Question about Wine & Spirits
Is Macs grape driffwood safe for in fish tanks
  • 19,065 Answers
Probably, but it will float!
Posted on Dec 31, 2016
I HAVE CONCORD GRAPES THE FRUIT DIEING ON VINE AND LEAVES ARE DRYING UP
Have a read. Disease, pests or virus.
Grape Diseases and Drying on the Vine ' Home Guides ' SF Gate
homeguides.sfgate.com > Garden > Pest Control
  1. Cached
  2. Similar
The leaves become mottled with tiny black spots and the fruit also bears dark spots. ... Most of the diseases that cause drying grapes on the vine are fungal ...
Why Are the Grapes Dying on the Vine? ' Home Guides ' SF Gate
  1. Cached
  2. Similar
Luckily, the fungi, insects and bacteria that cause fruit to rot or wither are easily ... Summer bunch rot-infected grapes have black, brown or green powdery fungal ... Removing leaves at the base of stems once grapes have set helps control both ... Best Time to Pick Concord Grapes for the Best Flavor · Grapevines & Leaf Curl ...
What Are the Causes of Grapes Turning Black Before They Ripen ...
  1. Cached
  2. Similar
If your grapes turn black on the vine before they ripen, the cause is usually black rot. ... which helps prevent infection by speeding the drying of leaves and fruit.
Why are my grapes turning dark and drying up before they ripen ...
https://ask.extension.org/questions/199835
  1. Cached
  2. Similar
Jul 16, 2014 - Minimize black rot problems by removing infected fruit, cleaning up mummies, and pruning out leaves that surround fruit clusters. See fruit links ...
Grape Diseases ' Integrated Pest Management Program - MSU IPM
www.ipm.msu.edu/grape_diseases
  1. Cached
Oct 16, 2014 - Leaves develop numerous dark brown spots, 1/25 to 1/5 inch (1 to 5 mm) in diameter. ... resulting in distinctive clusters of dead vines within the vineyard. ... Berries that do not fall off shrivel up, similar to black rot-infected berries. .... This disease occurs only in Concord and Catawba grapes in Michigan.
CONCORD GRAPES THE FRUIT DIEING ON VINE AND LEAVES ARE DRYING UP Google...
Aug 14, 2017 | Cooking
Tip
Using a pH meter to care for your fish
pH values are the acidity of a body of water. Neutral water has a value of 7.0 meaning that it has equal amounts of hydrogen ions and hydroxide ions. When more hydrogen ions are added the water then the number goes down and the water becomes more acidic, or if the amount of hydroxide ions goes up then the water becomes more alkaline.
pH levels in your fish tank can prove to be fatal if they aren't monitored properly. While there is no secret formula for the perfect pH level for all fish it is best to keep all the fish from the same bodies of water together. Salt water fish shouldn't be put in a tank with freshwater fish because they need different pH levels.
Throughout the day the pH level of your fish tank will change although these slight changes shouldn't be too harmful on your fish sudden changes will prove to be fatal. When you are moving fish from one tank to another you want to make sure that the two waters have the same pH levels. When you want to buy a new fish check the pH level of your fish tank and then the pH level of the water at the pet shop to make sure that the levels are not too different.
You should be checking the pH levels of your fish tank at least once a month, but more often is always better. When you take the pH level you should write it down in a log book. You should try to take the pH level at the same time every time you take a reading because at different times of the day the levels would be different. Try to keep yourself from going crazy, if the pH level is a few decimals off of perfect your fish will be okay. If the level is fairly regular you shouldn't have to do anything unless your fish show signs of distress.
on Feb 02, 2014 | Measuring Tools & Sensors
Hi. I purchased a pirate ship for my aquarium and it's been in it for almost a month. I quickly noticed that the white paint began chipping almost immediately.
Doesn't sound like it was made to be put in an aquarium. Because there can be toxic chemicals that will kill fish, it is a good rule to only put things that are labeled as being Aquarium Safe into a fish tank.
I would have removed it as soon as I saw the paint coming off. There's plenty of aquarium decorations out there, look for those if you want something other than a natural look in your aquarium.
May 18, 2017 | Fish
My betta fish is not eating. I placed a holiday disk in his tank for food while we were away this weekend.. Just got home and the water was extremely cloudy
I hope you did a big water change right away. The very first thing to do, any time there is a problem with water for fish, is to change at least half of it right away. If you have dip strip tests, test some of the water you change to find out if any readings are too high, but do the change first. If you don't have tests, you should consider getting some, they are the only way to tell if the water has too much ammonia, nitrite or nitrate for fish safety.
Cloudy water often means a bacterial bloom has happened, which isn't always dangerous to the fish. But sometimes they can be the result of a rise in ammonia. All fish produce ammonia as part of their respiration and all organic waste, which is broken down by bacterial action, also produces some ammonia.
For the future, It is MUCH safer to simply not feed your fish if you are going away unless perhaps you are trying to raise valuable fry. But most tanks of fry would also probably survive if their tank is provided with large masses of live mosses and floating plants. These provide minute food resources, infusoria, bacteria, algaes, which fish can pick from the plants. Plants, of course, need enough light so they don't die off.
For sure, unfed fish will get hungry, but healthy fish will not starve to ***** in a short time. Most fish can do fine for a week and I leave mine for two and three weeks if I must and so far, nobody has died. During an emergency, my fish survived for over a month without any attention at all, far from ideal but it could not be avoided. Those fish were living in a heavily planted tank and the plants provided food resources. It also contained shrimp and live scuds the fish could eat, though they didn't eat them all.
