Question about Dewalt Air Tools & Compressors
I purchased a kit from professor foam on ebay and installed it. The nail gun is still shooting air out of the tip where the nails come out. Dewalt D5188 type 1
I did find one shredded o-ring when I took the gun apart. With the kit I got it doesnt seem the the gun is getting a good seal around the bulkhead /cylinder spacer. I have a type 1 dewalt D51844. The plastic bag the kit came in does have my model number on it. Only one of the only rings that go under (inside) the bulkhead is the clearer color. Both of the ones I removed were clearer. Also I seem to have one o ring left over. Maybe that is because one of the other models or types takes an extra one ring. Please advise. The only other option I can think of is to pull the trigger out and check those o rings. Im just not finding info online that would indicate those o rings as the problem I am having. The gun does shoot nails but they only drive in half way 5do to the loss of air out of the nose of the gun.
2 Suggested Answers
  • 1388 Answers
SOURCE: Dewalt Nail Gun D51844. Same problem as other guy
Dewalt uses about 4 or 5 orings within the gun made of semi clear urethane that fail (turn gummy and breake apart). Two are under the bulkhead and at least two in the trigger valve. To remove the bulkhead pull up on the white housing. With housing and cylinder assembly out, push down on the black retainer at the very bottom and remove the oring(take a picture of the assembly after each stage so that you can re-assemble the spring and checkvalve correctly). You will find two large orings under the bulkhead against the cylinder that need to be replaced (also the orings in the trigger, or replace the trigger valve ).
Posted on Oct 06, 2011
Well i put a seal kit in my dewalt d15844 nail gun and the air still comes out where the nail do,can anyone help me
You must have damaged the seal when you installed it, you used seal lube when replacing them correct?
Nov 02, 2016 | Dewalt Air Tools & Compressors
Dewalt framing nail gun want shoot nail
Which model is it? What happens when you try and shoot it? Is it leaking air and if so from where? Is there a nail jammed in the tool?
Aug 19, 2012 | Dewalt Tools & Hardware - Others
I have a d51822 framing nailer that will shoot a nail but then not recoil to shoot the next nail, if you wait 10-20 seconds the gun will release air at the top of the gun and recoil
Most likely there is a problem with swollen orings between the cylinder and cylinder spacer (white plastic piece between cylinder and body ). Order the oring kit because nost likely when you take the gun apart the orings will fall apart. Dewalt used vinyl orings instead of viton on critical areas of the cylinder and these vinyl orings failed.
Sep 21, 2011 | Dewalt Clipped Head Framing Nailer
After shooting a nail, it fires out two more nails. It's a Dewalt d51822.
There is a replacement trigger valve available from Dewalt. The new part number is 5140095-73 (the old part number was 641006-00 ). I am not sure however if the new part is just a natural upgrade or if it was changed to address an issue. I have seen these guns double fire and fire once when air is connected. I would change trigger valve and four orings that make contact with the bulkhead (part # 395215-00). These orings are in the repair kit available from Dewalt (kit does not include the trigger valve). Use caution for now, do not load nails until you are ready to nail; then pull out nails from rails when done . Good luck
Jul 30, 2011 | Tools & Hardware - Others
I only shoot one nail and the rest is air. i need to push up the magazine to advance another one. This is my first finish nailer, is there something i'm doing wrong or is it the gun. I just purchased this...
Possibly, I would make sure that you are using the right guage nails first with the proper collation. You can go to Dewaltservicenet.com and download a breakdown for the tool and also a users manual.
Jul 19, 2010 | Dewalt D51256K 16 gauge finish nailer kit
My nail gun will shoot one nail and then stop shooting.
check with one of your friends that have a nowinly good 18v bat if that dont work check for little pieces of plastic or pieces of the nail that are jamed up by the plunger
Apr 22, 2010 | Dewalt DC618KA Angled Nailer Kit
My dewalt framing gun will not shoot out nails
several things could cause this need more info..... be sure your
firing correct nails #1, check air pressure #2,make sure spring clip
is pushing nails forward #3, make sure ram is moving in the head #4
if this does not help we can go deeper.... good luck
Nov 01, 2009 | Dewalt Air Tools & Compressors
Nail Gun support
Yes, because there is less risk of splitting the wood grain when using a nail gun than when using a hammer, nail guns are especially useful in delicate projects such as the application of indoor trimming. A nail gun sets the nail in one motion, reducing the chance of slips and bumps that can ruin delicate woods. Most models also include a rubber safety nose to protect the wood from friction.
Sep 01, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Air Tools & Compressors Logo
130 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
