Question about Frigidaire Dishwashers
Frigidaire Dishwasher FGHD2433KF1 SELECTOR FOR CYCLES CHANGE BUT WILL NOT START WHEN PRESSING START ?
4 Suggested Answers
  • 4 Answers
SOURCE: Frigidaire Dishwasher FDB956RBC0
I successfully replaced the broken handle for my ELECTROLUX 24" Built-In DISHWASHER Model FDB956RB.
Try to check to make sure you reassembled all the parts and wire connectors properly.
Other than the broken handle, did you have other problems prior to replacing the handle/latch?
Posted on Nov 28, 2009
jumptrout51
  • 3361 Answers
SOURCE: My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Posted on Jul 17, 2010
dynastygrani
  • 21 Answers
SOURCE: frigidaire dishwasher model fghd2433kf1 keeps restarting after a few minutes
rlindaur179,There are a couple possible issues. We will start with the easy ones first.
1. There is a round shape float on the inside floor of the dishwasher.On this mode I believe it is in the front left. please check to see this float moves easily up and down. If there is any build up it could getting stuck in the upright position this can cause a reset in the cycle. Clean the float shaft. Lift float and clean shaft (steel wool works well)2. Replace control board
Hope this helpsJoe Connolly
Posted on Nov 13, 2011
Frigidaire dishwasher Model #fghd2433kf1 flashing light with Error 'S'. Dishwasher will not start. I was able to restart it last time this happen by disconnecting power and then pres
Thank you for your post, Cathie Sanchez!
I understand that your Frigidaire dishwasher is displaying error code "S" and will not restart. The error code "S" usually stands for sanitize, this could also be a miscommunication within the control panel. I would recommend performing a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for roughly ten minutes. If you continue to experience issues with the error code I would suggest having a professional technician out for proper diagnosis and repair. Hope this is helpful. -Matt
Jan 07, 2015 | Frigidaire Dishwashers
Fghd2433kf1 shows an s next to time what does this mean?
Hello friend, thank you for your post!
From my understanding the "S" stands for sanitize within your Frigidaire dishwasher. I hope this is helpful. If you have any additional questions please feel free to reconnect. -Matt
Oct 09, 2014 | Frigidaire Dishwashers
FGHD2433KF1 err eu
Good Afternoon Stacy,
I see that you are having trouble with your Frigidaire dishwasher, model# FGHD2433KF1, showing an error EU. I also see that you have had a technician out who stated that there was no vent inside the unit. I would start by contacting the manufacturer, to see if you are in warranty, and if not, if there is any assistance they can provide to you. Hope this is helpful.
-Best Regards-
WP
Apr 22, 2014 | Frigidaire 24 in. PLD3465REC Stainless...
Frigidaire dishwasher fdb1100 starts then stops
Hello - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may also prevent the unit to start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Dec 08, 2012 | Frigidaire Dishwashers
Frigidaire dishwasher fdb 750 stops during cycle
Dec 05, 2012 | Frigidaire 24 in. FDB510LC Free-standing...
Door latch not working on Frigidaire 18 in.
Hi -
The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Oct 21, 2012 | Frigidaire 18 in. FDR252RB Built-in...
Frigidaire dishwasher model fghd2433kf1 keeps restarting after a few minutes
Nov 09, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
Our 2 month old Frigidaire FGHD2433KF1 dishwasher is producing a very strong foul odor. It is not connected to a garbage disposal and we only see a small amount of water in the bottom of tub when the...
Do you have it connected to an air gap? If not this can allow the water to drain back into the dishwasher and will sometimes have food particles in it making it stink.
Oct 23, 2010 | Dishwashers
Re-connect power.
Jul 17, 2010 | Frigidaire Dishwashers
Dishwashers Logo
47 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
