Question about Black Watches
I need a manual for my morefitM5 plus touch screen bluetooth black Smart bracelet wristband
How do I connect to kogan Bluetooth vibrating bracelet
I had the same problem myself
Go to this:
it's the user manual for the bracelet and it has the steps in there
when it says to "hold down button two until 'pairing...' appears" just keep holding button two down (it might take 30+ seconds)
Dec 20, 2012 | Watches
Gold wristband, need to take a link or two out of it. do I need to go to the jeweler ECO-Drive
I would suggest taking to the jeweler you bought it from. But here is a link to Citizen that will help you in your search for instructions to do it yourself: Sizing
Best regards
Aug 23, 2010 | Citizen Eco-Drive BL5184-56L Wrist Watch
I want to remove links on my wristband.
Most wristband links are held together with screws or pins. Screws are usually only found only in high end watches so you most likely will have to remove pins. Without the proper tools and know how you will most likely scratch the bracelet or, worse, damage the pins. A jeweler can do this for you easily and, if they even bother to charge you, it shouldn't be more than $5. Should you wish to proceed on your own, you can buy the specialized tools on ebay quite reasonably.
Apr 10, 2010 | Armitron Two Tone Sports Watch
How do I adjust the wristband on the timex expedition indiglo?
Read my tips and tricks. Watch band is called bracelet as well.
Jan 23, 2010 | Timex Watches
Shorten movado wristband
There is nothing you can do yourself as the special equipment is needed.
Find your nearest watchmaker and ask to shorten your bracelet.
Dec 18, 2008 | Movado 0605068 Wrist Watch
Wristband too big
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Dec 02, 2008 | Kenneth Cole KC1104 Wrist Watch
srevice center for tissot watches here in the philippines is only at timeline...g/f farmers plaza cubao,q.c. its fronting gateway and araneta coliseum.
Jul 29, 2008 | Tissot T-Touch T33759851
Tissot T-Touch T33.7.788.51 Bracelet replacement
Sounds like it's broken @ a factory sealed link (non servicable). Local jeweller should be able to order & fit you a new one
Feb 19, 2008 | Tissot T-Touch T33759851
Watches Logo
13 people viewed this question
Top Black Watches Experts
Bill Boyd
Are you a Black Watch Expert? Answer questions, earn points and help others
