Computers & Internet Logo
A
Anonymous Posted on Dec 31, 2016
What does configuring system mean in a Toshiba satellite T1150-S1120
Not powering up
cross check adapter & batter
problem in mother board
2answers
What's your problem?SCHEMATIC OF TOSHIBA T115D-S1120
You can download thewireless and device drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Put windows 7 on my laptop now i can not find ym web camera
You mean the webcam does not install or program does not detect it? Go into control panel> system > Hardware tab and device manager button and see if your webcam is installed there else download the driver and utility from the Toshiba site.
If it is then you need to use a better program like yahoo messenger or webcamax to configure it for use.
My Emachine T1150 keeps freezing up when it goes to load windows
When you start the system and you system goes to freez while loading window thats means there was a problem with OS,window is currept.you need to ghost means load the new fresh OS.
or if when you install a new window and thats loading time your system goes to freezing mode thats means there was a problem with your bootable CD or CD drive,change it vis a versa worked with another CD & drive and check it .
Thanks,
1helpful
2answers
My toshiba Satellite A215-S7422 System unit, dose not shut down until the batries runs down.
1. It means the normal shutdown process is not working!
2. Try to press the "Power" button continuously untill the system shuts down!
3. Restart the system.
4. Press F8 key to get the advanced booting options.
5. Select the last option "Last Known Best Configuration"!
if it don't helps tell me...tc! :)
4helpful
Cant type @ key in toshiba satellite L300 laptop
you need to change the layout of your keyboard. "Regional Settings" in windows.
Check on http://en.wikipedia.org/wiki/Keyboard_layout what your layout is and configure the correct one in the operating system you are using
1helpful
2answers
Wheres the ram?
RAM modules must be installed in special locations on the motherboard called Sockets. These memory sockets are what hold the RAM module in place and can range from 1 to 16 or more. Banks consist of a group of 1 or more sockets. A system can have 1 or more of these banks of sockets. If a system has more than 1 socket in a bank, a Kit must be purchased for that bank. A kit is simply more than one, usually 2 or 4, like RAM modules. All sockets in a bank must be filled. Typically you will see 2x512MB or 2x256MB signifying you get 2 units of 512MB RAM modules or 2 units of 256MB RAM modules, respectively.
The Toshiba Satellite A40-S270 has 2 bank(s) which have 1 socket(s) in each bank for a total of 2 memory socket(s). This means the Satellite A40-S270 can support up to 2 individual RAM modules.
Below is a visual representation of the memory bank(s) and socket(s) configuration for the Toshiba Satellite A40-S270.
socket_1.gifsocket_1.gif This graphical representation above details what the memory configuration would look like with the maximum memory installed and does not necessarily model your system memory configuration. This graphical representation is not drawn to scale and should only be used as a general reference. Please consult your system’s user manual for your actual memory configuration.
Toshiba satellite laptop keeps restarting
Is the fan working? It might be overheating.
Or one of the drivers is corrupt, and crashing the computer. The only way to solve that is by remotely (by means of starting from CD with a mobile OS).
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
