Question about Bionaire Air Purifiers
Volume of air (cfm) for Bionaire model 4010 - Bionaire Air Purifiers
Are Bionaire F150/150S/150W available?
Refer your inquiry directly to Bionaire.
Jul 21, 2014 | Bionaire Air Purifiers
Bionaire BAP1300 -- Working fine for 2 Days then, Red Light
Try to do a hard reset by unplugging the device from the power outlet and wait for sometime to reconnect.
Jun 09, 2008 | Bionaire BAP1300 Air Purifier
Tip
BAP1500 FILTERS GOOD TIP FOR RECYCLING!
I had a Bionaire BAP1500 which was broken, light up but nothing happens.
i also have a BAP412 and BAP242 which need to have their filters replaced every 3 months - which is very expensive.
I thought i would try the permatech filters from my 1500 in the other 2 purifiers to see if they would fit - they do! and they both work perfectly with the filters installed..no more buying filters for me
So just a tip to say if you have a BAP1500 and its broken, keep the filters because you can use them in a much cheaper model!
on May 09, 2008 | Bionaire BAP1500-U Air Purifier
Reset Filter Indicators on BAP 725
there should be a small pin hole somewhere on the top of the unit. Stick a pin in there hold for about 3 seconds and it should reset.
Sep 01, 2008 | Bionaire HEPA Air Purifier Air Purifier
Bionaire bap825 air purifier
if you have a manual it will be on page 2 of the manual under cleaning and maintance. it willhave the picture there. if you don't have the manual. the hepa's go in first and they should snap on and the the carbon lays on top and then you put the back on the unti back on.
Apr 14, 2008 | Bionaire BAP815B-U Air Purifier
Lost amnual
the lights are the ionizer light, the filter indicator light which is the light that will come on when the filters need to be changed, ionizer control button, the speed control and the power light.
Dec 04, 2007 | Bionaire BAP825-U Air Purifier
Manual
if you go onto the bionaire website and in the search bar type in your model number it will pull up a pic. click on the picture and right underneath it it will say your model number and then manual. if it's not there scroll down until you see a customer service box and the first one should say manual. clickon that and it will pull up in adobe reader
Sep 21, 2007 | Bionaire HEPA Air Purifier Air Purifier
Red Light indicator on
I have a Bionaire tower air filter model BAP1700 that I bought from Costco. The filter check LED came on recently after 5 months of use. After cleaning the Permatech filters, I tried every remedy on this website including following the instructions that say push power button for 2 secs. Nothing worked. Then I noticed a tiny hole on the control panel in front of clean filter LED; I pushed a paper clip pin into that hole, felt a click, held it down and 2 secs later, LED went out. Success!
Apr 06, 2007 | Bionaire BAP1500-U Air Purifier
Bionaire Hepa filter
The carbon filter should have the air passing through it first, before the hepa filter. The carbon filter removes the large particles which would otherwise block the hepa filter very quickly. Contact these guys if you need more help; http://www.bionaire.com/contactUs.aspx Hope this helps :)
Jan 01, 2007 | Bionaire LC0760 Air Purifier
Air Purifiers Logo
169 people viewed this question
Top Bionaire Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Tim Whalen
Are you a Bionaire Air Purifier Expert? Answer questions, earn points and help others
