Question about Exercise & Fitness
Dashboard lights up but running bed won't go.Could it be anything to do with re set button which sticks out and doesn't seem to re set?
  • 6,694 Answers
If you wish to get some details about treadmill repair ; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Posted on Jan 01, 2017
    Novelist:
  • 144 Answers
Hi There, Make and Model of treadmill? Sounds like a lower control board issue?
Posted on Jan 03, 2017
My Beko MW5104 is frozen and does not respond to any settings. It is permanently on at spin/end with the green light on. I can switch it on and off. I have unplugged it from the mains and switched it off...
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
No control panel lights on Bosch SGV43A03GB/17 diswasher
i have nearly the same problem ! but my one have no water left in it !but pump still running if i put bucket of water in it will drain it away but no lights on panel and anyone know what that is please ?
May 14, 2012 | Bosch 24 in. SGV43A03 Built-In Dishwasher
Warning light on my car dashboard won't go off
The light doesn't go out after you top up the air pressure in the tyres.There is a reset button, that you should press, and that will reset the tyre pressure
Usually it is in between the front seats, about where the handbreak is.
Find the button, press it and hold it down for a couple of seconds, and that will make the warning light go off.
May 08, 2012 | Skoda Roomster Cars & Trucks
My Shuttle Barebone K48 will not even power on.
Try to run it with only one stick of memory in at a time. If the memory doesn't work the computer won't even go into the POST. It only takes one failed stick to stop a computer.
Mar 07, 2012 | Shuttle KPC K48 Barebone
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
I have a husqvarna viking 5610 and it was an auction find. The reverse button doesn't work at all. It won't go in or anything. I've looked inside the back and it doesn't appear that...
Try setting the machine in direct sunlight with the back cover off and let it get nice and warm. It might even need a little assistance from a hair drier. Warm the area directly behind the reverse button. If you can get it to move a little, you will see which parts are moving. Use Tri-Flow on these parts and they may come loose without having to take it in for service. DO NOT USE WD-40 or 3-IN-1 oil. Go to a bicycle shop and get a small bottle of Tri-Flow liquid.If that won't work, any authorized Husqvarna Viking repair center should be able to take care of it for you. Don't force anything too hard. If you break anything, you may not be able to find parts as they are no longer available from the manufacturer.
Sep 09, 2011 | Husqvarna Viking 1
Frigidaire FDB710LCS0 Dishwasher dial seems to stick?
I had the same problem. Turn the HIGH TEMP buttons off. Simply turning them off corrected this problem for me. Mine got stuck in two places and I had to manually turn the dials or the washer would run all night.
Nov 21, 2008 | Dishwashers
Exercise & Fitness Logo
42 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
