How do I open control panels to reset keyboard functions
2 Suggested Answers
  • 3 Answers
SOURCE: Microsoft multinedia keyboard volume control keeps
This may help, go to control panel under sound and audio devices make your Microsoft sound your default unit, also make microsoft your only device. Select use only this device at bottom of page.
Posted on Aug 03, 2009
My neighbor disabled my Toshiba touch pad. what do i press to re enable it?
Start menu. Control panel. Go from there with keyboard options and it should work. OR research stick keys/ on screen keyboard
Feb 24, 2015 | Toshiba Computers & Internet
Why have ive lost the function to use the at key
Hi Diane Andrews
You stated as you have lost the @ function on your keyboard . And by looking at your DP i suppose its a laptop . Well then if so you might need to reset the keyboard layout settings for your laptop . Different OS has its different settings . You might have changed your language settings which may or might have caused it . Steps on how to its here . But if you have lost the @ key itself then ... you might need to get it change at your nearest computer repair shop or bring it to the vendor . Or maybe for time being you can use the on screen keyboard
CLick start - under the search - type On screen Keyboard and select it to use it .
Basic .. Fix an external keyboard and try if it works on that keyboard . If it does then your laptop keyboard might be at fault or need to change the settings .
Method 1 of 3: Changing the Language Settings (Windows)
If your keyboard is not displaying the correct characters when you press keys, your language settings may have gotten changed. If you have the incorrect region selected, your keyboard will act differently. To change it back, open the Control Panel.
You can access the Control Panel from the Start menu. Windows 8 users can right-click on the Windows button and select Control Panel from the menu
Open the Language settings. How you access this depends on which version of Windows you are using.
Windows 8 - If you are in Category mode, select "Change input methods" under the "Clock, Language, and Region" section. If you are in Icon mode, select "Languages".
Windows Vista and 7 - If you are in Category mode, select "Change keyboards and other input methods" under the "Clock, Language, and Region" section. If you are in Icon mode, select "Region and Language" and then click the "Keyboards and Languages" tab. Click the Change keyboards... button.
Windows XP - select "Regional and Language Options", click the Languages tab, and then click Details..
Select your language. Use the menu to select the default input language you want to use. In Windows Vista and 7, select your preferred language from the "Default input language" drop-down menu. In Windows 8, move your preferred input language to the top of the list.
Sep 15, 2014 | Acer C7 Chromebook
Why did my enter key suddenly no longer function as to enter, when pressed it brings up a toolbar instead of taking to the next line?
your keyboard utilizes keys F1-F10 as re-programmable function keys.to change your current pofile press the razer lycosa logo+functon key(f1-f10) or you can reset your keyboard to factory default settings by pressing the "Razer Logo" button for 15 seconds while the Razer Lycosa is connected to a powered on computer. NB: ALL CONFIGURATION SETTINGS WILL BE LOST WHEN YOU RESET THE RAZER LYCOSA
TO FACTORY DEFAULT SETTINGS. ALL CONFIGURATION SETTINGS WILL NEED TO BE
RE-ENTERED OR LOADED FROM THE CONTROL PANEL AFTER THE RAZER LYCOSA IS RESET.
Jul 21, 2013 | Razer Lycosa Gaming Keyboard
I am not able to work with my keyboard function keys and num keys and function keys . but the the touch pad key is onlyworking .please send a solution to unlock the keyboard. hp pavilion g6-2102tx
Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon. Hope this helps.
Dec 10, 2012 | Computers & Internet
My employer recently purchased the Microsoft wireless 3000 keyboard. Though I'm enjoying it very much I have been wondering (along with my IT people) why the function keys do not perform the same...
Hi
I also use the old keyboard PS2, but the all key working file like a F2 used to open the field edit, and excel F4 performed a delete, there is need to go the new keyboard. all thing is working in old keyboard, check these setting in your computer. Go to the control panel open regional setting click language select details and chose the default language united state.
May 09, 2011 | Computers & Internet
I am left handed and am experiencing difficulties scrolling with mouse
Open "Control Panel".
Open "Mouse".
Switch the mouse from "right-handed" to "left-handed",
i.e., make the RIGHT button (not the LEFT) to function as the FIRST mouse-button.
Sep 22, 2010 | Logitech Deluxe 650 Keyboard, Mouse
Microsoft multinedia keyboard volume control keeps quitting until i open the control panel volume window. Once i open the master volume icon the keyboard volume works gain till I shut down the computer....
Aug 03, 2009 | Microsoft PS2 Multimedia Keyboard...
Keyboard doesn't work
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Sep 13, 2006 | Gateway 2520915 Keyboard
Computers & Internet Logo
David Payne
David Payne
