 2017 | RCA Class 1080p 120Hz Smart Back Lit LED...
RCA SLD55A55RQ 55 INCH HDMI SMART TV CUTS OFF AFTER FIVE MINUTES
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 20, 2016 | RCA Class 1080p 120Hz Smart Back Lit LED...
My RCA model no. SLD55A55RQ when i turn it on it flashes white,blue,red,green how do i stop this or fix this?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 13, 2016 | RCA Televison & Video
My tv RCA SLD55A55RQ doesn't update it said metadata fail.
Contact the authorized service center. This is not a fault repaired at home. http://electronicshelponline.blogspot.com/
Sep 26, 2016 | RCA Televison & Video
Tv screen has gone black but still have sound when you shut the tv off and turn it back on the screen comes up but it flashes and goes black again
Hi Bob, The link below is a YouTube video showing how to fix a RCA television(DIFFERENT MODEL) NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
RCA 46LA45RQ tv repair No picture no power troubleshooting
May 01, 2016 | RCA L46WD250 46 in. LCD HDTV
HOW CAN I RESET A RCA 55 SMART TV MODEL SLD55A55RQ, WITH A BLACK SCREEN
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 07, 2015 | RCA Class 1080p 120Hz Smart Back Lit LED...
Rca 62" PROJECTION FLATSCREEN - COLOR PROBLEM/FLICKERING SCREEN
Sounds like the red picture tube could be shorting internally which would cause the "all red" condition. In which case you'd have to replace the red tube. Are there horizontal (slightly slanted) lines through the picture as well when this is happening and a very very bright screen? If so it's most likely the tube.
Oct 06, 2008 | RCA F36645 TV
Rca p52771at - dark picture
Sounds like a bad screen asy,part number 204809,must use the generic,or you could have weak tubes,if so you may just need to turn up the screen drives,this part is located in the right top of the set with the back removed,if no cracks are present adj. the three marked screen's,turn the color all the way down in your menu and adj. for a black and white picture.
Oct 07, 2006 | RCA P52771AT 52" Rear Projection...
RCA Class 1080p 120Hz Smart Back Lit LED HDTV - SLD55A55RQ 55 in. Black 50 to 59 in Logo
59 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
