How can I delete old readings without removing the battery?
  • kakima Dec 31, 2016
    Hi Hal Ballard, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
Is it possible to delete VERY old account on qeep mob without access to email or password? i want to remove my old profile pic form internet...
You will need your passwords to change any settings. I doubt they can help either as the account is setup on your old email address. Why not re start your old email address and email the company for a new password.
Jan 29, 2017 | The Computers & Internet
I have the toshiba satellite a35-s1592 and I want to know what preinstalled programs I can delete?
Try a google search for a program called 'pcdecrapifier' it checks for pre-installed software that you may not need. No you can't remove older windows updates, I believe the newer updates build on top of the older ones. Also I use a program called Revo Uninstaller, to remove programs and any left over files and folders and registery files that windows doesn't. Hope this helps.
Nov 11, 2011 | Toshiba Satellite A35-S1592 Notebook
Battery not charging for labtop why?
take out the battery from the laptop. does the laptop turn on without the battery? if it does not, either the AC adapter is bad or the connection inside the laptop (the DC jack) is loose or broken. If the computer turns on without the battery, more than likely the battery is bad. if the computer is less than a year old, a warranty will usually cover it (it depends on the manufacturer, you'll have to read your warranty info to clarify) if the computer is much old, the best solution is purchasing a new battery.
May 03, 2011 | Computers & Internet
My old memory card all of a sudden reads unusable, So i bought a new one...and it still says unusable... what do i do? I have only had the camera for 4 months
Try putting the new memory card into the camera and format the card. If the camera doesn't accept that it has a memory card turn the camera off remove the battery and then after about ten seconds put the battery back in and turn it on and see if you can format the new card again. You should always format the memory cards in the camera, even though there is a delete for single images leave them on the card and format the card. Always format the card in the camera not the computer.
By deleting single images in on the card while in the camera it sets up little partitions and pretty soon the memory card is rendered useless. Formatting in the computer writes a little program to the card which the camera can not read.
Dec 20, 2010 | Kodak EasyShare C142 Digital Camera
Can't delete old pictures
It depends on the brand or model of camera you are using, but if you cant get how to delete a picture from your camera, simply get a card reader, then remove the memory card of the camera and insert it into the card reader, connect the card reader with your computer, so from your computer you will be able to delete old picture. But I still know that most digital cameras should be able to delete old pictures, simply read your camera manual to see how to delete or you tell me the model and brand of the camera that you are using.
Sep 22, 2009 | Cameras
TI-nspire screen doesn't work
Here is what the TI knowledge base says about a calculator failing to turn on
For the TI-Nspire™ Family:
  1. Remove thekeypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) andremove at least 1 battery from each column of batteries. After 2-5seconds, reinsert the batteries and turn the unit on. This will causethe unit to reboot the operating system.
  2. Remove the keypad(for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove atleast 1 battery from each column of batteries. After 2-5 seconds,reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and thenback off). Hold down [Home] [Enter] [P], and while holdingthese keys, press [On]. The device will boot up as in the previousreset, but will display a menu with the following options. Please tryoptions 1, 2, 3, and 4 in that order. ** The [Home] key is located atthe top right of the TI-Nspire keypad and has a picture of a house onit.
Note:TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
2. Delete Operating System – The operating system will be deleted without deleting any documents.
3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS.
4. Complete Format – This will delete the OS and all documents for a total erase of memory.
Hope it helps you solve the problem.
Aug 30, 2009 | Texas Instruments TI-Nspire Graphic...
My calc wont turn on at all no matter what i do.
Try these, courtesy of the TI Knowledge Base
Jul 23, 2009 | Texas Instruments TI-Nspire Graphic...
Calculator keeps powering off after a few seconds
  1. Remove the keypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and turn the unit on. This will cause the unit to reboot the operating system.
  2. Hold down [Home] [Enter] [P], and while holding these keys, press [On]. The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 2, 3, and 4 in that order.
    1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts. 2. Delete Operating System – The operating system will be deleted without deleting any documents. 3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS. 4. Complete Format – This will delete the OS and all documents for a total erase of memory.
    Note: TI-Nspire family model options 2 and 4 above require that the OS be reinstalled. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
Dec 03, 2008 | Texas Instruments TI-Nspire Graphic...
26 people viewed this question
k24674
jasbo
jasbo
