Question about Ryobi Bt3000 Bt3100 Dual Slot Miter Table
Is there something that people have been doing to replace or repair this obsolete part 661844001
This is the upper half of the miter table mount on a Ryobi BT 3100 Table Saw it is a black plastic part 1" square with legs molded on it
jyackle5
  • 8197 Answers
SOURCE: cannot find parts for ryobi 15in miter saw
Go to this site for parts. You will need model number though.
http://ryobitools.arinet.com/scripts/EmpartISAPI.dll?MF
Posted on Dec 16, 2008
  • 11 Answers
SOURCE: loose replacement blade
I completely removed the blade and put it back on, tightening the locknut, and now it works perfectly. The blade has not come loose and have used the machine for the last 3 months. The only thing I can think of is that somehow I didn't have the blade correctly installed in the first place, although it didn't wobble or anything.
Posted on Jun 05, 2009
mrrichardlbo
  • 59 Answers
SOURCE: Ryobi Miter Saw turntable hard to move and grinds when moving.
Hi Bob take the table back off get you some white lub put it on the center body of the table and if all posable get you a plaste over size washer to put where the bolt gose this will work now dont forget to take a look at your knob on the front it is tight you going to get the same thing.... Good Luck
Posted on Aug 16, 2009
  • 52 Answers
SOURCE: I do not know how to release the blade so it will
When you are facing the saw look on the right hand side in the area where the arm pivots. There will be a silver shaft with a groove just in front and slightly lower than the pivot. If you hold down slightly on the handle and pull out on this shaft it will allow the arm to lift up. Locking the arm down is reverse.
Here is a link to the owners manual for this tool.
http://www.ryobitools.com/product_manual/file_url/378/TS1342L_329_eng.pdf
Posted on Feb 24, 2010
  • 52 Answers
SOURCE: how do you unlock 10
Posted on Mar 08, 2010
I believe my table saw blade is not accurately aligned with the table and I can't find my Owner's Manual.
OK, first you should understand that the blade needs to be aligned with the miter slot. The easiest way to check this is to use a ruler.
UNPLUG YOUR SAW BEFORE BEGINNING!
First, use a pencil or a marker to mark the outside of one of the teeth on your blade, on the same side of the blade as the miter slot you're going to measure from. Position the marked tooth at the front of the table, then measure from the side of the marked tooth to the leading edge of the miter slot. To determine if it is aligned correctly, you simply spin the blade around where the marked tooth is at the back of the table and measure it again to the leading edge of the miter slot. The measurements should match. If you want to be more accurate you can use a machinists dial gauge to measure within 1/1000 of an inch.
If the measurements are off, you need to loosen the trunion bolts that mount to arbor to the table just slightly, then use a dead blow to move the table in the appropriate direction.
Search youtube for "table saw allignment" to find lots of videos showing this technique.
Also, here is a copy of your owners manual:
http://www.homedepot.com/catalog/pdfimages/c2/c2e26e29-35a4-469c-8193-136092afdbd3.pdf
Jun 30, 2012 | Ridgid 10 in. 13-Amp Professional Table...
I have a Bosch 4000 table saw when I start it will not rev up to full speed and after a min. or two the blade will **** to a stop and make a clicking sound then start up at half speed then immediately...
The field coil sounds like it has failed, best to find a service cneter in your area, this is a very involved repair if you are not familiar with these units.
Jul 05, 2011 | Bosch 10" Slide Miter Saw
Cuts not square-bevel adjustment
Here's something to try. Get a dial indicator or a drop indicator to measure the blade wobble. Clamp the indicator to your miter gage or use a magnetic base or whatever. Position the indicator so that it contacts the side of the blade as near the outside diameter as possible, then rotate the blade by hand. If there is any warp to the blade, or bend in the arbor, or something out of square where the blade mounts on the arbor, this will pick it up. If that is all good, maybe you have a couple of teeth that were miss-sharpened and are sticking out to the side more than they should (causing a virtual wobble at the tooth end). You could position the indicator on the side of a tooth, then slowly rotate the blade backwards looking for the max reading on each tooth. You should repeat this on the other side of the blade too. Total wobble should only be a few thousandths. Good luck!
Jan 24, 2010 | Delta 36 - 981 Electric Table Saws
Need to adjust Miter gauge for Delta tablesaw 36-977. The 90 degree stop is off
1) Before setting the Miter gauge, check that the blade is straight (parallel) with the slide grooves. Lock a board in the miter gauge and place against the front of the blade, and then the back of the blade. Is the distance EXACTLY the same (it won't matter if the miter gauge isn't straight and square). If not, you'll need to loosen the table and rotate the blade holder to square it up.
2) Now Cut a board in half the flip one side over and place the cut back together. If it isn't straight, the resulting board will have a "dog-leg".
3) Adjust the miter-set-screw until the cuts on the trial board yield a board that comes out straight (or use a Framing square to check).
Dec 31, 2009 | Delta 36 977 Left Tilt Contractors Saw
Adjusting Blade/Miter Groove Alignment on 1950's Craftsman Table
Try using a 1/16 thick flat washer as a shim where the mounting bolts/trunions mate with table. 1/16 shim on front mounting bolt will shift front of blade over 1/16 or 1 on the back mounting bolt will shift back of blade over
Oct 28, 2009 | Craftsman 10" Table Saw
How do I align the saw blade with the saw table I have a 10 inch Delta Contractor's saw that is about 10 years old. The blade is not straignt with the miter slot. andyc@bergeralllied.com
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
Sep 14, 2009 | Delta 36 982 10 Inch Left Tilt 1 1/2...
The table binds when I rotate it to change miter settings. When I cut miters(45 degree) I'm not getting straight cuts along the edge. The saw is on a plywood base mounted to a Dewalt miter saw stand. I...
Could be the wear plates under the table between it and the base. Or if it doesn't have any then the two mating surfaces are dry and rubbing causing this problem I would suggest going to Dewaltservicenet.com and typing in your model number and downloading a breakdown for the tool. To remove the table on most saws you have to remove the fence and that requires that you square everything up upon disassembly. Let me know and I will try and help further. By the way to clean the parts I use a surface conditioner with something like a scrubbing pad and then after everyting clean use a dry silicone lubricant or equivelant.
Sep 13, 2009 | Delta SM100M 13 Amp 10" Compound Miter Saw
Ryobi Bt3000 Bt3100 Dual Slot Miter Table Logo
Top Ryobi Saws Experts
JOHN LAPIER
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
