How do I get it to read subtitles? - Televison & Video
  • kakima Dec 31, 2016
    Hi Claudia Miller, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model is "it"?
I need to update the software of my LG DV532how can i acieve that?
You dont need to update your software of your dvd,you just need to make sure your dvd usb supports arabic or just do this, Search your movie in google with SUBTITLE ex.Superman subtitle, then if you found your language download it, usually it is a .zip file when you download it ex Superman subtitle.zip you will need to extract that using winrar or any extract tool, after extracting the file should end with .srt ex. superman subtitle.srt, if it is, make a folder in your usb then copy the movie and subtitle in it (make sure the movies name and subtitle name are the same ex. superman.mp4 and superman.srt) then play it.
Mar 06, 2016 | LG Televison & Video
How do I turn the subtitles off for the yamaha HTR-5730 AV receiver? When I hook the cable up directly to the TV, there are no subtitles, but when the video output goes through the receiver, subtitles
The receiver manual may list it under "CC" (closed captions) instead of subtitles. Also, don't just check your AV receiver; try checking the setup menu on your TV, and look at the TV remote. See if there's a CC setting that may be turned on, either through the TV setup (probably under the "Display" or "Video" tab) or because you've accidentally pushed the CC (or Subtitles) button on the TV remote.
Nov 26, 2014 | Yamaha HTR-5730 Receiver
I can't get subtitle to turn on. Zenith DVD player to play movie with Subtitle
What you want is Closed Captioning. It has nothing to do with subtitles. If you turn off the speakers in your TV, the CC should appear after a brief pause. If your TV is not equipped for CC, this approach won't work
Nov 11, 2012 | Televison & Video
Cant find the option to add subtitles to a movie played through a portable device
the remote control comign Subtitles, do it, if not work, you must see when your are starting the film, if contain this options. because will not work.
2= Not all format contain this option in USA, in Latin America, comign with this optin, and you setup the option subtitles, and languajes by the remote control.
Read you instruc. manual download from www.fitness.manualsonline.com or www.retrevo.com
God bless you
Jul 17, 2012 | Televison & Video
Hey, I am watching a dvd's called Dilemma. I have been having trouble with subtitles on that movie because the subtitles is too big to fit the screen or maybe it's my picture screen position! I...
most pirated dvd having problems like this due of illegal copying they omit the subtitle and sound enhancement data. try to use original dvd.
May 27, 2011 | Televison & Video
Subtitles always on
Hi - welcome to FixYa,
There are 2 methods for changing the subtitle settings on your DVD player.
Method 1.
To turn off the subtitles on your DVD player during playback:
1. Press the "SUBTITLE" button on your remote control
The subtitle button is just below the "0" (zero) numerical key on the remote control. It is marked "SUBTITLE" above the button and the button has "ABC" written inside a white rectangle on it.
2. Use the left "<" and right ">" arrow keys to change the subtitle setting
Each time you press an arrow key the subtitle language will change and eventually the language will read "OFF". The subtitles are now switched off during playback.
Method 2.
To turn disc subtitles off from the main menu:
1. Press the "MENU/LIST" button on your remote control (directly below "STOP")
The main menu will now appear
2. Press the down arrow key on your remote once to highlight "A" in the left hand column of the main menu
3. Press the right arrow key on your remote once to move to the right-hand column of the menu
4. Press the down arrow twice to highlight "Disc Subtitle"
5. Use the left and right arrow keys to change the subtitle options until your required choice is displayed
6. Once set, press the "MENU/LIST" button again to exit the menu.
This should solve your problem, but if you need any further assistance, please post back.
Regards,
BElectric
Nov 21, 2010 | LG RH-4820 DVD Recorder
Unable to access subtitles whilst watching digital channels
Contact your TV service supplier to be sure that subtitles are available in HD ...
Jan 07, 2009 | LG Televison & Video
How i can view divx whit subtitles (.srt, .sub.ssa)?
it is quite easy to play those anoying subtitles first name the same way both files (video file and subtitle file) example movie.avi movie.srt be sure that both files are in the same folder second: insert the cd/dvd in the yht-630 when the menu appears select the subtitle file using the arrow keys and press the "subtitle" key after this at the screen you will see -> subtitle selected finally select the file that contains the movie (again arrow keys) and press "ok" or "play " key the movie will start and the subtitles will appear. it functions with sub and srt files
Jan 25, 2006 | Yahoo YHT-630 System
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
