Question about Humax Televison & Video
Purchased humax freevie getting great pictures bbc1,itv etc but smaller channels like pick quest no picture just sound some pictures but frozen
SOURCE: My Humax PVR picture freezes
Fixed it. Unplug your aerial, start it up (it will not freeze), go into the menu and reset to factory defaults (code 0000). When it has finished plug in the aerial but stop it searching for channels, reset to defualt again. Next let it find the channels and save them and it should work fine (mine does).
Posted on Jul 04, 2008
  • 33 Answers
SOURCE: no sound on analog channels
Grab your sharp remote and press MENU, arrow over to SETUP, arrow down to RESET and press enter and follow that prompt to reset the unit. Once that is complete turn the tv off and unplug ONLY the tv for one minute then plug it back in. Then turn the tv on and see if you have channels, if you do, your audio should work on you analog stations, if you have no channels and all you see is a snowy picture do the following press MENU, arrow over to SETUP...arrow down to CH SETUP and press ENTER...you will then be at a screen that says AIR/CABLE, press ENTER, select CABLE or CABLE(STD) if that option is available to you. after then, arrow down to CH SEARCH, press ENTER, then you should be highlighted on ANALOG AND DIGITAL SEARCH...press ENTER and wait for 15-30 minutes ( or until you get a picture back) and make sure you DO NOT press any buttons or turn the tv off and you should be good. good luck 2 u
Posted on Feb 19, 2009
  • 105 Answers
SOURCE: Digital channel 25 has no sound.
First make sure SAP or nothing similar is turned on.
After you triple check that just Contact ILO if it continues for more than 1month. This is a software error.
What state are you in?
What channel is this?NBC, ABC
Have you check this at different times of day?
What TV does your son have?
Posted on Jun 24, 2009
SOURCE: Digital TV not picking up all channels
TV is searching for over the air channels. Select in the main menu to go from over the air to cable channels and you should be fine.
Posted on Oct 10, 2009
tvtek
  • 1284 Answers
SOURCE: Toshiba 26LV610u TV with no sound on one channel
If you have lost sound on only one station and are using cable or an antenna directly to the TV. Look in the audio settings as most likely the SAP mode is turned on. If the TV detects a SAP signal even if there is no audio this is what you will end up with.
Posted on Nov 05, 2009
On my Techwood it as built in freeview but every other channel is right except bbc1 and bbc2 both channels say bbc wales,How do i get them back to bbc1 and bbc2 please PLEASE HELP.THANK YOU.
What you need to do is retune the TV, but when it is finished look at the regional settings. Or if the regional option is available before retuning, retune selecting your area so then you get normal BBC channels. It's likely that at the moment the channels for BBC are located at the very top end of the channel list say? - channel 800+.
You are clearly picking up signals from many transmitters. With regional settings you can change it to the area you live in.
But you will have to take into account how good your aerial is. Otherwise the signal quality will not be good on same transmitters. So the set may only suggest those with the best quality signals.
ITV stations might also change.
When done it will move the channels you mention to the top end of the guide, to 800+.
Note many HD channels have no regional options. For example here in Yorkshire we only get ITV Granada and not Yorkshire TV on the HD channel for ITV1. And BBC1HD does not show any programmes when local news comes on.
Jul 02, 2016 | Televison & Video
Unable to watch ITV, Channels 4 and 5, Frreview on my television.
try and do a res set on your freeviev to re find the channels sometimes works or you may have a damaged wire from your airial due to weather or water damage
Jun 16, 2016 | Televison & Video
Can get bbc picture but not the other channels
BBC1 and BBC2 are among the strongest signals you could simply have a low signal reception, try a channel dump and re scan for all digital signals, try re tuning on a different aerial if that's possible. If all this proves fruitless the fault will most likely be on the Main AV Panel where the tuner an IF stages are found. Post your Brand and Model Number for more specific help suggestions
Dec 30, 2015 | Televison & Video
How do I get my channels ITV 3, 4 5 + 6 back on my PVR Humax 9300T
You are going to need to have your aerial adjusted, it's getting conflicting signals. I have a Humax in London, not until recently was this sorted out by repositioning the aerial to the strongest signal.
Jan 08, 2015 | Humax PVR9300T HD DVR
Loss of some channels on 32LD30U B
Weak digital signal. Either antenna or tuner.
May 03, 2010 | Televison & Video
Reprogramed humax after digital day cant get bbc1 or bbc2 all other channels okay
Could only get bbc1 london,wales, scotland, or northern ireland. Could not get bbc1 south.
Try other nearby post codes, tried 3 or 4 then eventually hit on one that worked . (Bournemouth area)
Mar 25, 2010 | Humax DRT800
Unable to get BBC 1 and 2 on Digital. Both Channels are ok on Analogue but switch to Digital and programmes start at ITV( channel3) Have re tuned since last digital update but still the same. Have used the...
There is not a problem with the TV despite it's age this is can be due to your reception of the digital package for BBC. Have you checked through he full listings? sometimes the BBC channel will be at a different number setting because of the transmitter you are receiving. I assume you are using a digital box, you can enter a menu which will give you an indication of the strength & quality of the incoming signal. Do you pick up some of the other BBC channels such as BBC3 or CBBC? It's possible your aerial strength is a bit weak for the digital BBC package & you may need to have that looked at.
Oct 07, 2009 | Panasonic Televison & Video
Can only tape clear pictures on DVD recorder from BBC1/BBC2 EX78E
Are you in the UK? Is the new DVD player compatible with TV in your area?
Some technical details like make and model would be helpful.
Apr 05, 2009 | Panasonic Televison & Video
My Humax PVR picture freezes after a few seconds (on BBC1) and no controls work - switching off and on the problem recurs.
Jul 03, 2008 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
