My sky caddie touch has stopped being able to be charged. No idea why. Is this a common fault?
It won't charge off a wall socket or a laptop.
    Top Expert:
  • Computers & ... Master
  • 52,149 Answers
Dead battery will never charge
Posted on Jan 01, 2017
adi_techmax
  • 57 Answers
SOURCE: not charging
try to pull out the battery and run the laptop on the charger...if the laptop starts, then it's an issue with the battery....else have the charging port checked out by a certified technician.
Posted on Jan 18, 2008
frcs68
  • 1605 Answers
SOURCE: If I press POWER all the lights are ON only for 2 secs and then OFF again
I would remove all attached items. memories, hard drive, battery.
unlpug the AC. push and hold the pwer button for 20 sec. (discharge the PC).
plug in the AC and turm it on. (BIOS) only. if that is good, then install other devices.
Posted on Oct 29, 2008
SOURCE: Battery not charging when Laptop powered on Acer Aspire 4520
replace the battery of lappy
Posted on Feb 09, 2009
leecom72
  • 4806 Answers
SOURCE: my acer aspire 5315 doesnt charge properly.
I'm sorry to say that your initial fears are correct and the pin that the adapter connects to in the laptop is loose. This is a common problem with laptop's and can be easily dealt with.
Now I'm not going to tell you to open the laptop up and de-solder the adapter (unless you want me to).
Because this is a fiddly job and you have to order the correct adapter i recommend you take it to a reputable repair store and have them replace the adapter for you, don't let them tell you that you need a new motherboard as this is not the case at all, adapters can and do get regularly get fixed and is not that expensive.
Good luck.
Posted on Aug 18, 2009
SOURCE: my samsung r480 won't power on, or charge
First remove the battery and connect the charger, if power is coming,Then connected battry
Posted on Apr 05, 2012
My sky caddie touch will not power up and does not appear to be charging when I plug it in the flashing light does not flash?
Check the connection and power supply.If the problem persists look for a dealer closer to you.
Jul 23, 2016 | Televison & Video
Sky caddy breeze will not charge
I cannot charge my sky caddie breeze even though I am using the same lead and USB port that I have always used. Do you know why this might be?
Jan 02, 2014 | SkyCaddie BREEZE GPS
Rdrhow to find recharge componets on a215-s4807 motherboard?
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Aug 14, 2012 | Toshiba Computers & Internet
V-touch won't turn on
Check and see if you have a loose charge port on the V-Touch, or it could be a short in the cord. Try and plug it into a computer and see if it will come on. If not try using different USB ports on the computer (some work better than others.) if that does not work I would try a wall socket. You can get a USB to wall socket plug from almost any I-pod or I-phone. Droid and Android also it. If you still have no luck you could send it back to Visual Land for them to fix. If your warranty is still valid, they will fix it for free. Hope this helped.
Apr 27, 2012 | Visual Land V-Touch Digital Media Player
NO POWER
Hello, use the charger on another laptop and use another charge with your laptop. By so doing, you would now if its a charge fault or not. If its not a charger fault, it means the charging socket or the power board of the laptop is defective. You need to disassemble the laptop to get to the root of the problem. Regards.
Jan 01, 2012 | Computers & Internet
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
My HP DV9700 has recently got a problem after 2-3 years of problem free use. The battery isn't charging but says it is plugged in. When I disconnect the adapter from the wall end the blue light goes out,...
If you don't have damage to the socket on the laptop it sounds like you have a faulty adapter. Pretty common especially after 3 years.
Try a replacement. If that doesn't work the socket on your laptop is most likely damaged and a costly repair if you take it to HP.
Ted
Sep 10, 2010 | HP Pavilion dv9000z Notebook
My ipod touch wont stay charged i need help!?
You can do 2 things,
1. Stop charging from USB port and buy yourself a wall socket adapter.
2. Replace the battery,
And as a tip I will tell you that you shouldn't let your battery run down flat keep it charged always.
Aug 12, 2010 | Apple iPod touch 1st Generation (8 GB) MP3...
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
