I have my rti T2i on charge now for 3 hrs, it's completely black no response, my remote is less then 1 year old second time this has happened, it took 2 days to get it going, what can I do to fix it?
4 Suggested Answers
pishta68
  • 579 Answers
SOURCE: Large Black Bar across one channel only Polaroid T.V.
Turn off CC1,2,3 or 4. You are seeing a Closed caption screen with either no data or encoded data. Usually the blank CC's are 2,3, or 4.
Posted on Nov 30, 2008
RTI Install
SOURCE: New RTI remote went black. Fully charged but nonresponsive.
Whenever possible contact an authorized RTI dealer in your area for support help!
There are a couple of reasons that a T1 or T2+ goes black. I understand that the screen does not light but if the buttons do not light either. The first most obvious reason is the battery is dead, even though it may act like it is charging. Pop the back off and check to see if the battery is slightly bulged. If so, it is for sure finished with its life. Further if the battery is over 2 - 3 years old it is probably done. Replacement batteries are available, but changing them requires more knowledge than just knowing how to use a Philips screw driver. The mother board battery connector is very susceptible to damage, so you must take great caution to hold the white mother board connector down gently on the edge with a small screw driver while you pull the white battery connector out.
Another potential problem area that will cause the screen to go off or become fractal is that there is an internal screw in the lower left that clamps the keyboard circuit board in place. This is also the ground clamp for the keypad illuminating surface. If this screw was not installed tightly the contact surface underneath will burn off. I have successfully repaired several of these by placing a triple folded small piece of aluminum foil in place of the burned out contact material under the screw and clear plastic illuminating sheet then tighten up the screw.
Only perform repairs if you are qualified to do so J
David
Master A/V Systems Integrator
www.soundandtheater.com/home.htm
Posted on Mar 08, 2010
  • 9 Answers
SOURCE: My 1 year old RTI T2+ suddenly will not charge.
Try replacing the battery. If this does not fix the problem the charging circuit may be bad and need service. Go through your dealer if you purchased it that way and they may be able to provide you with a loaner while it's sent off to service. Or call RTI yourself and setup a service request. (952) 253-3136
Posted on May 11, 2010
Remote in not charging; just blinking
If the remote is over 4 years old it's most likely the battery. Just need a replacement.
Jun 08, 2014 | Rti Technologies Rti T1 Remote Control
My RTI m2(?) fell off the table to the floor. The black cover dislodged and the screen also dislodged. It was still lit. When I replaced the screen the icons were lit with a pink band across the bottom of...
Sorry this remote can't be repair it is garbage,because the small display LCD screen panel it have mircro cracks and fractures in them and leaking chemicals radiation that why u able pink chemicals band across the the small display LCD screen panel.It time to buy another remote.
Sep 06, 2011 | Rti Technologies Rti T1 Remote Control
Can any one please tell about how to increase battery backup, its very less upto 1 1/2 hrs.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Dec 30, 2010 | Acer Aspire Notebook
My 1 year old RTI T2+ suddenly will not charge. I've tried charging it on 2 separate charging stations with no luck!
Feb 06, 2010 | Rti Technologies Rti T1 Remote Control
I have a T2+ remote sys and need a manual. as a start I need to know how to charge.
The remote comes with a charging dock, if you did not get this you can order one from RTI (952) 253-3136.
BATTERY AND DOCKING STATION
The T2+ uses a Lithium-Ion rechargeable battery. This battery does not exhibit any type of "Memory Effect" from being charged too often. Since the T2+ can safely be charged after each use, a docking station is included for convenience. If left out of the docking station, the T2+ will remain in sleep mode for 1 or 2 months before shutting down. At that point the battery must be recharged. The T2+ Docking Station can be placed on a flat surface such as a shelf or table, or it can be mounted to a wall using the mounting holes on the back of the unit. If the T2+ battery capacity is reduced to approximately one hour of remaining run-time, a low battery icon will appear in the upper left corner of the display The docking station LED illuminates to indicate a charge in progress. The LED will turn off when the battery in the unit is fully charged.A fully discharged battery will take approximately 2-4 hours to completely re-charge.The T2+ can remain in the docking station indefinitely without damage to the battery.
Jan 17, 2010 | Rti Technologies Rti T1 Remote Control
What does it mean when the light at the top of the remote is red instead of green?
The red indicates low battery. The batteries are estimated to last around 2 years at that point or later the battery will weaken and the red light will show up more often. In some rare cases the red light will not go away even with a fully charged new battery, in that case there may be something wrong with the charging circuit inside the remote that gives feedback on the battery's charge. You can either live with a false reading of the battery level and charge the remote nightly OR you can send it to RTI for a repair.
Nov 12, 2009 | Rti Technologies Rti T1 Remote Control
David
Sep 27, 2009 | Rti Technologies Rti T1 Remote Control
Phone says "charge complete" but then just dies
I took your suggestion and replaced the SIM card, but the difference is I managed to locked it in tightly. It worked.
Aug 21, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
