Question about Sewing Machines
Which way to insert bobbins for siruba T828
Have industral Siruba T828 double needle do bobbins go clock wise or counter clock wise
  • 111 Answers
SOURCE: inserting bobbin
needle's in backwards
Posted on Jun 01, 2009
  • 1788 Answers
SOURCE: My needle does not pick up the bobbin thread. I
Make sure that you have the needle's flat side facing the rear of the machine, or else it will never grab the thread. Also, make sure you hold the top thread in your left hand until it grabs the thread and you pull the bobbin thread up
Posted on Sep 12, 2010
  • 411 Answers
SOURCE: after i insert the bobbin
is the thread going acrossed the top of the bobbin friction brings the thread up
Posted on Jan 18, 2011
  • 539 Answers
SOURCE: Needle breaks due to bobbin case slippage. How do
You CAN fix timing. Of course, it's up to you, but this is how to do it (I have over 30 years experience)...1. Remove the bobbin case. 2. Unthread your machine and put a fresh needle all the way up a's far a's it will go into the needle clamp, flat side flush against the needle bar. Tighten screw. 3. Set your machine on straight stitch, length at 6, and position needle at Center. 4. Remove the shuttle race ring and turn the handwheel a tad over 1/16". Observe the position of the point of the hook. It should be directly 1/16" behind the needle and pass a tad above the needle's eye. Put a drop of sewing machine oil (NEVER use cooking or bath oil! So many have ruined machines tinkering with improper oil!) on hook point CAREFULLY because that point is quite sharp. Use lint brush and gently sweep out any threads that may have broken off and got stuck in that area of machine.
Posted on Mar 29, 2012
SOURCE: Can a SInger 5050c use a double needle? I tried using one and it looks fine on the top but the bobbin thread is just one straight line on the back and doesn't look right.
try adjusting the top tension & see if that helps
Posted on May 10, 2012
Siruba 757b overlocker how do i change needle
You might try looking at the owner's manual or here:
otherwise, contact Siruba Support.
Aug 17, 2016 | Sewing Machines
The automatic threader isn't working. the bobbin isn't sewing correctly?
make sure the bobbin is turned counter clock wise, also try changing the bobbin, also try a new needle. you may have to have the automatic needle threader checked to see why it's not working
May 20, 2016 | Singer Inspiration 4206
Search the internet for:
Make + Model + the word "Manual"
Remove the thread. Install a brand new needle.
Be sure you are using thread that is compatible with the needle and fabric being sewn.
All About Needles
Raise the presser foot and rethread from the beginning.
Make sure your threading is following the correct thread path and the bobbin is loaded and threaded properly in the bobbin case.
If it continues to malfunction, it may need service.
Feb 24, 2016 | Sewing Machines
Thread keeps getting tangled in bobbon and wont sew
try a new needle
make sure the bobbin is inserted correctly,, counter clock wise
also check the upper thread tension, also check to make sure there aren't any loose thread or lint in the tension disc area
make sure the top thread has not come off the thread take up lever
check in the bobbin area for lint or loose threads
Dec 15, 2014 | Sewing Machines
How do i thread the bobbin on simplicity fashion pro sw 2145
normally counter clock wise for bobbin, usually the first thread holder is used and the 2nd is used for double needles. here is a link for parts
Simplicity SW2145 Parts
Dec 06, 2014 | Simplicity Fashion Pro SW2145 Mechanical...
Embroidery machine won't pick up bobbin thread
try changing the needle--make sure the needle is inserted correctly into the needle holder--
make sure the presser foot is In the up position
rethread the machine using every thread guide
make sure the bobbin is inserted correctly into the bobbin case--counter-clock-wise
if these suggestions don't help then the machine could have a timing problem
Dec 06, 2014 | Sewing Machines
My bobbin thread will not attach to top thread so the needle thread sews but nothing will come up from the bottom. WHy
sounds as if your bobbin is in wrong . I believe all bobbins are to be inserted so that it goes counter clock wise. When you place the bobbin in the bobbin casing make sure you check and see if it goes in the opposite direction of the clock. also check your needle it may be in backwards too
Feb 16, 2011 | Singer 8280 Mechanical Sewing Machine
I just got a new Singer Simple. I had a problem with the needle thread getting caught in the bobbin shuttle. I disassembled this area, found a random thread, and cleaned it out. I put it all back together...
Do you have the bobbin thread going the right way, according to owners manual some go clock wise some go counter clock wise when you pull the thread after bobbin inserted in bobbin case
Dec 27, 2010 | Singer 3116 Simple
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
