Question about Channel Master Televison & Video
Codes for channel master dvr - Channel Master Televison & Video
    Habit-Forming:
  • 195 Answers
What model?
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Posted on Jan 07, 2017
How to reset hi-focus h264 dvr admin password?
173480
8456Hl
375611
Please use above the Master Password. This password is only valid for today.
Kindly use the master password from VGA/HDMI.
Kindly follow the below procedure to reset the password:
Remove LAN cable if it is attached
Restart you DVR
Choose the "admin" account in USERNAME
Use MASTER PASSWORD in PASSWORD. Now you can access your DVR
Go for Main Menu >Advance > Account
Select "admin" user
Click on Modify Password, In Old Password Use Master Code,
In New & Confirm Password type your new password (without any special characters).
Now you can login with your NEW PASSWORD that you have created.
Oct 08, 2014 | Home Security
How do i reset the password on my samsung dvr
There should be a master reset code in your manual.
Jul 09, 2014 | Samsung 4 Channel Dvr
How do i set the time on a cm7000pal manually?
If you do a Google search on 'Channel Master CM000 PAL manual it will take you to the manual which you can download. You setup the time, etc when running the 'The Wizard'.
Apr 15, 2014 | Channel Master CM7000PAL HD DVR
Cm7000pal dvr stuck in wizard on continue in searching for channels seams to load on hdd then goes to continue
I have 3 of these 7000pals and 2 have done a similar thing, one of them did it twice. After the Loading Channel Master screen hangs for a time, they would restart. Then the same cycle would keep repeating. It seems like after years of adding and deleting timers, the DVR's software gets "confused". I've noticed that twice it happened on the hour just as a program timer started while I was watching a program through the DVR. ZAP...Locked up! The power button would not even work to turn it off.
The steps below fixed all three instances of this failure.
To unlock the Channel Master CM7000PAL DVR:
1. Unplug the recorder from the wall outlet and DISCONNECT THE ANTENNA. Now plug it back into the wall power outlet.(This will keep the recorder from freezing and rebooting)
2. let it go thru it's normal bootup, tv guide search, etc.
3. When you are able to, hit MENU and then go up to TIMERS. Delete all of the record timers. Unplug it, reconnect the antenna, and plug it back in.
4. After a now a proper bootup, re-program you timers and you will be good to go.
5. And the best thing is, all of your pre-recorded shows will still be there on the hard drive.
I would suggest that you do a yearly "TIMER CLEAN" to avoid this trouble in the future.
Jan 22, 2014 | Channel Master CM7000PAL HD DVR
Reboots then shuts down again
I have 3 of these 7000pals and 2 have done this same thing, one of them did it twice. It seems like after years of adding and deleting timers, the DVR's software gets "confused". I've noticed twice it happened "on the hour" just as a program timer started while I was watching a program through the DVR. ZAP...Locked up! The power button would not even work to turn it off.
Oct 07, 2013 | Channel Master CM7000PAL HD DVR
The channel master locked up so I unplugged it. Now, when I plug it back in it just sits and says loading Chanel master tv but does not load. What should I do?
I have 3 of these 7000pals and 2 have done a similar thing, one of them did it twice. After the loading channel Master screen hangs for a time, they would restart. Then the same cycle would keep repeating. It seems like after years of adding and deleting timers, the DVR's software gets "confused". I've noticed twice it happened on the hour just as a program timer started while I was watching a program through the DVR. ZAP...Locked up! The power button would not even work to turn it off.
Sep 22, 2013 | Channel Master CM7000PAL HD DVR
My CM7000PAL unit only displays "Channel Master CM-7000PAL..... Loading. Please wait..." then turns off and then repeats the same message. I don't know how to fix this issue. Has anyone found a solution?
3. When you are able to, hit MENU and then go up to TIMERS. Delete all of the record timers. Unplug it, re-connect the antenna, and plug it back in.
I have 3 of these 7000pals and 2 have done this same thing, one of them did it twice. I would suggest that you do a yearly "TIMER CLEAN" to avoid this trouble in the future.
Aug 06, 2013 | Channel Master CM7000PAL HD DVR
CM7000 DVR keeps turning off and resetting when I try to enter My Recordings.
Feb 09, 2013 | Channel Master CM7000PAL
Channel master cm7000pal
Jun 29, 2012 | Channel Master CM7000PAL HD DVR
4 channel DVR L154-81
Does it recognize the hard drive? is the jumper on the back of the drive set on master? Jumper should be all the way to the left. Hard drive also has to be locked in the dvr for it to power up.
Jul 30, 2008 | Lorex L154-81
Televison & Video Logo
53 people viewed this question
Top Channel Master Televison & Video Experts
Peter Privates
Level 1 Expert
Are you a Channel Master Televison and Video Expert? Answer questions, earn points and help others
