Question about Ryobi Tools & Hardware - Others
How do I remove a torn belt from the drive wheel of a Ryobi be318-2 belt sander?
efs_perpends
  • 1996 Answers
SOURCE: BROKEN RUBBER BELT FOR BELT SANDER
Maybe you can use a linked belt to replace it. Check the width of the old drive belt, and give these folks a call: Lee Valley
Posted on Apr 02, 2009
SOURCE: Ryobi 9
I it myself by putting the band in a pan of boiling water. It had to stretch about 3". A hair dryer was useless to get it hot enough
Bob
Posted on Apr 13, 2009
  • 384 Answers
SOURCE: I have a Ryobi 4x36 Belt Sander (BD4600). I've
Look for plastic build up in the motor. Try to air blow motor and belt drive.
Posted on Jun 16, 2009
  • 384 Answers
SOURCE: broken drive belt
Take the broken belt to an industrial supply house or Ball Bearing supply house for a replacement.
Posted on Jul 10, 2009
SOURCE: broken drive belt on belt sander
My answer comes almost a year after the original question, but I'll post it anyway for those who end up here after a search.
Black & Decker no longer supplies drive belts for the BR400 sander, but you can get a replacement elsewhere if you know what to ask for.
The belt is a synchronous, single-sided "XL" series belt, and mine had 120XL031 printed on it. The belt width is 0.31in or 5/16in or 7.9mm. Its pitch (distance from tooth to tooth) is 0.20in or 1/5in or 5mm. Its total height is 0.09in, and tooth height is 0.045in. It has 60 teeth, making the total length 12in.
I found a replacement at sdp-si.com, part number A 6R 3-060031.
Look here for timing belts (inch), then narrow the search for single-sided, .200 (XL) pitch, 60 grooves, 5/16 width.
Posted on Jun 16, 2010
How do you adjust the belt tension on the Ryobi BE321 belt sander?
Usually there is no belt tensioner on by sanders. Only alignment adjuster. Must use exact size belt.
Jan 06, 2015 | Ryobi Tools & Hardware - Others
Where to buy 55-3554-4 drive belt
Applied Industrial Technologies Brampton they also have several other location just google the name
May 05, 2012 | Ryobi Mastercraft Belt/disc Sander Belt...
I have borrowed a ryobi industrial belt sander, I have put the sanding belt and repositioned the latch. When running the sanding belt keeps moving out.
There will be a tracking adjustment somewhere, usually a knob or wheel located at one end (axle) of the sander that allows you to adjust that... run the sander at low speed while you turn it until it tracks straight
Jun 10, 2011 | Tools & Hardware - Others
I have a Ryobi BE-321 belt sander. The drive belt is strtipped. Are replacement belts still available?
Yes, you can purchase a new belt here:
http://www.ereplacementparts.com/ryobi-be321-belt-sander-parts-c-7931_7932_15013.html
Luke
Oct 27, 2010 | Tools & Hardware - Others
The sanding belt has broken and jammed in behind the rear driving wheel. It won't budge. How do I remove it ???. Brand new sander to. Thanks for your help,Fraser
UNPLUG tool and with a pair of needle nose plliers and patience pull the belt loose it might take some time but that isabout the only way to do it.
Oct 22, 2010 | Makita 4" x 24" Belt Sander 9403
How do you replace the drive belt on a ryobi type be321
I tried the model number and can't find it on their site, but if this is a belt sander or planer you can "roll" the new belt in place without loosening anything. If this is another tool let me know and please give me all the information (tool type) and I will check further.
Aug 23, 2009 | Ryobi Tools & Hardware - Others
Motor runs but the drive drum that hold the sanding belt does not turn.
Instead of removing the drum, remove the belt and the cover over the gearbox. The gearbox cover is normaly fixed in place by screws around the drive pulley. There may be a couple of screws under the pulley, if so they can be accessed via holes in the pulley wheel itself. Check for worn or stripped gears. These gears can be replaced if need be, but if this is the case make sure you remove and clean out all the grease first and replace that aswell as it may contain bits of teeth that have come off the faulty gear. As far as I know belt sander drive rollers can not be removed without removing the drive inside the gearbox first.
Oct 27, 2008 | Dewalt Factory-Reconditioned DeWalt DW432R...
Tools & Hardware - Others Logo
62 people viewed this question
Top Ryobi Tools & Hardware - Others Experts
Mike
Jay Finke
Jay Finke
Are you a Ryobi Tool and Hardware - Other Expert? Answer questions, earn points and help others
