Question about Optics
Remote for duel multimedia car stereo
Model numberxdvd256bt
I need to know what color is remote wire in the stereo
not sure what brand or model your using but every time i've installed a car stereo the remote wire has always been the same. (to be clear i'm not saying they're all going to be the same) but ive worked with multiple brands before and the remote wire in everyone of those was always solid blue! hope this helps.
Apr 24, 2015 | Cars & Trucks
Start up volume way too loud! The answer here is to push in volume button to set..my volume button when pushed in sets mute and on/ off
Annoying issue but honestly, I have no idea how to operate your "Jensen VX7020 6 2 Inch MultiMedia Bluetooth" but logic says you should read instructions. Read these instructions
http://www.jensenmobile.com/docs/common/VX7020/VX7020_IM.pdf
Watch these videoos, maybe get some hint
Jensen VX7020 6 2 Inch TFT Car Stereo 2 0 DIN MultiMedia Receiver with...
Jensen VX7020 6 2 Inch TFT Car Stereo 2 0 DIN MultiMedia Receiver Review
also some info at this website. Check it:
vx7020 manual
Feb 19, 2015 | Jensen VX7020 6 2 Inch MultiMedia...
2002 Isuzu rodeo -tail/illumini lights keep blowing fuse. Can't figure out what all this fuse goes to-so we can check wiring. Any ideas?
I would be first checking that the correct bulbs are fitted to the light sockets. If the socket has a single contact and a duel contact bulb has been fitted then the fuses will continually blow as there is a dead short across the contacts .; Check for cut /damaged wires at the light assemblies as if there has been no body damage or any add ons done that require screwing or drilling then the damage to the wiring will be remote. The rule is if single contact socket then single contact bulb and if duel contact socket then duel contact bulb.
Jul 16, 2014 | 2002 Isuzu Rodeo
What aftermarket stereos will work with usa spec scd-f100
That unit is designed to work on Ford vehicles that have a CD button but no CD changer.
Oct 13, 2012 | Ford F-250 Cars & Trucks
Need a battery for my hct remote for stereo
Go to "manualsonline.com.
Select "RCA"
Fill in model number in table on the left hand side of screen and select "ask a member for help".
Type in problem and wait for a reply.
Dec 21, 2009 | RCA RCR660 Remote Control
Manual for lightware vp800, and i can't get the sound to work
Try changing to your S video wire input.If you hear a cracking sound it could be you've blown your speakers.It depends on your application but I run all my DVD equipment through my stereo system,just run the same video wire to your stereo and select that input on the stereo .And yes they do have remote controls,try ebay where you can get another vp800 w/remote under 100.
Dec 22, 2008 | Lightware VP 800 Plus Multimedia Projector
Optics Logo
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
