Question about Cell Phones
At the moment my telephone is ringing twice then cutting to voice mail. How can I make the rings more. Thanks
  • Cell Phones Master
  • 805 Answers
Customize ur ring settings and select ring "ringing". then active the profile
Posted on Jul 21, 2009
How do I increase number of rings on CL2909 ATT phone
The CL2909 does not have an answering system. Thus the number of rings will depend on the caller's patience or your voice mail service. You need to check with your telephone provider to find the procedure to change the number of rings before your voice mail system answers the call. You'll have to get into the voice mail system and then access those options.
AT&T has the manual for the CL2909 on the product page: https://telephones.att.com/pd/290/CL2909-Speakerphone-with-caller-ID-call-waiting . The direct link to the manual is currently https://cdn-media-att.vtp-media.com/products/CL/CL2909/CL2909_CIB_i14.0_20170210.pdf .
I hope this helps. If you add a comment with your telephone provider, I may be able to find a guide to their voice mail system settings.
Jul 26, 2017 | Lands Phones
GE phone model 29581 does not seem to have instructions for resetting voice mail ...my phone just keeps ringing and won't go into voice mail
Voice Mail is not a function or feature of any telephone set,
nor does the GE 29581 phone have an Answering Machine
System that might be confused with Voice Mail.
VoiceMail is an option offered by some (not all) Telephone
Service Providers. Check with your Telephone Service
Provider to learn how to go about using theirs if it's available.
The original GE 29581 phone User's Manual is available at: http://www.manualslib.com/download/59417/Ge-29581.html
Mar 18, 2016 | GE Lands Phones
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
Fax won't answer
If you have an answering machine connected to the same line as your fax:
If you have a voicemail feature associated to the same line as your fax:
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
Ring back on 18D
If you have enough voicemail boxes go to ext 10 or 11
Press feature 00
Left intercom twice
#310
enter extension number
press 1 to assign
Feature 00
Jan 16, 2009 | Avaya Corded Phone avaparp18d
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Voice mail recording for my new panasonic digital phone
For voice mail service subscribers
If you subscribe to a flat-rate service
package that includes Caller ID, call
waiting, voice mail, and unlimited
local/regional/long distance calls, please
note the following:
L To use the voice mail service provided
by your service provider/telephone
company rather than the unit's
answering system, turn off the
answering system (page 30).
L To use this unit's answering system
rather than the voice mail service
provided by your service provider/
telephone company, please contact
company to deactivate your voice mail
service.
If your service provider/telephone
company cannot do this:
- Set this unit's "Ring count"
setting so that this unit's answering
system answers calls before the
voice mail service of your service
provider/telephone company does.
It is necessary to check the number
of rings required to activate the
voice mail service provided by your
company before changing this
setting.
- Change the number of rings of the
voice mail service so that the
answering system can answer the
call first. To do so, contact your
company.
Jan 13, 2018 | Panasonic KX-TG4322B Twin Cordless Phone
Alcatel 630 telephone
The phone rings once or twice but then it stops ringing despite the fact that there is still a ringing tone on the caller's phone.
Furthermore, the answering machine does not take the message as it does not click into answering mode. Any messages are left on the automated voice mail.
Thanks
Aug 28, 2008 | Alcatel Lands Phones
Same Number for Fax and Telephone
The fax is designed for use with an answering machine, the greeting for which must be no longer than 15 seconds. If voice mail in this case is referring to answering machine, be certain that the message is as indicated.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Mar 29, 2008 | Canon FAX-JX200
Cell Phones Logo
47 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
