Question about Canon PIXMA Office Equipment & Supplies
Pixma paper jam code 6000
I can't see any paper jams, I've turned machine off and on. Keep getting a paper jam error that says turn the copier off
thumu
  • 69 Answers
SOURCE: False Paper Jam
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to Paper Jam error messages even though there is no paper jam in printer . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
This issue could happen if there is an issue with any small paper jam in the Printer, or due to the communicational issue .
To isolate the issue, I recommend you to perform below steps.
Steps are:
1. Power OFF printer and then please Disconnect the Printer from Computer and then disconnect the Power cable of Printer from wall outlet.
2. Check thoroughly in Printer that there is no small piece of paper in the Printer.
3. Let the Printer be disconnected and idle for 5 minutes.
Meanwhile please perform further steps on Computer.
  Note: The below steps are applicable if you are using WINDOWS 2000/XP/VIsta Operating system in  your PC
  Steps are:
 Perform the below steps to restart the print spooler :
1. Click Start>Run
2. Type services.msc
3. Click OK
4. A Window will pop up with so many services listed.
5. Scroll down to locate "print spooler" in the list, right click on it and click "Restart"
6. Restart the Computer.
Once if you are done with steps, please connect the Printer and then Power ON Printer and check the issue.
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
Posted on Oct 20, 2007
shaggyrat
  • 1224 Answers
SOURCE: canon pixma mp460 code error 6000
Solutions for error 6000 Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
1. Press ON/OFF switch to reset the multifunction device 2. Removing paper jams MP450 / MP460 3. The MP460 may require repair
heres the problems currently with mp460 and at bottom is the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13369
this is the solutions for the mp460
for the guest
clean out your ink absorber after unplug
reset printer you still have a little credit card sized paper in your printer that you need to remove it
Posted on May 21, 2008
  • 27 Answers
SOURCE: paper jam in my printer
the paper sensor may have went in the printer try doing unplugging everything and plugging it back in
Posted on Jun 29, 2009
  • 52 Answers
SOURCE: paper jam problem in pixma mp145. E3 error.
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
Posted on Nov 04, 2009
pineworks
  • 4041 Answers
SOURCE: Error 6000
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
Error code 6000
Error 6000 is a line feed error, it means the platen roller isn't advancing properly. It usually means something has fallen in from the back where the paper goes and is stopping the rollers from turning.
Check the printer for any paper jam or try to reset the printer to release memory code errors.
1. Press and hold the Resume button for 1 - 2 minutes.
2. Open the cover.
3. Remove the cartridge and then reinstall it.
4. Close the cover.
5. Turn Off the printer.
6. Turn On the printer.
Jun 14, 2011 | Canon PIXMA mini260 InkJet Photo Printer
When i try turning my printer on for the first time i get an error message that says 6000 printer error turn off and back on again. but this doesnt help.
1. Check for a paper jam.
2. Turn the printer upside down to ensure nothing is inside (small) jamming the feed.
3. Use a flashlight to make sure there are no small pieces of paper in the way, preventing the paper from feeding.
Mar 01, 2011 | Canon PIXMA MX350 Wireless All-in-One...
My pixma mini 260 canon printer is giving me an error 600 signal.
Error code 6000 on PIXMA MP260 to solve this issue, lift the lid and rolled the wheel on the right hand side (plastic with black rubber drive belt) connected to stainless steel shaft. This wheel should be able to roll in both directions for 10 full turns with no obsruction. If the wheel stops there is something jamming the drive motor giving error 6000. or see a little paper piece may cause jam.
good luck, do rate if soved
Nov 30, 2010 | Canon Office Equipment & Supplies
Errror code 6000
Error code 6000 appears when the paper jam, power off the printer and remove carefully the jam paper and power on the printer:
Nov 09, 2010 | Canon Pixma MP450 All-In-One InkJet...
Error message 6000
6000 is a paper jam or jammed sensor.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#ServiceAndSupport
Click service and support, then enter error 6000, then click Error LCD ... 6000..., then click Removing paper jams mp600. Sorry, but they use javascript so I can't give you a more direct link.
Sep 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma ip1980 service error 6000
Hi there
You can try this may help you.
These are the steps:
1. Turn On iP1980
2. Push and Hold Resume button about 2 minutes
3. Release Resume button
4. Printer back to normal again
To get Permanent , follow the steps here :
Manual Resetter canon Pixma iP1980/1900 Download
Feb 07, 2010 | Office Equipment & Supplies
I have a Canon MP 520 Pixma printer and getting error code 6000
There is got to be a paper Jam inside the printer OR
Look for something that might have stuck up the roller ..
Thanks
Fame !
May 02, 2009 | Office Equipment & Supplies
Error code 5110 Canon Pixma MP500
Error 5110 = Kann den Schlitten nicht anheben. (mechanischer Fehler)
Sep 28, 2008 | Canon Pixma MP500 All-In-One InkJet...
26 people viewed this question
old marine
old marine
