Question about Kenwood DV-705 Multi-disc DVD Player
I have a Kenwood DV-705 multi disc changer. Lights 1, 2, 3 & 4 are lit when the unit is powered up. The slide will not open. I have pulled the cover. There is no disc inside.
  • 883 Answers
SOURCE: Pioneer PDR-W839 Jammed Disc Changer (previously posted)
hello poopig1, after further review, I meant to describe this: look for a pinhole in the area of the CD tray to insert a pin...similar to the same pinhole you see on a PC's cd player to eject the tray manually. If there is none, then try this: Open the cover and find the motor that, when turning, performs the tray ejection. Then, turn that motor by hand until the entire tray (or cartridge) is ejected. Then power up and observe the events.
Posted on May 31, 2007
pjstanley
  • 185 Answers
SOURCE: How to connect an aux audio cable from Kenwood krc 705 to Ipod Photo
no sorry cant help
Posted on Apr 05, 2008
4x4dawg
SOURCE: Re: Kenwood DV 605 CD
ace71cf.jpg We repaired this problem by taking the advice of another member of FixYa! The component had recently been packed to be shipped. After unpacking the unit when we powered up the read out only displayed "LOADING" and the CD changer door would not open. We removed the exterior cover and gently moved the CD changer one position. When it locked back into position we powered up and the unit works fine now. FixYa sure help me save perhaps a $100. or more by not sending it to the manufacturer or another shop. And it was working within minutes so we could enjoy using it right away. Thanks guys I very much will recommend this sevice to others... this was the 2nd problem we fixed that day by logging onto FixYa!!!
Z-Dawg
Posted on Dec 07, 2008
  • 61 Answers
SOURCE: CD magazine trapped in Ford CD changer, no power to release
there is a way to get it working with the ford radio as long as the ford radio is cd changer compatible. You can purchase an adaptor from a dealer of autoleads. They also have a website. http://www.autoleads.co.uk/ were you can find out if its compatible and what lead you need. As far as i can remember with the jvc changers there is a seperate lead for power for a changer which you have to earth to the body of the car aswell have you got this
Posted on May 19, 2009
emissionwiz
  • 75822 Answers
SOURCE: My original problem WAS that
there are small drive belts that provide the power to operate the different parts to eject the CD magazine, i suggest you remove the covers and check these belts for slack/strech, it is a common reason for this problem
Posted on Jan 28, 2010
Wave Music system Multi-CD Changer
The unit has a power supply problem, no user servicable parts inside. Bose uses a thermal fuse built into the power transformer. Take unit apart and check for connection issues first, then look for a possible fuse, if none exist chances are it is in the power transformer, contact Bose for service.
Sep 02, 2012 | Bose Wave music system Multi-CD Changer...
Tray won't open
by just resetting the software will not work this is a mechanical problem this usually happens on players that is not use for a long time or improper closing of tray..fixing this kind of problem requires opening the cover of the unit..you need to lubricate all moving gears and parts by putting enough amount of lubricating oil..you have also need to assist the motor manually by helping it to push the tray out just gently pull the tray with your hands during a eject command on the unit clean also the limit switches of the tray make that contact are properly working..good luck!
Apr 06, 2012 | Kenwood DV-605 Multi-disc DVD Player
How do i hook up the dvd player to the t.v?
It's quite straight forward, you wiill need a Scart connector. Then connect one end into the rear scart socket of the DVD & the other end into the scart 1 socket of the TV again at the rear. When you play a DVD just select the AV (1) input on the TV. On some TV's AV can also be identified as Aux.
Oct 23, 2009 | Kenwood DV-705 Multi-disc DVD Player
Re: Kenwood DV 605 CD Player... Power On: Reads "Loading." All 5 CD lights are lit up but the CD changer does not turn. CD #1 appears on screen with two green lights appearing.
Z-Dawg
Dec 06, 2008 | Kenwood DV-605 Multi-disc DVD Player
Tray will not open on my dv-605
Solution: Unplug power from wall. (Don't just turn off!) Next: Remove exterior case. Now gently turn the CD changer clockwise one position. Power up and try again.
I had this same problem after unit appeared to have froze up when unpacked from a shipping box. The CD changer had got off track and by gently moving the CD changer 1 position it fixed the problem. Works fine now.
Best of luck,
Z-Dawg
Apr 30, 2008 | Kenwood DV-605 Multi-disc DVD Player
DVD will not show picture
No activaste por equivocacion la funcion PROGRESIVE SCAN s
i lo hiciste desactivala,no cambiaste el formato PAL o NT
SC.
Apr 24, 2008 | Kenwood DV-705 Multi-disc DVD Player
Disk error with Kenwood DV-605 multi-disc DVD player
Try the following
when the error is on the screen, press the number 1 key on the remote, this should take you to the fist chapter of your DVD no matter which region it is
Miguel
Jan 03, 2008 | Kenwood DV-605 Multi-disc DVD Player
Dv-605 kenwood
I have a similar issue with my DV-605 as well. When the unit power on, I can hear the motor trying to start, but the DVD does not spin. Being the adventurous type, I opened the case and turned the DVD drive motor a few revolutions by hand and then the dvd played. I think I need a new DVD drive motor. You may as well....
Dec 09, 2007 | Kenwood DV-605 Multi-disc DVD Player
DVD
I just fixed mine. Same scenario, with the loading and #1 displayed. The tray changer was jammed.
Take the cover off the unit and gently convince the changer to spin. It will go *crack* and then exhibit free-play. Turn the machine back on and voila it works.
I'm now watching Braveheart on 480p on 55"widescreen!!!!!
Wally
Oct 27, 2007 | Kenwood DV-605 Multi-disc DVD Player
Kenwood DV-705 Multi-disc DVD Player Logo
Top Kenwood Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
