Question about Vacuums
Leggett&Platt adjustable bed stuck in upright position
How do I adjust the height of the brushes and suction
look for a blockage -something may have dislodged the lever mechanism, or be stuck preventing the roller or position leaver from moving.
Sep 26, 2014 | VAX Appliances Vax X5 Bagless Upright...
Bissell 3576 height adjustor broken
Hi Chris! Lock the vacuum in the upright position, set the height adjustment to the desired setting, then recline the handle for the change to be made.
If you continue having difficulty, you may want to have one of our Authorized Service Centers inspect your vacuum.
Here's a quick link to help you locate one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
May 19, 2013 | Bissell 3576 CleanView II Bagless Upright...
Dyson 28 handle is stuck in the locked and upright position. Vac runs fine, just can't get the handle to release to run the vac
On the lower right side of the body of this model is a air duct piece that can get stuck and won't allow you to use the release. Take out that piece and put it back on again to see if that will unlock it.
Nov 30, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Belt tension adjustment
If you are looking at the belt while the vacuum is in the upright and locked position, the belt will be loose. The idler removes tension so the brush doesn't spin while you walk away and put heat marks in the carpet. Hit the lever that allows you to move the handle low, like you are vacuuming under the bed, and the belt gets tight.
May 25, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Loss of suction when using upright. Suction remains for samll tools no suction when in upright position makes funny noise but ok when not used in that position kindest regards louis
u can remove the flexi pipe by pressing the inset button,it may be bit stiff if it had not being removed before.may be something is stuck at the bottom,also remove u bend where most of the stuff get stuck. i just posted how i fixed the suction and over heating problem. pl read it. good luck
Feb 08, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Levels/Settings
These height adjustments are designed so that they will not adjust when the handle is in the "back" position. This is so they will stay where they are set and not self-adjust while you are vacuuming. To change the setting, you need to return the handle to the upright position and the adjust the setting and the machine will go to that position when the handle is lowered.
Jan 25, 2008 | Hoover Elite Rewind Bagless Upright...
Problem with wheels
If the belt is over a year old, it should be replaced. This is normal maintenance and is often overlooked. When the handle is in the upright position, it will appear the the height adjustment is not working. What's actually happening is that the height adjust is easily moved so you can make any adjustment you want. When the handle is pulled back, the front of the machine will lower to that setting and lock, so it will not adjust itself while you are vacuuming. If you wish to change the setting, you have to return the handle to the upright position, or you can lift the front of the machine with your hand, taking the weight of the machine off the wheels and this will allow you to slide the adjustment to another position. It is possible that the adjustment mechanism has come apart. It is comprised of three separate components. It would be very difficult to explain it here and should be addressed by someone familiar with this model.
Jan 12, 2008 | Hoover U5264-930 TurboPower Bagged Upright...
Carpet Height Adjusment
In addition to the tab that contacts the bottom of the slider, there are 2 protusions on the adjustable wheel plate that move through holes in the housing, but only when the handle is tilted to begin vacuuming. The wheel plate has a spring that forces the tab against the slider. As the handle is moved to the upright position, the protusions move back through the holes, taking the tab away from the slider and the wheel plate locks in its highest position. Therefore, the position of the slider has no effect while the handle is upright and locked. Hope this helps.
Aug 19, 2007 | Hoover U5753-900 WindTunnel Bagless...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
