Question about Vacuums
Intex inflatable bubble spa getting E90 code- air lock in system?
Filters are clean
Smells hot when running and will not pick up debris I recently cleaned all filters
Something is stuck in the piping system. The passing vacuum air is used to cool the motor. It's not getting that air so it will start to over heat and smell
Jan 09, 2014 | Eureka Surfacemax 200 Bagless Upright...
Can anyone help with an older Euro Pro EP055, It has very little suction.
Cleaning filters on a bagless vacuum helps but filters should be replaced frequently, as often as every 3 to 6 months on some vacuums. Foam filters aren't as critical to replace because the pores are very large (which also means they don't filter out the small particles) so they don't clog as easily but paper filters have much tighter pores which become clogged and restrict the airflow. Cleaning paper style filters with water which can pack the fine dust into the pores clogging the airflow even more.
I recommend replacing filters st least onceor twice per year and cleaning them after each use for best performance and longer vacuum life. Blowing the dust out with an air compressor is my preferred method.
Changing filters frequently on a bagged vacuum isn't as critical because the bag collects most of the fine dust, dirt and gunk. The surface area of a bag is much greater than that of a filter so a bag is less likely to get clogged than a filter. Most homeowners change the bag once per month which keeps the air flowing smoothly.
Sep 30, 2017 | Euro-Pro EP055 Bagged Canister Vacuum
Bionaire humidifier model:bcm7309cm How to clean the air filters?
"You should change your furnace filter once a month in the winter season and your central air filter once a month during summer months.
If you run your heat or air every day and night, have pets, or your home collects a large amount of dust, you may need to change your filter more often during very hot and very cold months.
If you use disposable filters, it's really not worth vacuuming them to reuse them. They are inexpensive enough that you should replace them instead.
Disposable filters don't work as well after only being vacuumed and they are usually in a cardboard frame and therefore don't wash well.
Before you take out the filter, however, vacuum the outside and around the filter encasement. After you remove the filter, you should vacuum behind it, too, to catch any stray dust and particles.
Replace disposable filters with new ones."
(http://www.mrscleanusa.com/en/cleaning-tips/tip/cleaning-air-filters.html)
Mar 03, 2011 | Vacuums
Oreck XL21 just will not work at all any more. Beater is clean - belt is fine. Fresh bag - inflates. Took the thing apart - checked for blockages at intake, bag entry, and the tube. It just doesn't...
Did you make sure the brush turns freely? Even though it is clean, if it does not turn freely with the belt, it will not beat the carpet and pull debris up into the unit.
Another (drastic?) thing to try would be to take the unit outside into your driveway and using a small source of smoke, a cigarette, etc, let the vacuum **** up the smoke and see if it exits anywhere other than through the bag. If it does, there is obviously a leak someplace in the unit that needs to be fixed.
Oct 01, 2010 | Vacuums
Andorra collection, withcommand system 2000 wall control. Light will not turn off by light switch, when light switch is depress light blinks is it the wall switch or the light?
I searched under the following search terms and did not find it on the Internet:
'andorra collection withcommand system 2000 light control'
and found:
http://www.elecdir.com/site/store/16263/index.html (directory of home automation)
http://www.homeclick.com/web/catalog/product_detail.aspx?pid=224370 (home spa with air bubble pumps)
If searched under '2000 wall control'
I get the following:
http://www.csnlighting.com/Craftmade-UC-2000-3-fd7760.html
I cannot find the exact product you refer to, but are there any typos or misspellings? How long ago did you buy this product? I am not sure how to support without more specific information. Is the company still in business?
Jul 21, 2010 | Vacuums
Vacume overheats and shuts down I replaced the motor.When it cools down it runs again.
The filters had to be cleaned out with air.
I replaced the motor for nothing.There are two filters and the cannister give them good cleanings with an air gun.
Jun 03, 2009 | Kenmore Vacuums
Vacuum cleaner filters
Sponge filters should be washable. I have found that "FLASH" lemon floor cleaner is by far the best, but washing up detergent will do (far too many bubbles to get rid of for my liking!). I find pouring the detergent onto the sponge and working it in before dunking it in very warm water works best. Despite not being very washable, most paper filters can be washed if you have no other choice and you take care. Just pour on cleaner and then dunk up and down in hot water. Then leave in the airing cupboard for a couple of days to dry. It should get you by until you can find somewhere to buy a new paper filter.
Jan 23, 2009 | Vacuums
Motor runs fine and hosed not clogged will not pickup dirt
Check your fan for damaged or worn blades, then following the flow towards the bag check for blockage. Does your bag inflate when the vacuum is on? If so, it is less likely that you have blockage, than it is that there is an issue with the fan.
Jan 19, 2009 | Eureka Vacuums
Dirt Devil Purpose for Pets suddenly stopped vacuuming, totally cutting off. Checked plug and outlet for problems which were negative.
I had this same problem. All of a sudden it shuts off while vacuuming and then i'd have to wait a while before it would turn back on. Finally it stopped working period. Before going out to buy a new vacuum, I decided to take the thing apart and clean it up really good. That included running a clothes hanger through the tubes to get all the stuck hair out, removing the roller and getting all the hair untangled from it, and rinsing out the air filters (both the sponge and the plastic piece with the paper like filter) with hot water. Then you let the filters dry for a day or two. The plastic/paper filter takes longer to dry so I used a hair dryer. The vacuum itself is not hard to take apart. I think there are only 11 total screws you need to take out. After the filters dried I put them back in the newly cleaned vacuum and it worked like new. I think the main problem was the condition of the filters. They can get pretty filthy over time, which will limit the air flow to the motor. With less air the motor is more likely to overheat and shut off. So keep your filters clean and you shouldn't have any proplems.
Apr 03, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Model 1697.m Bissell carpet cleaner.
You are going to want to replace the water pump on the machine. Also you might want to look into replacing the belt that runs it. If that still des not working, you probably have a clog in the hose coming form the heater element. This is VERY common with the Bissells. Good Luck!
Jan 08, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
