Question about Home Security
Where are the 2 locking mechanism plates on sports afield safe
48 gun
User manual for sports afield safe
need a model #...
find the product here and you can download the manuel......
http://saproducts.com/
Jan 06, 2018 | Home Security
I have a sports afield gun safe but do not have the codes ,the safe is open
There is normally a button to reset the codes. It is good you have it open. Contact the maker direct by phone.
Contact Sports Afield Gun Safes
Dec 13, 2017 | Locks & Locksmithing
If there is a power failure will my Sports Afield safe still open?
don't know try putting in the model and numbers so we can help do a search for you
Oct 10, 2017 | Power Home Security
What I need to know before buying a gun safe?
First you need to decide how big enough your safe should be and also choose the style of your choice. Next, you have to check the locking mechanism and also fire rating. For best gun safes, please visit Guardwell Lock & Safes in Dublin
Sep 30, 2016 | Locks & Locksmithing
GETTING IN A SAFE
You really have no choice but to break in or call a locksmith.
Sep 23, 2016 | Liberty FatBoy Jr. LFJ48 48-Gun Safe,...
Sports afield 6040 executive vault how to reset combination
Spot Afield safes default code is 1,2,3,4,5,6. Open the safe door, with door open lock the handle. This will let you have assess to your things if you have trouble while setting the codes. To change the code, press the * 6 times. You should hear a single beep and one flash from the LED, then enter the default code 1,2,3,4,5,6. Again you should hear one beep and see one flash. Enter the new code you would like to use ...lets say 6,5,4,3,2,1. You should hear one beep and see one flash. Enter the new code again 6,5,4,3,2,1. The code should now be set to 6,5,4,3,2,1. Try the new code and see if it unlocks the door. Also try the old code to make sure it no longer works.. If at any time during the process you hear 3 beeps and flashes something went wrong. You will need to start over.
Good Luck!!
Jun 30, 2014 | Other Sports Afield Executive Gun Safe...
Can't turn off beep sound on keypad of my stack-on Security Safes Electronic Lock for a 16 gun safe
You can turn off the "Beep" sound of the keypad by entering the code 633.
To turn the "Beep" sound on, enter the code 66
Feb 17, 2013 | Stack-On Stack On 16 Gun Safe with...
I need a manuel for stack on gun safe
http://www.stack-on.com/pages/instruction-sheets
Dec 19, 2012 | Stack-On Stack On 16 Gun Safe with...
Gun safe key lost
you csn get nfor from safe company that made it.. or just spend money on a lock smith....
May 24, 2012 | Stack-On Stack On 16 Gun Safe with...
ACCIDENTLY LOST COMBINATION FOR DIGITAL SAFE , HAVE TO USE KEY
Take off front plate key will open, reset with default 159a should help
Sep 28, 2009 | Safe International Digital Electronic Safe...
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
