Question about Vizio Televison & Video
Connecting Vizio sound bar to an Emerson LF501EM5F. I am using the optical cable from the audio out jack to the in on the bar and there is no sound.
  • 246 Answers
You have to set up the sound out to optical cable
Posted on Jan 03, 2017
Having problems connecting using RCA cables (TV to Sound Bar) - No sound on Sound Bar
I assume by using your phone (cable rca to mini jack) the sounbar functions normal. Next time give more info like tv and soundbar make and model no and what connections are available on both components and if its input or output connections.
On the tv make sure the rca cable (tv to soundbar) is plug into the stereo output of the tv and not in a av input. Some tv's have a mini jack out and not rca. Some have a earphone socket which could also be used.
Some tv's only have a digital or optical output port. Iin basic sound work and can be connected with the following combinations .
Minijack to minijack
Minijack to rca
rca to rca
digital to digital
optical to optical
Oct 26, 2015 | RCA Televison & Video
How dd I connect my soundbar to my TV using the red and white RCA plugs
Hello. On the back of your TV look for RCA Audio jacks marked "Audio Out". Connect the cables from that to the RCA Audio Input on your sound bar. If your TV doesn't have the RCA outputs, see if it has an optical output. Your sound bar probably has an Optical Audio input. You would need to buy an optical cable for that.
Aug 15, 2015 | RCA Televison & Video
Why is the sound on my new sound bar only going up half way?
Connect the sound bar to your cable box audio outputs--best way is optical. Then set the cable box volume to high and control the volume from the sound bar
Jan 12, 2015 | Craig Soundbar with Bluetooth
My sound bar does not want to work with my new 50 inch tv. Emerson model # LF501EM5F..any suggestions?
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Nov 30, 2014 | Emerson Televison & Video
We are trying to hook up a VIZIO sound bar model#S3820w-Co to our Vizio TV we also have Directv and a dvd player hook to this tv which wire do we hook from sound bar to Tv
If the TV and sound bar have an optical connector, then get the optical cable to connect the two. If not then use the audio out jacks on the TV and don't forget to change the audio set up to switch the sound to the sound bar.
Oct 29, 2014 | Televison & Video
Take it back to where you brought it from, End get your money back. End get a sound bar with a optical jack on it,
Oct 07, 2012 | Vizio High Definition Sound Bar
Need help connecting to surround sound to a vizio sound bar
did u mean connecting the sound bar to ur tv.
u didn't mentioned the model number of ur sound bar.
any how ur tv has only coaxial digital audio out. no analog audio out. the sound bar may have one digital audio input (optical digital input) and 2 analog inputs. if it has coaxial input it may be very easy.find is there, if not u cant link these devices.
if u are using a satellite receiver then u can connect the optical audio out to ur sound bar's optical input or the analog audio output to any one of the analog audio input.
Dec 18, 2010 | Emerson LC320EM9 32 in. LCD HDTV
I am attempting to attach a Samsung Sound Bar to my 42 inch LCD 1080P Polaroid Television. I can not seem to get sound from the Television connected to the Sound Bar. Thoughts?
Connect the audio out RCA jacks (white and red) on the TV to the white and red RCA input jacks on the sound bar for analog stereo sound or connect the black digital audio output jack (typically optical) on the TV rear panel to the sound bar's optical digital audio input jack for surround sound. Use an optical cable. There may be some user settings on the TV for audio.
Aug 12, 2010 | Polaroid FLM-4201 42 in. LCD Television
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
source from
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
Televison & Video Logo
77 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
