Question about Sewing Machines
7570 reads creative cards- choose design- msg. Raise presser foot lever- change ht position-ok-screen again shows all designs w/ no selection made. Where and how are sensors accessed for cleaning?
Lever ht...embroidery ht, up, or raised to very highest position makes no difference. so assume it might be a dirty sensor, but how to access and cleaning method recommendation needed.
5 Suggested Answers
  • 192 Answers
SOURCE: Presser foot wont raise and lower
Does the presser foot move at all when the machine is first turned on?
Do the needle and feed teeth calibrate when the machine is first turned on?
You probably need to locate your nearest authorized repair center.
Posted on Jun 12, 2008
Tally Girl
  • 1133 Answers
SOURCE: When I raise the lever the presser foot only lifts
yes, pressure foot lever should stay raised, this sounds like the spring has broken in your machine. if you are comfortable with delving into the machine you could open it up and take a look. alternatively take it to a sewing repair man and get it serviced as well as clean and lube.
Posted on Jun 26, 2011
SOURCE: computer stuck on "Raise presser foot lever" when I want to embroider
I fixed myself. When you take off the front left cover to expose inner workings o0f pressure foot lever, move the pressure foot lever see, the small metal plate move, when looking from back of machine see a small post upper left rear with what kooks to be a spring, lightly touch causing to spring back to the left and you will hear a snap. This is realigning pressure foot and your embroidery unit will register and you will have a normal lcd screen.This helped me, hope helps you.
Posted on Nov 09, 2012
  • 143 Answers
SOURCE: When I turn my machine on it makes a long rattling sound in the bobbin case area, then when the screen comes on it says to raise the presser foot up and turn power on again. The presser foot is always
How old is the machine ? Sometimes, the 'socket' [ for lack of a better word ], where you fit the bobbin case into the machine, can become worn with use. So the bobbin may be set a bit too low, compared to where it was when new. May cause noise, may cause failure to catch the bobbin thread by the needle.
Sometimes this can be remedied by use of something underneath to shim it up to the right height. But I must say, I haven't ever tried this fix in anything other than a fully mechanical machine.. that is, one that does not have any computer functions. I don't know how it might affect any sensors in the area.
Short of that, might just need to find a sewing machine repair shop.
Often it's just because of a buildup of lint, but you know about that, so that is unlikely to be the reason for this.
Posted on Nov 19, 2014
Testimonial: "My machine is the Janome 11000Se and I have it 6 yrs. The first four years I could hardly embroidery at with the constant thread breaking and thread shredding. It was finally discovered I had the wrong "P" foot (embroidery foot). The one I had came with the attachments with the machine but it wasn't even for my machine. The repair person that has worked on my machine is good and has adjusted the sensor for the latest problem but It seems to go back not being able to sew very long. I had the understanding that the newer machines are not supposed to be oiled and if you do oil them it could cause more noise. My machine also makes an ugly clacking soun when the embroidery arm goes into position. So much has gone wrong that I'm convinced I have a lemon. I just thought that someone might have new insight into this problem. Thank you"
Pfaff creative 7570 embroidery unit error message 'raise the presser foot lifter' won't clear even though it is raised?
I had this problem, but ignored it, go through the advised listing on the machine's screen, under 'pressure foot lifter' and see if anything can be adjusted.
Dec 08, 2016 | PfaFF Creative 7570
Cant get machine to embroider
there are three positions the presser foot can sit in. Up and down are the same on any machine. The 7570 has an in-between position for embroidery. Lift the presser foot and the lower it slowly while pushing gently. It should stop about half way down. The embroidery foot pushes the foot into the down position with each stitch allowing the fabric to move easily to the next stitch.
Jan 29, 2013 | PfaFF Creative 7570
Where to buy another creative blank pfaff 7570 card
try contacting pfaff customer & ask them if a pfaff dealer would carry them
also try
May 02, 2012 | PfaFF Creative 7570
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
Cannot get presser foot into sewing position
if the presser foot is stuck in the up position you need to get some WD40 and spray the shaft.
Nov 24, 2010 | PfaFF Creative 7570
I have a 2144/2170 and new Florini software. I do not know how to transfer a design from the computer to the creative card with a cord and then to the sewing machine. The design is in the autoditizing...
I bought a Ultimate Box and Ultimate Card, Wright the design to it, and then in the machine, I use the Data Manager to select the design (doesn't show the actual name, just dsgn1 or something like that), ok to the warning.
Jan 13, 2010 | PfaFF Creative 7570
Pfaff Creative 7570
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}You need to do a tension assembly test
Tension assembly test. To do this test. Pull the threadthrough the tension assembly and test it to make sure the tension is workingcorrectly.
(To do this test, adjust your tension setting to normal or medium or 5 orsomething in the middle. Raise the presser foot and pull the thread through thetension. It should pull easily!! Lower the presser foot and pull the thread. Itshould pull noticeably harder.)
If it doesn’t work this way then you probably have a pieceof thread or lint stuck inside the tension discs. To remove it, turn thetension to 0 zero and raise the presser foot.Using a small screwdriver, openthe space between the discs and spray with canned or compressed air( a needle will work also). The stuffshould come out. Do the tension test again to make sure you got everything andthen try sewing again.
Nov 18, 2008 | PfaFF Creative 7570
Pfaff 7570 creative card
Hi Eva,
You should be able to clear the card by holding down the card key as you turn on the machine. You should then be able to reformat.
Jun 11, 2008 | PfaFF Creative 7570
Trying to us Creative Card
There is an in- between setting. It's not up, but not down either. Does that make sense? If you put the lever up, then bring it down slowly and kind of push it to the back. Hope this helps!
Feb 03, 2008 | PfaFF Creative 7570
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
