Showing e04 and number 8 jumping across display
Display shows Check Printer E 04 01
an E4-01 is a fuser warm up error...this is usually caused by a bad thermistor but can also be caused by a bad fuser lamp or thermostat
Apr 02, 2014 | Panasonic Workio Dp 8020e
I have a magic chef MCO165UB that the LCD display is black on and the oven won't operate at all. I've checked the fuse and it ohms out. I checked across the Bottom T.C.O. and don't get con
Sometimes that is a fan switch to turn on the blower if it gets too hot when cooking on the stove top. But you say the schematic shows it should be closed. So jump it and try the unit. if it works OK then replace it.
Oct 16, 2017 | Microwave Ovens
Why does the lcd display goes bad
Faulty electronics. It may be time to look for another calculator. Try pressing the 8 key enough times to fill the LCD 88888888888. If
Apr 03, 2012 | Sharp EL-512H Calculator
Danby dpac120068 blue light flashing with error code E04 and the compressor keeps turning off randomly. What is causing this? What does E04 mean?
E04 refers to Overheating. There might be plenty of reasons. You might have seen, if you shut down the ac for few minutes and again start it, It would work for few minutes and the same E04 display is there.
This is tech's job. I am sorry, i am not discouraging you but it requires certain testing that actually what makes ac overheated.
This is dangerous. So, better to call a tech and get it checked!!
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | Danby DPAC120068 Air Conditioner
JVC GR-D30U Digital Video Camera error E04
there was a hole under the tape deck.. u can try to force;y open it right there
Sep 01, 2008 | Cameras
23 people viewed this question
k24674
jasbo
jasbo
