How do I turn off the internal speakers on a tv Sanyo DP42841
I bought a Bose soundbar and it tells me to turn off the speakers but I don't know how.
    Top Expert:
  • Televison & ... Master
  • 49,066 Answers
Does the remote have a MUTE button ?that is the only OFF there is
Posted on Jan 01, 2017
  • Jane Frew Edwards
    Jane Frew Edwards Jan 02, 2017
    thank you.....can very faintly hear sound coming from the soundbar but can't turn it up. Will call Bose tomorrow.
  • 4 Answers
You should be able to go to your tv Menu settings> sound> then look for speaker setting and select external speakers. I'm not sure how Bose works as far as setting input but if you have hdmi hooked up select the correct source. If you have a digital optic cable for audio then make sure you select that option as your input source through your soundbar.
Sanyo 1LG4B10Y04800 how do I find out what board my television takes this is the Power Board number
Assuming you are observing all ESD & Safety precautions...
The absolute best way to tell what pack you need is to LOOK at your old pack...
Go to a parts supplier...
Put in your make = SANYO
MODEL = something like "DP42841"
that ought to be a Sanyo Lcd tv ...
such as ... or
Sanyo 1LG4B10Y04800 Power Supply
TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 16, 2016 | Sanyo Televison & Video
Bought a soundbar for my Coby TV. How do I cut off the internal sound to be able to use the soundbar?
On TV menu / guide, sound section. speaker on or off, turn off. (If your TV has that option)
May 16, 2016 | Coby Televison & Video
Vizio sound bar won't turn on with tv
How to Fix the Vizio Soundbar ' > Finances & Taxes > Other Finances & Taxes
Soundbar Won't Turn On ... Turn the volume up on the Vizio soundbar and also ensure the soundbar isn't muted. ... For example, even if the Vizio soundbar is connected properly, if the TV is set up to output through the internal speakers only, ...
Fix A Vizio Soundbar Remote In 4 Simple Steps ' Vizio TV ...
Aug 25, 2015 - Each model of Vizio soundbar includes its own remote. It's what is ... Use the power button on the soundbar to turn it on. Then test ... So replacing thesoundbar won't resolve the issue if you have one of the effected models .
Nov 28, 2015 | Vizio Televison & Video
How do I connect Samsung soundbar 550 to sanyo dp55441?
Use the audio out ports on the Sanyo to get audio to the Soundbar. You can use a single digital audio cable or the legacy RCA audio cables. The Audio Out ports are marked in white on the back of the TV. If it doesn't work, turn off the TV Speakers in the TV's menu.
Jan 03, 2015 | Samsung HW-D450 Sound Bar
How do i connect a soundbar to a Sanyo TV.Tried all connections with both RCA cable and 3.5mm Line in cable.No luck.thanks
Make sure you are connecting to the TV's audio-OUT jacks, not the audio-IN jacks. Also, check the TV options menu. Some TVs have a choice of internal or external speakers and you have to select one or the other; obviously, you would select "external".
On the soundbar make sure you have selected the correct input jack for the audio cable.
Sep 26, 2014 | Sanyo 42 in. LCD TV
New (2012) DP42841 Sanyo no sound
Check all the cable connections to audio board for any loose connection. During long term storage, this might have happen. Reset all that cables comes to go out from it. If it do not help you, check the speakers. If all found OK, replace the audio output card. If you wish to get some details, check the site linked here. up older posts. Check the site in 'Mosaic' view.It will make search easy. Check its audio settings too. Whether it is muted or not.
Jan 05, 2014 | Sanyo DP42849 42 in. HDTV
Nexus NX5503L120 is the TV I have and I have a Panasonic Soundbar. I want to be able to control the volume from the TV remote.
You may be able to go back to the initial TV set up procedure and select the option of turning off the internal speakers
Dec 17, 2013 | Nexus Televison & Video
How do i turn the sound on my sanyo dp37647 off
As nearly as I can determine from your description, you want to turn off the Sanyo TV speakers and direct its audio to the soundbar. Your initial setup procedure should provide an option for doing this. If not, there may be an audio control button on your Sanyo remote that will accomplish this.
Nov 30, 2013 | Sanyo Dp37647 37" 720p Hdtv High Def Lcd...
Am setting up a bose GSX 3-2-1 home theater
Need to know the TV connections. On newer TV's there RCA jack connection or ext speaker connections. Usually the external TV speaker connections hook to the woofer and the rest of the speakers are connected to the woofer. The woofer acts as the sound system for the rest of the speakers. With this method you need to mute the internal TV speakers by a swiich on the TV or internal TV setup menus and select ext speakers.
Jan 26, 2008 | Bose Cinemate Digital Home Theater System...
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