Even an unplanted tank, if not over-stocked, should be ok, unfed, for 5-7 days, so long as the fish are all healthy and similarly sized. Tiny fish are likely to be eaten if their tank mates are big enough and hungry. If possible, put the tank lights on a timer so the day/night cycle continues while you are away. Full-time darkness won't kill them but is probably not much fun for them, either.
Fasting fish also helps avoid potentially serious water quality problems that uneaten food and fish wastes may cause in a surprisingly short time. Many keepers fast their fish routinely, one or two days a week, which is thought to mimic the erratic availability of food in the wild.
Having living plants in the tank is very useful; they use up ammonia and nitrates and provide interest, shelter and resting places for the fish. Water changes serve to keep all toxin levels at safe levels. Nitrate should not test over 50 ppm at most, 10-20 is best. Ammonia & nitrite should always be ZERO. If any levels are over these, big water changes are the only remedy.
Any fish's tank, including that of a Betta fish, should have a filter of some kind. If it does, changing 50% of the water weekly is what I have found works out for the best. Filters convert ammonia and nitrite to nitrate, the least toxic
Sadly, it's still popular to keep Betta fish in bowls without filters. It's a long way from ideal, but if water changes are done diligently, the fish may be ok, though it often ends up chopping a year or more from their life span. Without a filter, 50% of the water should be changed THREE times each week. That's a lot more changes than most advisory sites will say, but fresh, clean water is the single best friend any fish will ever have living in captivity. Make sure the fresh water's temp' is within a degree or two of the tank's temp' when you change it. Use a siphon or turkey baster to suck up fish waste from the bottom at least every other week, if not more often. Don't remove the fish when you do these maintenance tasks because that can be a lot more stressful than leaving it in.
Never feed Betta fish any more food than they can consume within a maximum of about ten minutes. Many of them tend to be very slow or picky eaters, so they need more time than most other fish species. Remove any uneaten food after a half an hour.
Mar 20, 2017 | Fish
I want to plant grapes...how and when do i do it
https://www.arborday.org/trees/fruit/care-grape.cfm
How to Grow Grape Vines
How to Grow Grapes in Your Backyard
How to grow grapes RHS Gardening
Consider consulting your county extension agent who may have access to publications about such as well as special knowledge about your area.
Jan 25, 2017 | Wine & Spirits
Non toxic quartz dyeing suitable for aquariums
I don't think the Canon ink will work. Suggest going to a Pet store and talking with them about a safe paint or dye for fish tank
Dec 12, 2013 | Canon Imageprograf Ipf750 DyePigment 36In...
What fruits are bad for my cat?
Any food not specifically designed for cats can affect the digestive system, causing vomiting, diarrhea, or loss of appetite. Here are some foods of particular concern:
  • Alcohol can cause severe liver and brain damage. As little as a tablespoon can lead to problems for your cat.
  • Chocolate contains theobromine. It is in all forms of chocolate, and most concentrated in dark chocolate and unsweetened cooking chocolate. Chocolate ingestion can cause heart problems, muscle tremors, or seizures. Chocolate also contains caffeine.
  • Coffee, Tea, Energy Drinks. These contain caffeine that can cause your cat to become restless, have rapid breathing, heart palpitations and muscle tremors.
  • Dairy Products. Some cats are lactose intolerant and if they eat dairy products it can cause vomiting and diarrhea.
  • Fat Trimmings, Raw Meat, Raw Eggs, Raw Fish. Can cause vomiting, diarrhoea or a painful condition called pancreatitis (from excessive fat) and there is a risk of Salmonella or E. coli associated with these foods.
  • Grapes and Raisins. Cats are less likely to eat these so cases are rare however, dogs can suffer acute kidney failure from eating grapes or raisins, so it is best to not to risk your cat's health and not let him eat these foods.
  • Onions and Garlic. All members of the onion family can cause problems if eaten in sufficient quantity. A little bit of onion or garlic in some sauce is not likely to cause any problems. However, eating a clove of garlic or a green onion may cause digestive upset. Eating some type of onion on a regular basis could cause anemia.
  • Xylitol. This is a sweetener used in a lot of sugar-free foods, especially chewing gum. There are no records of cats becoming ill from this product, but in dogs it can cause a severe drop in blood sugar (which can cause seizures/convulsions or even *****) followed by liver failure. Therefore it is better to be safe and not let your cat eat foods that contain this ingredient.
Jul 25, 2012 | Cats
What food should I not feed my dog?
There are many food items that may be good for the humans or other animals but not for dogs. If you feed this food items to your dog it may cause toxic in there body and may cause some drastic problems for them. So better not to give such things to them. Here is a list of food items that you may not feed to your dogs.
  • Alcohol
  • Avocado
  • Apple Seeds
  • Baby food
  • Cooked Bones
  • Liver
  • Dairy Products
  • Raw Fish
  • Salt
  • Sugar
To give your dogs healthy and long life make sure not to feed them with this products in too much quantity.
Jul 18, 2012 | Dogs
My glass aquarium cracked. How can I fix it?
There are a few steps to take to fix a cracked tank:
  1. 1. b>Move the fish to a backup tank with cleanwater
  2. 2. Wipe the crack with white vinegarto clean the glass and let it dry completely. This will allow the silicone tostick.
  3. 3. Line the crack withaqua-marine safe silicone gel
  4. 4. Let the gel dry completely(usually overnight) before returning the fish to the water
May 13, 2012 | Fish
Wine & Spirits Logo
4,065 people viewed this question
Top Wine & Spirits Experts
Don Hart
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a Wine and Spirit Expert? Answer questions, earn points and help others
