Question about Sony Playstation 3 (PS3) Console
Help it says my ip address has succeeded but dns failed on a d-link help!
  • 30 Answers
I have a simular problem with psp if something connected to your interent like magic,phone anything of the sort then that causes the problem you should probably buy a wireless router.
Posted on Jul 21, 2009
What is the default IP address of D-LINK DES-1024D 24-PORT 10/100 Ethernet switch and how can it be reset? its unmanaged version! mine is stuck on 169.254.180.130, while my routers has a 192.168.1.1. only...
This issue is more on a hardware. 169.254.XXX.XXX refers to an INVALID IP ADDRESS. Here's what you can try:
>release the ip address by running command prompt:
>>>>Click START>type CMD on the search bar>type IPCONFIG /RELEASE and hit ENTER
>>>>ip address will be set to 0.0.0.0
>renew the ip address: by typing IPCONFIG /RENEW and hit ENTER
>>>>it will generate new sets of ip addresses
However, if it still gives you 169.254.XXX.XXX you need to flush the DNS by typing IPCONFIG /FLUSHDNS and hit ENTER and it will immediately tell you that the DNS had been successfully flushed.
>Check your ip address by typing IPCONFIG and hit ENTER
That's the best I could do for the issue that you have.Thank you for choosing FixYa! Your rating will help me succeed and continuously help a lot people.
Feb 03, 2011 | D-Link DES-1024D Express EtherNetwork...
Tip
Why can't you connect to the Internet?
First check your TCP/IP address - see my earlier tip on checking you are connected to a network. For most recent systems, (not Linux) open a command prompt window (type "cmd" in the RUN window from the start menu) and type ipconfig /all
you should see your network adapter name and IP address, a subnet mask (don't worry) and a default gateway, also a DNS server IP address. If ANY of these are missing, that's your problem, try repairing or resetting the network adapter. WRITE THEM DOWN. You may have more than one adapter, you need to identify which one is used for the Internet connection.
If they are all there, from the SAME window type "ping" followed by the IP address of your default gateway. If this fails, you have no connection to your internet router, find out why!
If this succeeds, type "ping" again, followed by the IP address of your DNS server. If this fails, type "tracert" and then the IP address of your DNS server. The FIRST address that will be reported is your default gateway; followed by your ISP address; if the only address you see is your default gateway, the link to your ISP  is down, give them  a call. If it succeeds, from the same window type "nslookup"
You will see a chevron prompt, type in the name of the site you want to go to, e.g google.com.
You should then see a reply from your DNS server, and an IP address for your required server. If not, then either your DNS server settings are wrong OR the server does not exist. It will be obvious which it is from the reply you receive. If the DNS settings are wrong, you can change them from the Control Panel, Network, Network adapter, Properties, TCP/IP v4 properties menu; try setting DNS server to 8.8.8.8 or 8.8.4.4 and try again.
on Mar 26, 2010 | Computers & Internet
DNS FAiLED thats only the problem .. i can connect to wifi but when i start typing the url then enter go ..the response is dns failed
It is a problem due to DNS server ip address.If you configured ip address in mobile manually to connect wifi check the DNS address.If you have connected to wifi automatically means there is a problem of DNS ip in the wifi router configuration.Google has public dns of 8.8.8.8 if possible configure in Mobile and try it
Oct 28, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Mapping of D-link DNS-323 drive doesn't succeed.
I had the same problem when I was attempting to map the drive using the hostname of the DNS-323. I solved the problem by typing in the IP address instead. Do the following:
1. Login to the DNS-323 as admin
2. Make sure you use static IP's to make sure that the address does not change in the future.
3. Go to the drive mapping page and use IP address instead of hostname in the drive mapping (e.g. \\192.168.1.1\Volume_1)
4. Make sure you use a valid username and password.
5. Check the connection configuration by clicking on the Test button.
You should get a successful outcome, otherwise check all the settings again until you are successful
Nov 20, 2009 | D-Link Dns 323 2-Bay Network Storage...
Static IP address, primary DNSand Second DNS
hi
the router ipaddress or default gateway will be 192.168.0.1 and you can use any ipaddress from 192.168.0.2 to any... for your devices like computer and primary dns address will be 4.2.2.2 and the second dns will be 4.2.2.3
gud luck
thanx and regards
sukhvinder
Aug 18, 2009 | D-Link DIR-300 Wireless Router
Internet connection failed but IP address obtained.
sounds to me like you have the security turned on . Just type in your security key on PS3 and it should connect. Best of luck!
Jan 11, 2009 | Video Game Consoles & Games
Check to make sure that your router has gotten an IP Address from your ISP. Because you PS3 is telling you that it has an IP from your router. This means that the Router to PS3 connection has layer 3 connectivity, but what about from your router to your ISP? check that in the router by logging into the router's web page and going to the status page it should have your information from your ISP if it does not make sure that the main page is set to the proper settings either get IP automatically (Cable Modem) or Get PPPOE (DSL) connection (Make sure that your password information is correct to).
Now after checking these items make sure that you set the router up as the DNS for your network buy setting this on the status page then in your PS3 (set the DNS setting to point to your router, and set your router up as a caching DNS server).
Then power cycle the router after saving everything, and power cycle your PS3 after setting everything. This should clear up your problem.
Thank you,
Shuttle83
Oct 24, 2008 | Linksys Wireless-G Broadband Router
Xbox 360
Contact the people you get your internet from. tell them you need to register your xbox. I have the DNS issues when i visit my girlfriend at college since they dont like to keep the Download speed high for the students. always fails
Dec 16, 2007 | Microsoft Xbox 360 Console
Installation problem with edimax 6104kp
Hi Omdi,
Please proceed with the following instruction as follow.
1.) Connect first the modem to your pc, if you find it is working then get the IP Address, Subnet, Gateway, Primary DNS, Alternative DNS at the network properties TCP/IP.
2.) Open your router where you can configure the static IP or manually enter the IP address, subnet, gateway, primary dns, alternative dns.
3.) Make it sure you used the cable properly by connecting it to the appropriate line. For the modem to router you should connect the cable to WAN port. And the LAN port must be go through the computer.
If you still experience the problem, please let me know.
Best regards,
Philip
Oct 02, 2007 | Edimax BR-6104K Router (br6104k)
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
