Question about Hotpoint WD62 Front Load Washer / Dryer
Hotpoint W/D valve problem
I have had a water problem on mt washer dryer WD62.
Water was coming in during a dryer cycle, even with the machine turned off
Lucky me too.....the door seal was damaged from a caught tea towel, soi had a lovely flood to contend with. So turned off the machine, moppedup, went to bed. Next morning.....flooded again.
Anyway, I have changed the seal and got a replacement valve (3 way cold inlet). VAL20 from a fleabay seller.
The valve looks very slightly different with one pair of the spadeconnectors turned round 90 degrees......AND my old valve has a red anda black insert in the edge of the outlet pipes on outlet 2 & 3(counting downwards). The new valve has them on different outlets (red& yellow).
Now, the machine seems to be okay on wash.....but when I start adrying cycle, water spurts out of the top of black plastic vent on thetop rear of the machine.
Do I need to change these inserts around ? Should the wiring be the same on the new part ?
Any pointers appreciated. Thanks.
  • 249 Answers
Yes change inserts around leave top off test and watch. red is for hot water black for cold
Posted on Nov 25, 2007
Aquarius 1200 washer/dryer WD62. Why isn't it washing/rinsing clothes properly?
If your washer /dryer is correctly connected to hot and cold water supplies, replacing the fill valve would be a good place to start.
Mar 26, 2016 | Hotpoint Washing Machines
I have a wd62 washer/dryer. my machine will not fill with water but will wash and spin, can you please tell me what i could try. thank you.
In practice the washer should not wash without water in, if it does wash without water, then it could be a faulty or sticking water level switch.
The other possibility is the water inlet hose is frozen, turn the water off to the washer, remove the inlet hose, and lower it into a bowl or bucket, then turn water back on, and see if it comes through o/k.
If it does, then problem is in the washer.
Dec 19, 2010 | Hotpoint Washing Machines
Hi I have a hotpoint WD62 washer dryer. when I'm using the dryer the clothes still come out wet like the steam is not going out of the machine. Any tips on what to check for? Could something be...
I had the problem. I replaced the water inlet valve, and that fixed it. It seems no cold water was coming in on the drying cycle to condense the steam.
Sep 24, 2010 | Hotpoint WD62 Front Load Washer / Dryer
Where do I drain the tumble dry water on a hotpoint wd62 wash/dry
remove the top panel by unscrewing the 3 screws at the back of the washer dryer . remove the top and then remove the back metal panel. the screws are down the side and all around the back of the panel. once you have removed the panel check for the black rubber hose that connects to the drum. remove the clip holding the rubber hose by prising it with a small screwdriver. be careful as the water will flow out quite quickly. Check the hose pipe for any blockages and clear as required.
Jan 04, 2009 | Hotpoint WD62 Front Load Washer / Dryer
All washing machines have a solenoid valve for turning on and shutting off the water coming in, one for the hot water and one for cold. It sounds like one of them has a slow leak.
Try shutting off the cold water supply to the machine for a day and see if the tub fills with water. Next try shutting off the hot water supply and leaving the cold supply on. This will tell you which valve is leaking.
This solenoid valve is something you can buy from an appliance parts company. In some cases, someone handy may even be able to disassemble it and replace a washer that is leaking.
Until it is repaired, you can get by with shutting off the water supply when you are not using the machine or shutting off the supply that is leaking. For example, if it's the hot water supply valve that is leaking, just shut off the hot and do only cold water washing.
Oct 03, 2008 | Hotpoint Washing Machines
Hotpoint WD62 Drum wont turn
tilt the machine backwards. with a multimeter, check continuity across the brushes - if open circuit then brushes need to be replaced
Oct 02, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Water is being used in the drying cycle
This is normal operation. Water is used by the condensor to liquidfy the steam from drying.
Mar 27, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint wd62 leaking from the drawer
Hi, check the electrict valve winding busted hot and cold.
Jan 27, 2008 | Hotpoint WD62 Front Load Washer / Dryer
WD62 drawer leak
remove drawer clean it make sure flap is free on drawer compartment
Nov 24, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint Aquarius 1200 WD62 (Tumble drying issue).
no the steam from the dryer part comes out of outlet tube the same tube were the water comes out hotpoint washer/dryers use a condensing chamber which allows the steam to cool down a pass through it as water does and through the outlet pipe
Aug 14, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 Front Load Washer / Dryer Logo
77 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
