Why does 16.9 not show on remote - Televison & Video
Why is my circuit board showing KO when trying to add new remotes
It means that it has not programmed your new remote ie not compatable with your system or damaged hope this helps
Mar 03, 2016 | BFT R93524500001 - Swing Gate Kit, Single,...
Cannot set correct temperature with remote
the 16 on remote is the set temperature not the room temperature.
Jan 25, 2014 | Heating & Cooling
What universal remote will work for AXION 16-3350?
Here is a link to a replacement remote for you:
http://remotes.com/remotes/servlet/rs?a=gmi&smodel=16-3350FLAT&uuid=A12731975097341&brand_pn=AXION_16-3350FLAT
Apr 15, 2010 | Axion 16-3350 LCD TV
Picture not on whole screen
have you another disc?
some movies are formatted.try to press set-up button on your dvd remote.choose video or tv types.it shows letter box or LB, pan and scan , and 16/9 for widescreen
May 07, 2009 | Philips DVP5990 DVD Player
Thomson DT!6300-16 has stopped working
Usually to fix most odd problems on the Thomson digi box you should do a hard disk format every couple of months, select menu, setup, help,
press green button on remote
this shows advanced menu, press blue button, warning should show,
press green button to proceed
takes about 2mins you lose all recorded programs
If the problem is the box stays at red, and won't switch on,
pull the mains plug wait a few secs then push and hold the the standby
button on the main box (not remote) then insert mains plug, as soon as the
red light flashes release the standby button and very quickly press
menu and OK in that order, don't hang about, it has to be done very quickly
I had to do it several times before I got it right, this loads a preloaded firmware
and the box will come alive again the box will upload new firmware in a couple of hours.
good luck from Ron.........
Dec 04, 2008 | DTK PRM-0031I Motherboard
Aspect ratio
push setup on remote. go to video, select "16:9".
i was looking for a way to get rid of zoom logo from screen and decided to select 16:9 instead of 4:3 in setup. hope this helps
Oct 30, 2008 | Cyberhome CH-DVD 300 DVD Player
Sony DVD Home Theater System remote control code
I have the same system and one of my dogs got to the remote. I have a philips PMDVR8/PDVR8 universal remote. I was able to get the dav-hdx265 to turn on/off and do volume up and down by using code 0200. I have not been able to get the DVD functionality to work yet, but I will post if I do.
Oct 22, 2008 | Sony DAVHDX265 System
Remote Control Control Codes
has anyone solved this problem???
Jan 13, 2008 | Audio Players & Recorders
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
