Question about Refrigerators
Cannot get back of panel of in fridge to get to the drip hole I have water under vegetable trays
    Top Expert:
  • Refrigerators Master
  • 34,124 Answers
The drain may be inside at rear
Posted on Jan 01, 2017
zeusfaber
  • 247 Answers
SOURCE: fridge bottom has water under vegetable drawers
Make sure the door is closing properly, that nothing is trapped in the door seal, and that the seal isn't torn or distorted. The seals are there to stop moist external air getting in then dropping its load of moisture as it cools. A.
Posted on May 16, 2007
mreid542
  • 166 Answers
SOURCE: it leaks water onto the floor.
Where is the water coming from? unless you have a leaking ice maker fitting on the back or somewhere else, the most likely cause would be a stopped up defrost drain. check inside the freezer on the back wall and floor. if you see ice you will need to unstop the drain. (most newer models don't have a removable drain pan)
Posted on Nov 20, 2008
  • 198 Answers
SOURCE: water under vegetable bins, no water in drip pan under refrigerat
If this is a top mounted freezer the drain under the evaporator in the freezer section is iced up. You will need to take the back panel in the freezer off, to get to the evap. Defrost the ice with boiling water, then a heat probe will need to be attached to the defrost heater and down through the drain hole, There is a kit for this procedure.part # 819043
Posted on Jan 27, 2009
SOURCE: bosch fridge leaking water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have the same problem,warranty just ran out but its been leaking on and off for ages,must be this model.This much Ive figured out,what happens is the drain hole gets blocked from ice freezing over the hole at the back of freezer, the drain water has to go somewhere, since it cant leak out of the drain hole where it suppose to it ends up pooling under the vege compartment before ending up on the kitchen floor.Now if this is your only problem,someone suggested to me to run a piece of copper wire from the defrost heater to the drain hole so no ice can build up there,hence no more leakage.To do this you'll have to take the back panel off and see for yourself,I did this and Im a novice.Make sure you turn off and unplug the fridge first and wait for it to defrost.
Now I think I have other things wrong with mine,after leakage problem the refrigeration compartment wont cool anymore but the freezer part remains working as usual.Ive nailed this down to one of the following not working... Thermostat / timer / defrost heater.So one or more of these needs replacing.Im just trying to look for a manual which shows the nuts and bolts or the refrigerator (not the "How to use" type manual which I have).
Posted on Apr 05, 2009
  • 744 Answers
SOURCE: Whirlpool Fridge makes a loud dripping sound all the time G56SHE
Erin,
The water you hear sounds like it's coming from the automatic defroster in the freezer compartment. It runs down a drain tube into the pan you describe under the fridge. The pan is heated and evaporates the water.
Just some possible explanations if you are hearing "lots" of water"
* You may be in a warmer, more humid climate
* The temperature and humidity in your dwelling is elevated
* The door gasket on the freezer may be leaking
* The freezer is too full
* The freezer door is not closing properly
* The freezer door is being left open for extended periods
* There is a problem with the defrost cycle
If you are hearing water running all the time, check the ice maker water line and fill valve (if you have an ice maker) - there could be a leak or other malfunction.
Posted on Apr 15, 2009
Where can I access the defrost drain hole in my Kenmore model 253.74879404 Refrigerator? Disassembling the freezer did not work.
I've used used a compressor for that drain hole at the back of the fridge. A hanger wire will work too. I've never tried it but maybe a can of compressed air might work also.
The water drain line is plugged and that little catch tray is overflowing. That's why you're ending up with water under your bins inside the fridge. The problem is not in the freezer or else you'd have a skating rink on the floor of the freezer.
I don't recognize the photos exactly but they're all the same principle. Take everything out of the fridge , including the racks. It's far easier than o find the screws and disassemble the drain "catchall".
Good luck.
Dec 18, 2014 | Kenmore Refrigerators
Tip
Water Leaking Inside Refrigerator
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself. My 26 year old fridge was leaking
and I fixed it completely. It is a Kenmore
top freezer, bottom refrigerator model.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assembly, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
With lot of patience (I mean lots of it) you should be saving hundreds
of dollars. Attached are some pictures I took. Call me before you dig !
on Mar 01, 2010 | Refrigerators
Why my fridge is leaking water under the vegetables tray ?
at the back of the veg tray there should be a small drain hole , it may be blocked
Aug 27, 2014 | Refrigerators
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
it yourself.
To get to the connector assemble, you need to unscrew and
the light bulb fixture. Once you take the take the cover off (you will
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Hi, I have a 2003 Kenmore Coldspot refrigerator. It has started leaking water on the inside from the top(where cold air blows) into the bottom of the fridge. the model # is 106. 73192302. The serial # is...
Hope this helpout.......
Jul 29, 2010 | Refrigerators
Leaking water inside refrigerator thru openings
The defrost drain tube is clogged located in the freezer section behind the freezer back wall. use hair dryer and hot hot water to clear this tube.
Jul 05, 2010 | Refrigerators
I have a model ET8CHKXKQ0 1 Whirlpool refrigerator and it keeps collecting water in the meat tray, the vegetable tray and under both vegetable trays. I have vaccumed under the frig., in the back and...
The drain in the freezer is clogging. When the defrost switches on, the backed-up ice thaws and starts dripping down into the fridge area.
Easiest is probably to turn off the fridge, let it thaw, then check the freezer drain to see if you can unclog it.
Otherwise, you have to pull out the bottom and back parts in the freezer (which will probably have some sort of ice frozen to them). Once you see the drain pan, get a turkey baster and flat head screw driver. You'll have to make a hole in the ice above the drain and squirt hot water until you hear it start draining. The drain hole is off center to the right in the drain pan.
Good luck
Mar 23, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ive had my westinghouse moist cold 421 for quite a few years and lately there has been at times water leaking at the inside under the vegetable cripsers . I'm unable to find my user manual but I recall...
The drip tray is all the way at the bottom.Pull of the grill at the bottom of the refrig,tray should be there.
Also there is a hole or tube under your crispers,check that its clear and not clogged with junk.
Jan 20, 2010 | Westinghouse Refrigerators
Water under vegetable bins, no water in drip pan under refrigerat
Jan 27, 2009 | Kenmore Refrigerators
Water Is accumulating at the bottom of my fridge....below the vegetable/fruit crispers. The fridge however contiues to keep things cold.
The automatic defroster is supposed to drip down a tube and deposit water into a tray underneath the refrigerator. If that tube becomes clogged with either ice or mold, water is supposed to drip down the back of the refrigerator and go under the crispers, but there is a drain under there that takes it to the tray under the refrigerator. That drain might get clogged with mold or food.
So my suggestion is, try to clear out the drains under the crispers. More difficult, remove the floor of the freezing compartment and clear out the drain there. If it is severely clogged with ice under there, you have a defrosting problem.
In this hot, muggy weather you are likely to get lots of condensation. Good luck.
Jun 13, 2008 | Whirlpool Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
