I have a VL320M that works great not smart and a E320i-A0 with a broken LCD but good electronics smart tv. I'd like to combine the two - is it easier to move the LCD from the VL320M to the E320i or will it be safer to move the electronics from the E320i to the VL320M?
SOURCE: Broken LCD Screen on a Vizio VW42L. Where can I buy one?
Hello Sesman200,
We have a good screen in Stockton, CA... Call us at 209-465-6139 .. Dave
Thanks.
SOURCE: Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
SOURCE: My vizio VO32L will not respond after being tuned
I'm having the same problem (in the LA area too!) with my VO42L and VO22L...I called Costco and they've handed me over to Vizio. I'm waiting for a call back from Vizio right now, but I told them about your post. Hopefully, they'll get flooded with calls!
SOURCE: I need help with disassembly of Vizio GV42L LCD TV
remove all the screws and start at the bottom and push in the tabs, and work around the edges, being careful not to pry too hard, the cover has clips all around the tv. after the bottom is free and one of the corners the cover will kind of pop off if you use the palm of your hand and lightly tap as you apply sum upward pressure.
SOURCE: tv lcd vizio sv-420xvt1a no picture no sound back light on 12v
the problem was are in the main board control p/n 3642-0492-0150
