Question about Lexmark X2690 All-In-One InkJet Printer
Stepson has a 2600 and when installed says everything is ready. when you print, message comes up about a communication problem. gives solutions about what to try, tried them all, except don't know how to check to see if firewall is blocking printer. Running xp, software says system doesn't meet min req. Totally lost
  • 528 Answers
I don't think you have connected the printer as a network printer. If you have just connected the printer to the computer, the firewall will not block anything to the printer. If it says system doesn't meet min. requirements, try increasing the RAM of the computer. That will probably help!
Posted on Jul 21, 2009
Does not print
Epson sylus notorious getting getting corrupted software
1st Uninstall all Epson stylus printer software prividing you have instalation disk
Disconnect Printer
Restart computer and check to make sure under control panel / printers that there is no primary printer in there if there is delete it
2nd give printer power cable /communication cable good clean and check the printer port on computer isnt damaged.
3rd turn computer off reconnect printer have software ready but only if it is required most window systems have enough data with them that it will recognise new printer and install auto but if it asks for disk you will have it ready.
4th turn computer back on see if it notices new printer if not not to worry put disk in and install software,which will normally take you through a connect cables and power and install guide after that it should do a test print, if this comes out everything should ok again, but just check in control panel/ printer, and make sure its marked as default printer
hope this helps
Aug 12, 2014 | Epson Stylus Sx438w
My printer will not print still after I troubleshoot it and everything. I have a netbook laptop so I don't know why it's not printing. It says it's ready and everything
Problem Print job does not print; No Lexmark job status window Solution What you will see
  • The Windows print queue spools the print job.
  • The print queue icon appears in the systray or notification area.
  • The print queue icon disappears as if the print job has successfully been sent to the printer.
  • The print job disappears and does not print.
  • No Lexmark job status window appears to indicate a communication problem.
  • No other communication errors. This issue is most likely due to a corrupt device mode registry entry from another printer that was installed and used in the past.
Or
  • You do see the job status window and you do not see any alerts or communication errors, yet still nothing gets printed
What to do
A confirmed cause must be established before a resolution can be achieved.
To do this:
  1. download a diagnosis tool that will help determine the cause of the printing issue.
    IMPORTANT: Again, this tool is only to be used in cases where there is no communication error message from the Lexmark job status window and the job spools quickly through the Windows spooler, yet nothing prints.
  2. Select an easy-to-find Save location, such as your Windows Desktop.
  3. Double-click on the delserDevMode.exe file.
  4. Accept the License Agreement. After the file is executed, it saves devmode.txt to your root directory (e.g., C:\devmode.tx.
Aug 31, 2011 | Lexmark X2670 All-In-One Printer
Printer error
Here a few common problems that your Epson printer and ink cartridge can suffer from.
Improper Installation of Cartridges
A common Epson printer and ink cartridge problem! If you have changed the ink cartridges then you might just receive this error message. The message might state that the cartridge is not installed correctly in the printers. In such cases, re-install the cartridge in the correct manner. If the problem persists then it is advisable that you replace the cartridge as it might be defective. If you still get the same error message on installation of the replacement cartridge then its time that you clean the print head. You could do this yourself or could take it to a repair facility.
Printing Failure
Failure to print documents is yet another common problem with respect to Epson printers. The print heads of Epson printers are sensitive and this sensitiveness is the culprit behind such problems. If the print head is clogged or blocked you will have to unclog or unblock them. This can be done by using a special fluid that is available for just this purpose only. This fluid flushes the print head, and your printer is once again ready to print.
Communication Error
'Communication Problems' are yet another one of the common problems surrounding Epson printers. Once you give the print command you might be shown the message that there is a communication error between the printer and the computer. This means that there is the occurrence of a minor problem. One of the reasons for this problem could be the inappropriate selection of printers from the print options menu. Cable connections should also be checked. Another solution could be the re-installation of the driver of the printer.
Print Jobs that are Slow or Incomplete
These are problems that occur during an ongoing process. The printing might stop midway and then start again after some time. At times, the printing process will repeat itself several times and then finish printing the page. There are times when the page will finish printing, but you will find that it is an incomplete print. More often than not, this is not a printer related problem.
What might have happened is that the driver might have corrupted or a virus might have infected the computer; or a spyware might be affecting the working of the printing process. If such a problem occurs, the best solution would be to scan the computer for viruses and spyware. As can be seen these common Epson printers and Epson ink cartridge problems can be sorted out quite easily.
hope it helps..
Thanks for using fixya...
Dec 04, 2010 | Epson Office Equipment & Supplies
My Dell V305 only prints occassionally. An error
I used to have a Dell all-in-one and had same problem.
I asked Dell for new installation disc and re-installed it and that seemed to to solve the problem.
Feb 07, 2010 | Dell V305w All-In-One R840635AU InkJet...
Computer isn't communicating with my printer
The problem could be because of ONE out of FIVE problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Apr 08, 2009 | Dell 962 Photo All-In-One InkJet Printer
Lexmark Z705 Printer
re-install the printer with take care of communication port,
PS. keep turn on your printer while installing
Nov 08, 2008 | Lexmark Z705 Inkjet Printer
Lexmark Printer Install - No Communication Error
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Jul 19, 2008 | Lexmark X1150 All-In-One InkJet Printer
Ready Memory Received
Dear guys, your toner cartridge is low and as a preventive measure, the unit stores the faxes in order to give priority to copying and printing. If you are using remanufactured cartridges, the unit might not be displaying the low toner warning.
Jan 24, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Open Questions:
See all Lexmark X2690 All-In-One InkJet Printer Questions
Lexmark X2690 All-In-One InkJet Printer Logo
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
