Question about Brother Sewing Machines
My stitching on Brother ls 2020 sewing machine is loose. How do I fix the problem
  • Brother Master
  • 10,291 Answers
Without more description of the stitch symptoms, the only suggestion is that the tension is too loose. Whether it is the upper, bobbin, or both tensions, we cannot answer without more information.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Posted on Jan 01, 2017
Mimito7
  • 128 Answers
SOURCE: loose bottom stitch on brother se 350
Hi, general rule of thumb:: loops on the top, problem on the bottom.. Loops on the bottom, problem is on the top.. When threading your machine, stop just before you thread your needle, put the presser foot down. Try pulling the thread. If it pulls easily, the thread is not thru the tension wheel right. If it pulls hard, you got it right.
Posted on May 12, 2009
Zenqi
  • 208 Answers
SOURCE: I HAVE A BROTHER LS-2125 SEWING MACHINE AND THE
Sounds like either the bobbin case tension is too light or is not in the tension at all.
Consult your manual for how to place the thread in the tension and retry. Increase the bobbin case tension if necessary.
The top tension may be set too high.
Posted on Jul 11, 2009
  • 1126 Answers
SOURCE: I'm new to sewing. I was given a Brother LS-1217
Page 15 in this users guide.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_1217_EN_186.PDF
Posted on Sep 17, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
  • 1116 Answers
SOURCE: manual for Brother project 211 sewing machine.
You need the actual model number for the machine and then you can download a manual here - http://www.brother-usa.com/HomeSewing/
Posted on Feb 27, 2010
Brother ls 2020, 3 dials for tension, ALL I WANT TO DO IS MEND. what is the # just for mending? why are these machines so hard to work?
A manual may help:
User Guide Manuals LS 2020 Others Brother
There is only one tension dial, the round knob above the needle. Standard setting is the midway point between high & low number. The other two knobs are the stitch length and stitch width dials. With the stitch length knob, zero will make the machine sew in the same place, so you'll want to set it probably midway (the higher the number, the longer the stitch). With the stitch width dial, zero will sew a straight stitch--the higher the number the wider the stitch). Spend about 30 minutes reading the manual and you'll probably be able to use your machine. ALWAYS RAISE the presser foot when threading the top thread so the thread will seat properly.
A video may also be helpful:
https://www.youtube.com/watch?v=UC4ci-t5M60
RELAX!!!
Mar 30, 2017 | Brother Sewing Machines
Pattern selection dial
take the machine back & get another one
Aug 30, 2012 | Brother LS-2125 Mechanical Sewing Machine
Where to buy a foot control and power cord for model ls-2020
you can go to www.sewingpartsonline.com and order one through them, they are pretty much the same for there LS models. Or you can call Brother at 1-877-276-8437 and order directly from them
Jan 02, 2011 | Brother LS2020 Sewing Machine
My Brother LS-2125 does not stitch forward - only in reverse.
What stitch selection have you made, anything to do with the buttonhole? If, so make sure that you let it go through the cycle then, pick a straight stitch pattern with a longer stitch length. You can also go online to brother-usa.com and see if there are any other suggestions
Sep 16, 2010 | Brother LS-2125 Mechanical Sewing Machine
Shank for my brother ls 2020
Any Brother dealer, they are very cheap anyway
Jul 11, 2010 | Brother LS2020 Sewing Machine
I HAVE A BROTHER LS-2125 SEWING MACHINE AND THE STITCHING UNDERNEATH IS OK BUT THE UPPER THREAD IS LOOSE AND ALSO SKIPS
Jul 11, 2009 | Brother LS-2125 Mechanical Sewing Machine
Loose stitch with loops on top of material i got the right needle and bobbins what do i need to do i have ls 2125 brother
General rule of thumb is this.. If it loops on the bottom the problem is on the top..
If it loops on the top, the problem is on the bottom.
Sounds like #1 your bobbin is wound very loosely , #2 your bobbin thread has to go thru its tensioner.
Apr 19, 2009 | Brother LS-2125 Mechanical Sewing Machine
I'm having troubles with my brother sewing machine
Your tension is loose on top. Adjust your tension dial up a little at a time until you have a desirable stitch. Before adjusting the tension, you may want to look into the tension and see if there are any threads caught between the disc. If so remove them. Another common problem is that your machine is not threaded properly, make sure the pressure foot is in the up position when threading and if needed consult your manual for the proper threading diagram.
Jan 16, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
