Question about Kitchen Ranges
Want to replace the knobs on Tappan converta cook....89-9201...89-9211...KTM 8983 or KTM 8984.....electric stove
SolutionGuy
  • 331 Answers
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
  • 145 Answers
SOURCE: burners and oven not heating tappan range 560s111po1
You need to check the connection at the back of the unit that hooks to the house power. Turn off breakers or pull fuses before checking. It sounds like you only have half of the voltage you need. One of the wire connectors may be burnt or you may have a problem with the house wiring.
Posted on Apr 23, 2008
SOURCE: tappan gas stove
I had the same problem, and finally took the rings and the covers off of the burners. I used an old toothbrush to clean everything really good, and then used a vacuum ( or you can just close your eyes and blow really hard ) around the burners. If there is a build up of junk or if a pot has ever boiled over, sometimes junk can get lodged in the little igniter and this prevents it from lighting.
Posted on Jun 14, 2008
  • 409 Answers
SOURCE: Gas Stove
sounds like the spark module is trying to relight the electrodes again. it could just be the electrodes. is it on all the elements?
Posted on Sep 13, 2008
breddi2
  • 126 Answers
SOURCE: Tappan electric range, brand new - top heats up
Call the manufacturer and ask them what to do, they can advise you as to what to expect when unit operates and possible cause. Most ranges on broiler will have some heat transfer to top, but this sounds extreme
Posted on Apr 26, 2009
Tappan gas stove
Older gas stoves used a battery to ignite the flame but due to its age, I would get a hand held gas lighter.
Apr 21, 2017 | Kitchen Ranges
Tappan oven "turns on" by "itself" ??? Control
I cannot solve this problem yet. We have the same problem. However in ours if we turn the temperature know to off (the other knob is set to off - time bake, bake, broil, clean, etc - set to off) then it will not run. Somehow that temperature knob with the electrical control is making it turn on. Ours started to do this on the same day!
Apr 16, 2011 | Kitchen Ranges
Does this tappan stove require a hood for ventilation? The one I have is intalled in the center island of the kitchen.
You don't have to have a hood over a stove. If you do though it removes all steam and odours. The grill also catches all the cooking fats. Your kitchen will stay a lot cleaner if you have one.
Feb 11, 2011 | Tappan 30IN ELEC IGNa Oven
I have a tappan self cleaning oven KMT-2893-87A
call Sears for they took over Montgomery Wards services and we have the same stove
Feb 03, 2010 | Tappan Kitchen Ranges
Trying to bypass electrical ignition on oven to
Hi, the gas valves on modern ovens are electrical and cannot be turned on without electricity. Only the cook top burners can be lit manually.
Jan 29, 2010 | Tappan Kitchen Ranges
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Range burners
There must be a problem in one of the switches which is behind one of the knobs. Will have to check each switch with a meter.
Oct 03, 2007 | Tappan TGFS_63 Gas Kitchen Range
Tappan Gas stove
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan TGF336ASD stove Calibration of the oven
does it have a knob in front or is it a panel to operate bake broil ? if it has a oven knob take it off and look in the back of the knob you adjust it there if it is electric if it is gas you need to use a small screw driver in the stem where the knob goes on and turn a little screw in there to ajust temperture turn clockwize to adjust temp up
Aug 13, 2007 | Tappan TGFS_63 Gas Kitchen Range
Kitchen Ranges Logo
133 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
