Question about Refrigerators
Auger starts nice but once i put in into ice to drill bogs out,
  • Refrigerators Master
  • 3,368 Answers
More information is needed so somebody can help you. What Does HVAC Repairman do for Furnace Maintenance
Posted on Dec 31, 2016
How do I replace the ignition coil on a strikemaster solo 142 ice auger. I can't see how to remove the plastic case to get to the ignition coil.
To replace the ignition coil on a strikemaster solo ice fishing auger you will need to go about it from the bottom side. remove the auger drill itself and turn the unit upside down. remove the 4 screws and the snap ring remove the screw that connects the throttle arm. remove the remaining bolts that hold the upper part of the gear case and remove the entire gear case unit. now you will be able to access the screws that hold the plastic cover and have access to the coil.
Feb 10, 2016 | Refrigerators
Ice maker does not dispense ice through the door
Hello. I had the same problem. I replaced the auger motor(around$95) 3 times and would only last about a little longer than a year. I bought the 4th one but this time, I wanted to diagnose the issue. So it turns out that the auger motor goes installed with the impeller upwards. What was happening was that if a piece of ice would stay in the dispenser chamber and melt, the water would go into the auger motor eventually causing the auger casing to get full of water and slow it down or short it out. I took the casing apart and noticed that there was a small space between the motor and the casing. I drilled 2 nice sized holes in the dimple of the new motor very gently as to not drill into the impeller motor and installed the auger. To this day, 3 years later, no more having to buy new auger motors. Hope this helps!
Mar 10, 2015 | Refrigerators
What are some common uses for augers?
Well, some common uses you may be familiar with are drilling through ice for ice fishing and drilling into maple trees to take out the maple syrup.
Jan 31, 2013 | Drills
Pw 50, cleaned air filter,put new plug in,bike starts fine,then feels like choke is on and bogs down,plug is wet ,smells of petrol,,,,no power , tried running to clear through ,sputters then sounds...
cover up the drilled holes this can cause problems, why was a new carb fitted? did the shop have it running?
not likely rings .
check carb for flooding and correct jet sizes.
check safety kill\start\run switch for shorts.
Feb 25, 2011 | Yamaha DT 125 X Motorcycles
Engine starts and idles, give throttle, revs, bogs, revs, bogs
Check for a loose connection by the carb. Sounds like its sucking air.
Feb 25, 2010 | Garden
I have a older model # 30 jiffy ice auger and i can not seem to keep it running consistanly. I was wandering what the carburator adjustments are. The low idle screw and the high idle screw where do I start...
Hello Randy. I can talk you through making adjustments to your Jiffy ice auger engine.
1. Read through the whole list before you start adjusting.
2. Close both jets GENTLY
3. Open the Low speed 1/4 turn
4. Open high speed jet 1 1/4 turn
5. Start engine.
6. Adjust low speed until idling smoothly.
7. Open her up wide open.
8. Adjust High speed until engine transitions smoothly from idle to high speed without bogging.
9. Shut engine off. Let it cool.
10. Once engine is cold. Fire it up and let it idle for 30 secs. Open it up wide open again. Adjust if necassary.
NOTE 1: The trick with the Jiffy's is to tune them during cold (ice fishing) weather.
NOTE 2: Low speed screw,the one on the left.
NOTE 3: High speed on the right.
Good luck ice fishing! Regards, Joe
Dec 31, 2009 | Sport & Outdoor - Others
Ice maker makes ice but can't dispense ice
Please try this. Remove your Removable Ice Bucket Assembly which is where the Auger (corkscrew) is located. You should be able to see the Auger Motor Drive Fork which is located permanently inside the freezer compartment... opposite the end of the Removable Ice Bucket Assembly that you just took out. Close the freezer door and attempt to dispense ice... if you can hear the Auger Motor running as you attempt to dispense ice... then the Auger Motor is OK. Dump out all the ice that is in your Removable Ice Bucket Assembly and wash it out in your kitchen sink with warm water. Reach into your freezer and put your hand on the Auger Motor Drive Fork ... you should be able to rotate it CW or CCW...it is a little hard to turn but it will turn. Position the Auger Motor Fork to a 12:00 and 6:00 o'clock position. Now take your Removable Ice Bucket Assembly and position its Receiver Auger Fork to a 9:00 and 3:00 o'clock ....Re install the Removable Ice Bucket Assembly into the Auger Drive Fork. Close the freezer door and again attempt operate the ice dispenser... you should hear the Auger Motor again run as you press the ice dispenser. Note....at this same time the Ice Chute Door in the Freezer Door should spring open so that ice can fall out. Of course you have no ice in the Auger at this time...but it all this works then future production of ice will fall out. Note...Usually the Auger Motor never fails. but the whole thing can get jammed with ice and not dispense. Also, the the solenoid that operates the Ice Chute Door fails quite frequently. Last but not least... if nothing is happening... it is a control board type problem. Hopes this helps! Handy Henry
Jul 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice wheel not turning
If your model is the JSD2789GES let me know as I have the service manual 118 pages...Sea Breeze
Jun 21, 2009 | Jenn-Air JSD2789GES Side by Side...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
