Question about Air Tools & Compressors
Doerr lr22132 air compressor 2hp need to find out belt size
What kind of hydraulic oil does a doerr LR22132 take
ELECTRIC MOTORS USE TYPICALLY SAE20 WT MOTOR OIL FROM A ELECTRIC MOTOR HOUSE. YOU CAN GET AN OILER FROM LOWES OR GRANGERS. IF YOU ARE TALKING ABOUT AN ATTACHMENT SUCH AS A GEAR REDUCTION UNIT YOU WILL POSSIBLY FIND THAT INFO ON THE UNIT OR GO TO THE MANUFACTURERS WEB SITE
Dec 29, 2017 | Garden
Central pneumatic air comp model 9416797
Hi I have a central pneumatic 29gal 2hp comp when I turn it on it trips the breaker any answers
Sep 11, 2013 | Air Tools & Compressors
I nedd diagram for electic motor doerr LR22132
I am sorry but we have no wiring diagrams here at fixya.
Jul 27, 2012 | Cars & Trucks
Looking for a product or instruction manual for a Mongomery Ward 2hp air compressor circa 1970's approx. Has the art.no. xer6468 and serial #12039-215993 printed on the side. This is a 2 cylinder oil...
If you need to tighten belt loosen the motor and slide back until belt taut and should have about 1/2" to 3/4" in deflection. You might try ebay for manual
Jul 29, 2017 | Chicago Forge AF5HV 30 - Gal. 5.0 - HP...
I NEED TO REWIRE A DOERR LR22132 ELECTRIC
The green should be connected to the chassis, it is ground.
There should be a wiring diagram on it to tell you how to do this, but if not:
There may be T-leads on the motor labeled
P1, P2, T3,T4,T5,T8
P1-L1(black wire)
P2-cap/tape don't use.
T2,T3, and T5 wire nut together
T4,T-8 wire nut together with L2(white)
The power leads will be coming from your switch box on the compressor body itself. Don't wire the 220v directly to the motor, you replace the leads where the first motor was connected on the cutoff switch. There will be only 2 leading from the switch to the motor.
Mar 24, 2010 | Plumbing
I need to convert my 220 wiring back to 110 on my sears air compressor model number 106.173841 with doerr electric motor model 600678.
There should be a plate where the ires run thru, and on the plate or motor itself, there should be a diagram shouwing what terminals to connect the leads too.
Hope this helps.
Jan 17, 2010 | Air Tools & Compressors
I have a doerr electric motor, lr22132 single phase 220v, 3/4 HP with wires t2, t3, t4, t5, t6, t7, t8 and earth, how do i hook up, any help would be great, paul
i have a doerr electric motor, lr22132 single phase 220v, 3/4 HP with wires t2, t3, t4, t5, t6, t7, t8 and earth, how do i hook up, any help would be great,
Nov 20, 2009 | Kitchen Appliances - Others
Air Tools & Compressors Logo
133 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
