My tv is really dull and the picture shows dark and faded
  • 24 Answers
SOURCE: Picture too dark
You didn't say if you are receiving an off air picture or cable or satellite. The reason the commercials look good is because the local station (or source) transmits them "in the clear", that is, without any enhancements to the video signal. Network programing or local newscasts are sent through a device which inserts a reference signal in what's called the "vertical interval". You may have seen this as a series of flashing dots or pulses at the very top of the picture. There's a lot of information packed into the VITS (Vertcal Interval Test Signal). One of the lines contains a reference pulse for video which is set at a certain level. Your TV sees that level and automatically adjusts its circuitry accordingly. What I suspect is that your set is out of calibration and is pushing down the video signal because it is not "seeing" the level properly. A video alignment should correct this and can be done by a good repair facility. Hope this helps.
Posted on Oct 31, 2006
  • 3130 Answers
SOURCE: Dark screen/picture.
This 30" flat screen TV set may have a problem in the high voltage circuit of the TV set. You may be able to adjust this by taking off the back of the TV set. Look for the block where the large red wire runs up to the top of the picture tube. On this block will be two controls. one will say screen and one will say focus. Try and slowly turn the control that says screen or S on it clockwise and see if you can make the picture brighter. Turn up the control till you just start to see faint lines in the picture, then back the control down till the lines go away. If the picture does not come up when you turn this up, and all you get is a blank screen, you will need to have this set repaired by a qualified repair person. Good Luck
Posted on Jul 15, 2007
SOURCE: Fading picture that looks dark and dull on a 42" Samsung DLP tv.
You need a new lamp...
Posted on Feb 27, 2009
  • 668 Answers
SOURCE: dull dark picture on kdf-e50a12u rear projection
Depending how long you have owned it and if a Lamp was ever replaced, it probably needs to be replaced. You can check with SONY at
1800-222-SONY and see if they could sell and send you one.
Hope this helps,
Posted on Jul 21, 2009
  • 167 Answers
SOURCE: my samsung 61' DLP model# HLS6187WX is looking
you need to replace a lamp to resolve this issue part # bp96-01472a
Posted on Dec 19, 2010
My tv picture is faded and dark
you might need a new bulb, bulbs average around 4000 hours, depending on the bulb, they range from 750-6000 hours
Apr 20, 2014 | Philips 60PP9352 60" Rear Projection...
Faded and bright
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
May 17, 2010 | Philips 60PP9352 60" Rear Projection...
Dull dark picture on kdf-e50a12u rear projection
Hope this helps,
Jul 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
I would check for dust particles before I attempted any type of repair on the unit.
Dust particles will appear as dark spots that are larger than the size of an individual pixel. It must first be determined if the particle(s) are on the LCD panels or the screen.
May 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
Picture has a red "haze"
the color in my tv is a little faded when theres dark scenes on cant really see picture. Red and Blue really fade into picture
Feb 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Dark color
Have you tried polishing the projection mirror and changing the coolant in the CRTs. The mirror alone can make the picture dull. Do not use windex to clean the mirror, just a soft damp cloth then dry. You can access the mirror hrough the back panel its a bit of a reach but its do able from the rear the mirror is directly above the rear acess panel.
Jan 19, 2008 | Philips 43P8341 43" Rear Projection...
Picture Fading
hi there, maybe you do have a lose connection, wire/cable connection, check terminals if ok. ty
Dec 26, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
