Blue rectangle on projection screen - Televison & Video
A black rectangle showing in the middle of the screen this appeared suddenly
this sounds like screen burn with rear projection and plasma when a picture is left sitting still on the screen sometimes it will burn in to the screen rendering it useless i left my ps3 paused on my old tv then when i changed to bbc one it still had a faint call of duty pause screen in the back it can vary from things like that to logos to your black rectangle the only way of repair is by replacing the screen all toghether i would advise you to just take the screen off and start using the tv as a projector if you cant find a screen it is only a bit of ribbed plastic but very hard part to find
Feb 16, 2011 | Toshiba 46HX83 46 in. Rear Projection...
Yellow Screen over most of the TV?
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Hitachi 50UX57B 50" Rear Projection...
Black rectangle on the screen
That sounds like the Closed Caption function is turned on. Go to the menu and turn it off if it is on.
Jul 29, 2009 | Toshiba 65H82 65" Rear Projection...
I have little boxes at the bottom of my screen. They appear when there is a light picture on the screen. Three rows of small rectangles. Help! Mitsi 65 that just got the blinking green light fixed.
you're probably used to watch tv with le closed captioned on. On big sceen tvs, the closed captioned text will burn the 3 crts (green, red and blue) it is written on the first page of your owner manual and there is nothing to do to fix it. it would very costly. sorry
Jun 30, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Black box in middle of tv screen
This is a background for text, even though you aren't seeing any text at the time. Since it covers most of the screen, it sounds more like a demo mode screen than closed captioning. Go into your setup menu and make sure that neither of those is selected. If necessary, restore the factory settings. I'm assuming that this is coming from the tv itself, and that you don't have a VCR, Tivo, etc. Good luck!
Jun 15, 2009 | Hitachi 50UX57B 50" Rear Projection...
Sony kp-65wv700
take the back off there should be a small rectangle with 6 buttons on it 3 for focus and 3 for the G2 (screens) some models have this control in the front behind the speaker grille behind an access panel and others have the control switch on the circuit board that is attav=ched to the crt neck. Either way its just a small switch much like a volume switch but smaller. Depending on what chassis you have it will be in one of the 3 areas I have mentioned. just turn it down a little. If that doesnt take the lines away you will need to trouble shoot the blue drive circuit.
Mar 21, 2008 | Televison & Video
Samsung TV HCM5525W Convergence & GIANT SQUARE
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 02, 2007 | Samsung HCM5525W 55" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
