Question about Garmin nuvi2555lmt nuvi 2555lmt
Nuvi2555LMT I just purchased Micro card for upcoming trip to Argentina. Place in Garmin but only original data for North America shows up under maps. How do I complete this installation so Im now seeing South American data/
    Scholar:
  • Garmin Expert
  • 186 Answers
The micro SD card has to be between 4-8gb. Garmin Express is used to load the South American maps. Garmin Express can be downloaded from Garmin. Once installed on your PC, plug your GPS into your PC. The program should give you the option to install the South American maps to the SD card.
Posted on Apr 08, 2017
  • 9 Answers
SOURCE: Maps don't show after downloading upgrade.
sounds like you might not have the new map set selected
settings -> map -> map info (make sure the NT 2009 map is checked)
Posted on Mar 18, 2009
SOURCE: Need help unlocking maps in City Navigator NT North America.
I turns out that the unlock code was discreatly printed at the bottom of a yellow piece of paper in the packing.
Posted on Mar 22, 2009
odiebugs
  • 949 Answers
SOURCE: Not enough space for maps?
The garmin does not have any space on it for maps,any additional maps are stored on a memory
card. I don't see where garmin says the size limit of the card but in most cases unless it says
SDHC memory card,then the max is a 2g sd card, I think the models 500 and over can use over a 2g card.,
Posted on Mar 27, 2009
  • 156 Answers
SOURCE: Remove a map to make space on my garmin nuvi 205
I would reset the whole unit to factory specs & then load map.
Posted on Jul 06, 2009
  • 3289 Answers
SOURCE: I bought a lifetime update
The internal memory of the nuvi is full. Some maps will need to be delete before any new maps can be added. Typically, the map in the nuvi is named GMAPPROM.IMG and a map installed to an SD (or SDHC) memory card is named GMAPSUPP.IMG.
1) Remove the SD card from the memory slot
2) Connect the nuvi to the computer via USB cable.
3) Open the nuvi drive.
4) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
5) Empty the Recycle Bin.
6) Retry the map update of the nuvi.
This method will take some time to perform depending on how many map segments you are sending to the nuvi. Transferring the entire map can take over an hour. A quicker way is to send the maps to the SDHC card directly by inserting the card into a card reader. This eleminates the slow Garmin card reader from the equation and transfers are done in a fraction of the time. No maps will be on the nuvi - they will all be on the memory card instead. To update the SD or SDHC card, do this:
1) Repeat steps 1 thru 5 above. This removes the maps files from the nuvi.
2) Disconnect the nuvi from the computer.
3) Connect a card reader to the computer.
4) Insert the SD or SDHC card into the reader.
5) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
6) Update the map to the SD or SDHC card.
When either method is employed, only one map file set will result. GMAPPROM.IMG or GMAPSUPP.IMG is the name of this file set. You should ensure / change the name to GMAPPROM.IMG. Any subsequent file set added should be named GMAPSUPP.IMG.
I hope this helps & good luck! Please rate my reply - thanks.
Posted on Jun 27, 2011
Testimonial: "A quick, clearly explained solution that worked. Thank you"
Only shows us routes not canada
I fell foul of that the other way. I have Canada maps and lent it to a friend who was going to California.
You need a map that covers Canada and it is an extra cost. The USA is in two zones, or one map does both zones.
You need to buy the Canada maps and then put it on an SD card. The map costs $84
https://buy.garmin.com/en-CA/CA/maps/on-the-road-maps/city-navigator-nt/city-navigator-north-america-nt-canada-only/prod8750.html
City Navigator North America NT Canada Only Garmin
Feb 20, 2016 | Garmin Nuvi 2360Lmt - Gps Receiver
Can a New York card be used in Florida ?
Depends on the make and model. Garmon splits the US up. The chop of California for some reason.
City Navigator North America NT Lower 49 States Garmin
This one does all of North America, so check your maker.
https://buy.garmin.com/en-US/US/maps/on-the-road-maps/city-navigator-nt/city-navigator-north-america-nt/prod1456.html
Dec 02, 2015 | GPS
Why when I try to enter an Address with State = California, my Garmin Nuvi 660 only shows "Cayman Brac" and "Connecticut"? I'm on software version 4.90 and I have "CN North America NT 2015.40 ([1] Lower...
CN North America NT 2015.40 ([1] Lower 49 States NE)
NE = NORTH EAST... California is not in the North East of the United states. This device only has a small internal memory so you need to use a 4 GB memory card and load maps to that card with MapInstall:
How do install mapping to my device with MapInstall
Mar 24, 2015 | Garmin Nuvi 660 GPS Receiver
My nuvi 3760T does not have enough space to load europe map. Can I remove preloaded north america map and reload at a later date without losing it?
If you have the map downloaded from the garmin website to your computer you could remove it and replace it later. However a better option might be to download the map of Europe to your computer and install it to a micro SD card. A 4 Gb card would hold the map of Europe and you don't risk losing your North America map. You can get details of how to set up the map on your micro SD card at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
While this link is mainly about how to update your maps it has a section on setting up maps on an SD/Micro SD card also.
Mar 26, 2011 | Garmin GPS
Need a North America SD Card map for my European Garmin nüvi 255w. Where can I buy one on line
You can buy direct from Garmin via this link. You can opt for instant download, purchase of SD memory cards or DVD ROM medium. You may also be able to buy maps at some of the outdoor stores and electronics specialty shops.
If you plan on using this GPS in North America from this point on, you might want to look into purchasing a "Lifetime Maps" subscription for about $119 instead of the one-time map purchase for $79. The subscription allows you do download updated maps up to 4 times per year, for life of the GPS. Contact Garmin Support directly for more info about this option.
Nov 22, 2010 | Garmin nuvi 255W GPS Receiver
Need a Map Source CD for a Garmin iQ 3600 GPS
Please visit http://www.ebay.com
Search for the needed item and there you are.
rate this solution afterward.
Sep 04, 2009 | Garmin iQue 3600 GPS Receiver
Mar 17, 2009 | Garmin nuvi 350 GPS Receiver
Garmin map update
I recieved a notice on my gps saying that i must updated
my citi navigator to north america nt v8
do i have to do it
Aug 05, 2008 | Garmin StreetPilot C330 GPS Receiver
IQue 3600 missing disks
The simplest method is to update the software for the Mapping/Data, the one you probably had is sooo out of date!
http://www8.garmin.com/cartography/mapSource/citynav.jsp
City Navigator North America 2008 DVD
MapSource City Navigator North America
(includes access to the whole disk)
Garmin Part Number: 010-10474-00
U.S. List Price: $139.27 (for domestic US market only)
Sep 26, 2007 | Garmin iQue 3600 GPS Receiver
Garmin nuvi2555lmt nuvi 2555lmt Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
