Question about Connex Radio Communications
My connex 3300hp turns on an off by itself. Its powered an grounded from the battery.. It also makes a popping sound when it comes on
One Wire
  • 126 Answers
SOURCE: Manual for Connex 3300 HP
The best place for anything related to cb radios and ham radios is www.cbtricks.com.
Here is a direct link to the owner's manual for a Connex 3300hp
http://www.cbtricks.com/radios/connex/cx_3300_cx_3300hp/graphics/connex_cx3300_cx3300hp_om.pdf
Dean Pitts
Rollin CBs
Posted on Aug 31, 2008
ozark333
  • 396 Answers
SOURCE: On the Connex CX-3300HP what is the Band knob for.
The Band knob moves the frequency coverage from 25.615 and 28.305
The Hi-Low switch determines the lowest frequencies and highest.
Here is your owners manual.
Posted on Sep 29, 2009
  • 11 Answers
SOURCE: My connex 3300hp just stopped transmitting. why?
The RF final output transistor(s) is probably blown. They are not very difficult to replace if know your way around with a soldering iron.
Posted on Oct 10, 2009
  • 773 Answers
SOURCE: how do u make the talkbalk louder on a connex
There are problems with having a loud talk back. You can get feed back and an annoying squeal when you transmit. That is why the talk back isn't that loud to begin with.
The reason you use talk back is to check your echo, and make sure your mic gain is not too high. It shouldn't need to be that loud to check it.
I highly recommend you leave it at the level that it is.
Posted on Nov 03, 2009
jcameo7270
  • 675 Answers
SOURCE: Connex 3300HP old model. Dead keys no modulation
Try the voltage regulator or the power supply circuit
Posted on Jan 23, 2011
Hooked up my connex 3300hp backwards
this usually just blows the fuse, check/replace and try again, if it pops the fuse, the protection diode has shorted and the radio needs to be serviced
Feb 08, 2014 | Connex Radio Communications
Who makes connex radios/ 3300hp
RCI use to make them, I am guessing they still do.
Nov 26, 2013 | Connex 3300 240-Channels Base CB Radio
Connex 3300hp not receiving at all rx tx light on front not on, key mic turns red
MAKE SURE ALL THE CONTROLES ARE SET CORRECTLY R-R GAIN CLOCKWISE FULLY, SQUALCE COUNTER CLOCKWISE FULLY AND HAS THE RADIO BEEN MODIFIED FOR THE 11 METER BAND BY SOMEONE
Feb 25, 2013 | Connex 3300 240-Channels Base CB Radio
I need a wiring digram for a rk 56 inside the mike my wires are broke need to know were to put them back connex 3300hp
  • With the switch sitting as it is in the picture below (actual switch recessed tho the right. Soldier the wires in this order.
  1. Black
  2. Red
  3. Lite Blue.
  4. Dark Yellow (This yellow wire comes from the mic cord itself)
  5. Shield.
  6. Lite Yellow. (This yellow wire runs off to the side of the mike to the electrical components inside the mic)
  • Standard 4 pin Cobra mic tip to run it to that Connex.
  • Pin 1 - Shield.
  • Pin 2 - White.
  • Pin 3 - Red.
  • Pin 4 - Black.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 05, 2011 | Connex 3300 240-Channels Base CB Radio
Feed back thru external speaker, very bad
Have your antenna checked at a place that knows what they're doing. If your antenna system is bad, ground problem,coax bad mount or maybe just a wrong or bad antenna. Then the sounds not getting out the antenna and its feeding back thur the radio.If your echo board was bad then your radio wouldn't transmitt at all.
If you unplug your external speaker will it squeal? If not do the antenna and if that reads fine just try a better speaker like a uniden 20watt speaker.I own a CB shop and this is easy to fix.
Jul 10, 2010 | Connex 3300 240-Channels Base CB Radio
Connex 3300hp
Poor ground shield, or poor solder joint in mic cable.
Oct 07, 2008 | Connex 3300 240-Channels Base CB Radio
Dean Pitts
Rollin CBs
Aug 26, 2008 | Connex 3300 240-Channels Base CB Radio
Killer radio needs help
I'm not sure if this will solve anything...but here it goes.
1st..Make sure you antenna connections are tight. it sound like it is arcing.
2nd.. make sure you SWR is very low. 1.5 or lower. (very important)
3rd.. make sure the rf power at your radio is turned down to low..over powering (over driving) your amp will fry your finals. (just as important)
If it's not any of these..then I'm not sure.
I have always used an Road King RK56. Not the knock off but the real deal. I would sometimes shock my lips on the metal grille , when I keyed up with my linear on high. I could also power flourescent lights when I got under them..lol and that was with a 250w box and a galaxy 99!
Jun 27, 2008 | Connex 3300 240-Channels Base CB Radio
Radio Communications Logo
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Jim Y
Jim Y
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
