Question about Vacuums
How do I repair Hoover Windtunnel floor/carpet switch? Brush will not turn but belt is not broken. I believe setting was hard floors and son forced the switch when the vaccuum was running.
  • yadayada
    yadayada Dec 31, 2016
    Do you have the new switch.
  • Vacuums Master
  • 1,417 Answers
The lever that switches from carpet to hard floors may be broken if it was forced, remove the cover to gain access. Replace both belts too. They may be stretched or worn even though they look good.
Posted on Jan 03, 2017
I replace both belts on my hoover windtunnel and the small belt has no tention why.
Be sure the selector switch is set to carpet and not "floor" would be the easiest thing to check first.
Sep 17, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
How to repair windtunnel hoover agitator that will not turn
Likely a broken belt. Also check the agitator brush roll bearings (in either end under the end caps) for hair, strong, thread, etc. as this will make the brush roll harder to turn and wear/break belts prematurely. If all these check okay, then observe the tensioning roller that causes the V belt (runs from the idler pulley to the brush roller) to be sure it is swinging down when the handle is released to hold tension on the belt, causing it to rotate. These tensioning rollers can break, but often are locked into the "Bare Floor" setting without the user noticing. Slide the carpet brush roll selector (located on top, next to the floor height slide adjustment) back and forth and make certain it is all the way into the "Carpet" setting to allow the tensioning roller to engage. [Note: The tensioning roller is always retracted (in the neutral or off position) when the handle is in the upright position. You must release the handle to allow this tensioing assembly to engage.]
Sep 05, 2014 | Hoover Model U6485900 Upright Vacuum...
Hoover U6630-900 Self Propelled WindTunnel Bagless Vacuum - Stuck on "Brush Roll OFF"
You may have to do some disassembly to gain access to the mechanism but you will find it's a rather primitive arrangement that tends to fail over time. If no broken parts are found, some experimental testing will reveal what has to be repaired or adjusted to restore normal operation.Be sure to test "switch" movement as you reassemble to detect binding caused by tightening hardware.
May 08, 2014 | Hoover Vacuums
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Carpet/Floor Switch problem on Hoover WindTunnel Vacuum
Well, you have to deal with it, you have to play with this electrical things if you want to fix this problems.
The good news is, the sources of the problems is the switch already broken.The first things before you do anything is, find this switch on the market first to changes the old ones.Then, remove the power cord from the outlet of course.
After have it, then you must open the old switch, and remove it from the unit by cutting the cables using cutter/ pliers or anything.But remember, you must remember the locations of each cable that been cut, you can use Camera Cellphone to make sure of it if you like.
Then put the cables back together with the new switch, after all done, clean all the mess and try operate it.
Hope it works!!!
Dec 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
How is the V-belt tension adjusted (Hoover Model U6439-900)or how do I know if the tension is correct? There seems to be a lot of "play" in the belt and I'm wondering if that is the reason the brush roll...
The V-Belt is not adjustable. There are two ways the belt has no tension: (1) when the handle is upright, a mechanical lever takes the drive tension off the belt, and (2) the brush roll lever setting you described. The upper handle would have to be in the floor cleaning position to check the belt, not in the storage position.
Oct 07, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover 5470-900 no longer contacts carpet with beater brush
your floor adjustment spring is broken there is a plastic slider and clip if it is broken the height adj will not work you should get a new vacuum because this repair can cost as much as a new vac.also this is a common problem with the hoover brand I would get a sebo or an oreck they have a great warrentty and you will more than likly never buy a other vac.
Jan 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
I got new belts but the brush wont turn
Make sure the vacuum is on the carpet setting..the brush won't turn on the hard floor setting..
Dec 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel carpet level adjustment
The suction is so great that it sucks up your carpet, then nothing works. I get my children to stand on the corners/edges of the rug so that it stays perfectly flat on the floor while I vacuum. Or, you can turn off the brush roller (set it to "hard floor" setting). Or, tip the vacuum cleaner's front up slightly while vacuuming, to reduce suction.
Oct 28, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
