I have a bravos washer with problems.
When we set the washer to wash a little of water goes in not even enough to cover the clothes, washes for a couple of mintues and drains then stops.
  • 1952 Answers
SOURCE: washer will not drain water or go into rinse and spin cycle
First thin I would try is to check your thermal fuse for continuity. Its located on the tunnel that incases the heasting element.
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
You also want to check the drain hose, the end of the hose is tapperd and tends to collect lint. Run a coat hanger up the hose and see if you can fish something out also check that belt.
Posted on Oct 06, 2008
SOURCE: Kenmore washer not draining water
check for defective lid switch or switch just out of adjustment.
Posted on Jan 16, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Washer is turning my white clothes gray
Oil from transmission is a good possibility. The machine is still young but sounds like you do a lot with the washer. Better have a friend that don't mind looking it over, make sure that's oil and go from there!
Posted on Feb 02, 2009
  • 240 Answers
SOURCE: Whirpool Cabio washer knots clothes/sheets into tight balls
whirlpool had a service bulletin on this. New agitator design. replace with new design.
Posted on Mar 14, 2009
  • 5911 Answers
SOURCE: washer fills with water but wont drain
Check your lid switch. If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at,,, Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
NOTE: Some washer models have the lid switch located near either the left or right hinge of the lid. This type of switch is activated by a rod on the hinge pin. If not functioning, it can often be adjusted by bending the hinge rod until it engages the switch.
If you have any questions, please let me know. I hope this helps you.
PS You do not have to drain the washer to complete this repair. Once the switch is replaced the washer will drain on its own. This may save you the need to bail water again.
Posted on Jul 20, 2009
Why is the washer slowly leaking water into the back of tub between washes?
There is grit in the water valve holding it open just enough to allow the water to seep by. You should get a filter system for your washer and replace the water valve, Grit is not covered by most warranties.
Mar 13, 2016 | Maytag Bravos XL 4.6 cu. ft....
There is only enough water to cover the clothes in the washer on the wash cycle, is this normal
Hi Judy, This is quite normal for modern machines. It's an eco friendly thing.
Jul 12, 2015 | Washing Machines
Maytag top loader washer unbalaced during spin cycle
check your load -- not enough clothes in it - too little heavy ones
Jan 13, 2014 | Maytag Bravos MTW6600T Top Load Washer
Maytag bravos doesn't use enough water
see this causes and fix it.
God bless you
Water comes in very slow This is usually a water valve problem or an inlet screen blocked. 1st check your inlet screens of your water valve. Turn your house water valve off to the washer, undo the fill hoses and inside the water valve, you will see a silver screen. If the screen is filled with water deposits, clean it out and re-install into valve. Don't forget to check your fill hoses also, some hoses come with screens that also may be clogged. Your cold water valve usually clogs before the hot water valve, all that sediment settles in your hot water tank and not in the screens. If you are on a well system, your screens usually clog more often. If your screens are good, then most likely your water valve needs replacing.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
Not enough water stays in machine to cover clothes We know this is an econosaver but wife likes to saok whites in total water Tried adding water by the bucket while washer is stopped but it automatically...
Hello, Thank You for using FixYa. I will be helping you today.There is no way to change the water level. It washes by spraying the water over the cloths as it moves around.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
Maytag Bravo washers is staining my cloths.......any thoughts on what may be causing this?
the upper transmission seals bad its under the tub agitator and letting oil into the water called "wash back" you need to replace this seal and stains will disappear
Apr 06, 2011 | Maytag Bravos MTW6600T Top Load Washer
Water level in washer
The basket floats. The washer relies on a circulation pump to wash the clothes. THEORY OF OPERATION PAGE 22
let me know
May 08, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
No water?
Calypso's use very little water. The only way to change how much goes in is by the pressure switch located in the console. It tells the machine when to stop filling. A replacment is availible from a local appliance parts provider or online from the manufactures web site. But I can tell you from experience, when you fill one of these machines without a load of laundry inside, it won't even cover the top of the bottom plate. Even with clothes in it, there is still not very much that will go in. More water will be added durring the course of the cycle as the clothes absorb the water (there is less pressure going to the switch and it tells it to fill again). But again, the pressure switch determines how much water goes in. You can access it by removing the 1/4" screws in the back of the console. It is the white circle with the clear tube going to it. Yes, there are 2 that look almost identical. One is for incoming water level and 1 is for recirculation water. The matching part number will be stamped on top of the one you are replacing. Just remove the wire connector, pull the clear tube off, and press the tab while rotating the switch assembly. It will come right out. Instalation is just the reverse.
Jul 11, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
